Understanding Mali GPU Hardware Counters
Hi ,
I have read your blog on Mali GPU Hardware Counters. I have a few questions.
The Mali Job Manager Cycles:GPU cycles counter gives the total amount of cycles, the GPU was active. If I execute a compute workload (not graphics), I should be able to predict the execution time of the kernel should be from Tripipe cycles counter.  There is always a differnce in value  between the Mali Job Manager Cycles:GPU cycles and Mali Core Cycles:Tripipe cycles. What does this extra cycles signify. I know that the values reported by streamline is average value across all the shader cores but still what does this extra cycles signify?
I also would like to know what exactly does the  Mali Core Cycles:Compute cycles and Mali Compute Threads:Compute cycles awaiting descriptors counters report ??.
This is because I ran a OpenCL benchamark with zero arithmetic instructions but still the values of Mali Core Cycles:Compute cycles and Mali Compute Threads:Compute cycles awaiting descriptors  are not zero while Mali Compute Threads:Compute tasks and Mali Compute Threads:Compute threads started were zero.
Also the tripipe cycles counter value should be equal to the maximum of cycles spent in Arithmetic/LS-pipeline/Texture pipeline but even when there are no texture and Arithmetic instructions, the value of Mali Core Cycles:Tripipe cycles is not the same as Mali Load/Store Pipe:LS instruction issues counter. Why this is happening? If I am executing only memory instructions, Mali Core Cycles:Tripipe cycles should be equal to Mali Load/Store Pipe cycles instead I see that  Mali Core Cycles:Compute cycles , Mali Compute Threads:Compute cycles awaiting descriptors and  Mali Core Cycles:Tripipe cycles have similar values??
It would be helpful if you can give some insights to these behaviours?
P.S. I am doing an academic project and i am modeling the performance of opencl kernel on Mali GPUs.
P.P.S.I am not an android developer looking at optimizations
