Mali Offline Compiler v5.7 results
Hi  all:
I got the following result by compiling a opencl program. I do not know what is "work registers" and "uniform registers". Mali T600 a register bank that contains 1024 registers. Are the 1024 registers the sum of  "wor resigters" and "uniform registers" ?
Thank you
-Jack
ARM Mali Offline Compiler v5.7.0
(C) Copyright 2007-2017 ARM Limited.
All rights reserved.
7 work registers used, 5 uniform registers used, spilling not used.
                        A       L/S     T       Bound
Instructions Emitted:   20      10      2       A
Shortest Path Cycles:   2       2       0       A, L/S
Longest Path Cycles:    N/A     N/A     N/A     N/A
A = Arithmetic, L/S = Load/Store, T = Texture
Note: The cycles counts do not include possible stalls due to cache misses.
Note: Shaders with loops may return "N/A" for cycle counts if the number of cycles cannot be statically determined.
