ARM MALI400 GPU VP and PP are not working parallel. Why ?
Dear ARM Team,
We are working on Mali400-MP2 HW and  MALI DDK version r5p0-01rel0.
We are seeing almost all our applications are running serially one after other for CPU, GPU-VP, GPU-FP.
I attached one of our application performance chart captured using the ARM DS-5 streamline tool.
Questions:
  1. Why our applications are not able to process parallel on GPU-VP and GPU-VP, what are we missing in our Graphics solution ?
  2. How can we write an application which makes more efficient use of the CPU and GPU (GPU-VP, GPU-FP).
  3. Do you have any guidelines to achieve better parallelism and performance ?
  4. Can we get an example application which was written to get more advantage of Mali400 GPU ?
Please help me on this.
Thanks,
Ravinder Are
  • Why our applications are not able to process parallel on GPU-VP and GPU-VP, what are we missing in our Graphics solution ?
    Guessing slightly without seeing what your API sequence is looking like, but at a guess it looks like you are breaking the pipeline by enforcing some point of serialization in the GL behaviour. Do you have a glFinish() or a glReadPixels() anywhere in your per-frame rendering sequence? If you do please remove them. If you can explain why you have them we can hopefully provide some alternative.
    Cheers,
    Pete
  • Hi Ravinder,
    I think the developer guides at Developer Guides - Mali Developer Center should help you out.
    The Mali GLES SDK contains many sample applications which should help you out SDKs - Mali Developer Center
    Hth,
    Chris
