I am trying to use Huawei Mate9 to test ARM compute library, since it has been mentioned in the blog. However, I cannot run any OpenCL apps. I was wondering if OpenCL is really supported on Huawei Mate9. Do I need to modify the configuration to enable OpenCL on Mate9?
Best,
Wayne
What program did you try to execute and what error message did you receive ?
I tried OpenCL Z installed from google play. i saw one error message: DTS is not allowed for Package in logca. But I am not sure if this is the issue.
best,
I don't think this is the right message. Is OpenCL Z itself displaying an error message on the UI ?
If you have access to your phone's system, you might want to take a look at either :
/system/vendor/lib/system/vendor/lib64
/system/vendor/lib
And see if there's any libOpenCL.so in this directory ?
OpenCL-Z is saying that the possible reasons are:
1) The device may not support OpenCL.
2) The OpenCL driver library was not found on the device.
But I do see libOpenCL.so in above folders.
Strange... I'll see if I can create a small OpenCL example using the Android NDK.
Thank you for taking the time to discuss this topic. Can you explain me somebody because on my Huawei P10 Plus flash player do not work only html5. I entered on this site aquí and tells me that I need to install Adobe Flash Player. I install it but nothing. Can you help me someone. Thanks so much!
