Why I only have limited GPU counters from streamline
I would like to use steamline DS5 to collect GPU information from odroid XU4. however :
many  GPU counters are missing.
I used this kernel source :GitHub - hardkernel/linux at odroidc-3.10.y . It is version Linux odroid 3.10.103. My DS5 version is DS-5 CE_5.25.0.
I have enabled all the configurations required:
- General Setup
  - Kernel Performance Events And Counters
    - [*] Kernel performance events and counters (enables CONFIG_PERF_EVENTS)
  - [*] Profiling Support (enables CONFIG_PROFILING)
- [*] Enable loadable module support (enables CONFIG_MODULES, needed unless the gator driver is built into the kernel)
  - [*] Module unloading (enables MODULE_UNLOAD)
- Kernel Features
  - [*] High Resolution Timer Support (enables CONFIG_HIGH_RES_TIMERS)
  - [*] Use local timer interrupts (only required for SMP and for version before Linux 3.12, enables CONFIG_LOCAL_TIMERS)
  - [*] Enable hardware performance counter support for perf events (enables CONFIG_HW_PERF_EVENTS)
- CPU Power Management
  - CPU Frequency scaling
    - [*] CPU Frequency scaling (enables CONFIG_CPU_FREQ)
- Device Drivers
  - Graphics support
    - ARM GPU Configuration
      - Mali Midgard series support
        - [*] Streamline Debug support (enables CONFIG_MALI_GATOR_SUPPORT needed as part of Mali Midgard support)
- Kernel hacking
  - [*] Compile the kernel with debug info (optional, enables CONFIG_DEBUG_INFO)
  - [*] Tracers
    - [*] Trace process context switches and events (#)
The kernel space gator is compiled and inserted.
What is wrong?
