Hi, I try to measure our game's performance on galaxy s6(SM-G920K). I measured on galaxy s7 successfully, but I coundn't do that on s6. I added some log code to gatord source code, and got this message. What should I do??
MaliHwCntrReader::create(device = 0xf4f24290){ unsigned probeMMUCount(device = 0xf4f24290) { MaliHwCntrReader::create(device = 0xf4f24290, mmul2count = 1, jm = 0, shader = 0, tilter = 0, mmuL2 = ffffffff) { MaliHwCntrReader::MaliHwCntrReader(device = 0xf4f24290, mmul2count = 1, buffercount = 1, jmBM = 0, shaderBM = 0, tilerBM = 0, mmuL2BM = ffffffff) { device file path = / dev / mali0 MaliHwCntrReader : ABI version : 10.6 KBASE_FUNC_SET_FLAGS : OK KBASE_FUNC_HWCNT_READER_SETUP : hwcntReaderFd = 5 KBASE_HWCNT_READER_GET_API_VERSION : api_version = 1 KBASE_HWCNT_READER_GET_BUFFER_SIZE : sampleBufferSize = 6144 KBASE_HWCNT_READER_GET_HWVER : hardwareVersion = 5 MaliHwCntrReader : Could not mmap sample buffer } MaliHwCntrReader::MaliHwCntrReader(device = 0xf4f24290, mmul2count = 1, buffercount = 2, jmBM = 0, shaderBM = 0, tilerBM = 0, mmuL2BM = ffffffff) { device file path = / dev / mali0 MaliHwCntrReader : ABI version : 10.6 KBASE_FUNC_SET_FLAGS : OK KBASE_FUNC_HWCNT_READER_SETUP : hwcntReaderFd = 5 KBASE_HWCNT_READER_GET_API_VERSION : api_version = 1 KBASE_HWCNT_READER_GET_BUFFER_SIZE : sampleBufferSize = 6144 KBASE_HWCNT_READER_GET_HWVER : hardwareVersion = 5 mmap(nullptr, bufferCount_ * sampleBufferSize, PROT_READ...) : OK initialize = true } MaliHwCntrReader: Successfully created reader, with buffer size of 2 } // MaliHwCntrReader::create(device=0xf4f24290,mmul2count=1,jm=0,shader=0,tilter=0,mmuL2=ffffffff) [MaliHwCntrReader]::probeBlockMaskCount() { MaliHwCntrReader::triggerCounterRead() { ioctl(hwcntReaderFd = 5, KBASE_HWCNT_READER_DUMP) : rcode = -1, errno = 22, Invalid argument } MaliHwCntrReader::triggerCounterRead() { ioctl(hwcntReaderFd = 5, KBASE_HWCNT_READER_DUMP) : rcode = -1, errno = 22, Invalid argument } MaliHwCntrReader::triggerCounterRead() { ioctl(hwcntReaderFd = 5, KBASE_HWCNT_READER_DUMP) : rcode = -1, errno = 22, Invalid argument } MaliHwCntrReader::triggerCounterRead() { ioctl(hwcntReaderFd = 5, KBASE_HWCNT_READER_DUMP) : rcode = -1, errno = 22, Invalid argument } MaliHwCntrReader::triggerCounterRead() { ioctl(hwcntReaderFd = 5, KBASE_HWCNT_READER_DUMP) : rcode = -1, errno = 22, Invalid argument } MaliHwCntrReader::triggerCounterRead() { ioctl(hwcntReaderFd = 5, KBASE_HWCNT_READER_DUMP) : rcode = -1, errno = 22, Invalid argument } MaliHwCntrReader::triggerCounterRead() { ioctl(hwcntReaderFd = 5, KBASE_HWCNT_READER_DUMP) : rcode = -1, errno = 22, Invalid argument } MaliHwCntrReader::triggerCounterRead() { ioctl(hwcntReaderFd = 5, KBASE_HWCNT_READER_DUMP) : rcode = -1, errno = 22, Invalid argument } MaliHwCntrReader::triggerCounterRead() { ioctl(hwcntReaderFd = 5, KBASE_HWCNT_READER_DUMP) : rcode = -1, errno = 22, Invalid argument } MaliHwCntrReader::triggerCounterRead() { ioctl(hwcntReaderFd = 5, KBASE_HWCNT_READER_DUMP) : rcode = -1, errno = 22, Invalid argument } } } // probeMMUCount(device = 0xf4f24290) MaliHwCntrReader::create(device = 0xf4f24290, mmul2count = 0, jm = ffffffff, shader = ffffffff, tilter = ffffffff, mmuL2 = ffffffff) { MaliHwCntrReader::MaliHwCntrReader(device = 0xf4f24290, mmul2count = 0, buffercount = 1, jmBM = ffffffff, shaderBM = ffffffff, tilerBM = ffffffff, mmuL2BM = ffffffff) { device file path = / dev / mali0 MaliHwCntrReader : ABI version : 10.6 KBASE_FUNC_SET_FLAGS : OK KBASE_FUNC_HWCNT_READER_SETUP : hwcntReaderFd = 5 KBASE_HWCNT_READER_GET_API_VERSION : api_version = 1 KBASE_HWCNT_READER_GET_BUFFER_SIZE : sampleBufferSize = 6144 KBASE_HWCNT_READER_GET_HWVER : hardwareVersion = 5 MaliHwCntrReader : Hardware version 5 detected, but mmuL2BlockCount = 0 } MaliHwCntrReader: created reader, with buffer size of 1. but does not initialized. } // MaliHwCntrReader::create(device=0xf4f24290,mmul2count=0,jm=ffffffff,shader=ffffffff,tilter=ffffffff,mmuL2=ffffffff) } // [MaliHwCntrReader::create(device = 0xf4f24290)
Hi changmin,
Could you please try to modify probeBlockMaskCount function to default to returning 1 instead of 0 and see if that fixes the issue?
Also, what Streamline / gator version are you using? What Android version are you running on your S6?
Regards,
Jacek
