rk3399 with GPU : ARM Mali-T860 MP4 DS-5 (V 6.3.0) Ultimate Edition and I try on a linux host.
Here is my setting:
menuconfig options (depending on the kernel version, the location of these configuration settings within menuconfig may differ)
(#) The "Trace process context switches and events" is not the only option that enables tracing (CONFIG_GENERIC_TRACER or CONFIG_TRACING as well as CONFIG_CONTEXT_SWITCH_TRACER) and may not be visible in menuconfig as an option if other trace configurations are enabled. Other trace configurations being enabled is sufficient to turn on tracing.
And Here is my steps:
firstly:compile the kernel (Android with the linux kernel : Linux version 4.4.52 (gcc version 4.9 20150123 (prerelease) (GCC) ) #154 SMP PREEMPT)
make ARCH=arm64 x3399_defconfig
modify the generated .config file according to the config above
make -j32 ARCH=arm64 Image
make -j32 ARCH=arm64 x3399-development-board.img
then generate the kernel.img and resource.img, the kernel src and compile steps are from the RK3399 supplier
secondly:compile the gator daemon
modify the file Application.mk
mv daemon jni
nkd-build
the generate the file gatord
thirdly:compile the gator driver with the kernel src and the same kernel config
make -C <kernel_build_dir> M=`pwd` ARCH=arm64 CROSS_COMPILE=<...> modules GATOR_WITH_MALI_SUPPORT=MALI_MIDGARD MALI_DIR_MIDGARD="……/drivers/gpu/arm/midgard"
if I try to use DDK_DIR instead of MALI_DIR_MIDGARD, it give compiling error:gator/driver/gator_trace_gpu.c:22:36: fatal error: linux/mali_linux_trace.h: No such file or directory
so I use MALI_DIR_MIDGARD in compiling and generate the file gator.ko
last:start gatord
replace the kernel with newly generated kernel.img in the RK3399
adb push gatord /data/local/tmp/
adb shell chmod +x /data/local/tmp/gatord
adb push gator.ko /data/local/tmp/
then adb shell and get the root Authority, and start the gatord as : ./gatord &, it gives message:
and I can not get the GPU counter as follows:
Hi DwyaneTalk@126.com,
I have moved your question to the graphics and multimedia community as I feel that a member of this community would be able to answer your question.
Ryan
The two images of the error logs you get are unreadable - can you upload a higher resolution picture or just cut and paste the text of the error you are getting?
I think the error about GPU frequency being unavailable is not relevant for the rest of the counters; the frequency counter is optional and provided by the platform integrator (the clock tree is outside of the GPU), but the rest are native to the GPU hardware.
Thanks, Pete
Hi Peter,
Thanks for your reply, the clear pictures are here : https://community.arm.com/cn/f/discussions/8922/gpu-frequency-counters-not-avaliable
It confuse me that you said "the frequency counter is optional and provided by the platform integrator (the clock tree is outside of the GPU), but the rest are native to the GPU hardware."
I have no much experience on ARM and GPU
