FATAL - GLES: (checkMissingVersions 2455) Couldn't find symbol 'glUniformSubroutinesuiv' in 'libGL.so.1' (required for version of GL)!
FATAL - GLES: (checkMissingVersions 2455) Couldn't find symbol 'glProgramUniformMatrix2dv' in 'libGL.so.1' (required for version of GL)!
FATAL - GLES: (checkMissingVersions 2455) Couldn't find symbol 'glUniform3d' in 'libGL.so.1' (required for version of GL)!
FATAL - GLES: (checkMissingVersions 2455) Couldn't find symbol 'glProgramUniformMatrix3x2dv' in 'libGL.so.1' (required for version of GL)!
FATAL - GLES: (checkMissingVersions 2455) Couldn't find symbol 'glProgramUniform3f' in 'libGL.so.1' (required for version of GL)!
FATAL - GLES: (checkMissingVersions 2455) Couldn't find symbol 'glVertexAttribL3d' in 'libGL.so.1' (required for version of GL)!
FATAL - GLES: (checkMissingVersions 2455) Couldn't find symbol 'glDeleteProgramPipelines' in 'libGL.so.1' (required for version of GL)!
FATAL - GLES: (checkMissingVersions 2455) Couldn't find symbol 'glGetProgramResourceiv' in 'libGL.so.1' (required for version of GL)!
GL renderer: [Mesa DRI Intel(R) HD Graphics 5500 (Broadwell GT2) ]
GL vendor:[Intel Open Source Technology Center]
GL version: [3.0 Mesa 11.2.0]
GL shading language version: [1.30]
FATAL - GL33Backend: (bindGLTextureToTargetAndTextureUnit 1369) Could not bind texture. This should never happen. Catastrophic GLES-GL desynchronisation is about to occur. GLError = 0x0500
FATAL - Exception thrown in egl::IApi::eglMakeCurrent -> Underlying OpenGL error in GL33Backend. See Fatal error logs for full details. This is probably a programming error, so please report it
FATAL - Exception thrown in GLES32Api::glGetString -> Underlying OpenGL error in GL33Backend. See Fatal error logs for full details. This is probably a programming error, so please report it
glGetError() = 1280 at line 78 of main.cpp
Press enter to continue...
it is run with OpenGL ES Emuloator v3.0.1 on Ubuntu 16.04
so many error
How do I fix it?
Hi kyungsoo,
The minimum requirements for the Emulator to work on your host machine is Open GL 4.3, as mentioned in the guide.
OpenGL ES Emulator - Mali Developer Center
According to your output above, your GPU driver supports up to Open GL 3.0.
This is the reason why it is failing.
Please try update your GPU driver to the latest official Intel drivers, and try again.
Please also look into whether this GPU does in fact support at least Open GL 4.3, if it does not, then you will need to upgrade your GPU.
Kind Regards,
Michael McGeagh
