how can i use maliTextureCompressTool compress lots of png automatically? thanks
  • Hi
    This feature is supported by default in TCT. To compress multiple images in batch, simply open all the images you want to compress (you can select multiple images in the open dialog). The list of images on the left of the display will be filled. To compress them all, select then all using "Control-A" (or equivalent on OSX if using a Mac), or you can select as many as you prefer using "shift-click" or "control-click" commands. Once you are happy with your selection use the compression command as usual. All of the images you have selected will be compressed.
    Regards
    Ben
  • Hi
    Regards
    Ben
