Are the Vulkan drivers compatible with Mali-T764 GPU ?
Greetings,
I'm currently looking for a cheap Vulkan-compatible development board with a Mali GPU, that is compatible with mainline kernels.
The best I've currently found uses a Mali-T764. The Mali Vulkan drivers webpage stipulates that the drivers are compatible with Mali-T760 GPU.
Are the drivers also compatible with Mali-T764 GPU ? Or is that GPU completely different and has, currently, no Vulkan drivers ?
