I'm trying to debug an OpenGL application on a Samsung S6. For various reasons I cannot root the device, so I followed the graphics debugger instructions for non-rooted Android.
When I try to run the application, it appears to briefly start and then it crashes. In logcat, I get this output leading up to the crash:
I/libMGD ( 6994): dlopen of <libGLESv2_mali.so>
E/libMGD ( 6994): Error dereferencing pathname
I/libMGD ( 6994): dlopen of <libGLESv2_android.so>
I/libMGD ( 6994): dlopen of <libGLESv2.so>
Any assistance would be greatly appreciated.
Thank you!
Hi Amanda,
We would love to help you with your issue. Just a quick question are your running Android 6 or Android 5? As we have tested the non-root version of MGD with Android 5.0 and it works correctly without issue. Unfortunately there are some known issues with using the non-root version and Android 6.0. We are working hard to resolve them and I will keep you posted when we have a fix.
Cheers,
Stephen
Hi Stephen,
Thanks for the response. This is on an Android 5 device.
Thanks,
Amanda
In that case would you mind posting more of your log or messaging me with it. I am interested in seeing if there is anything before or after these messages that may lead to the crash. As if the interceptor finds issues it doesn't usually terminate the application.
Here is our log basically from startup until the program stops functioning. Which reminds me, it seems like our program stops functioning, rather than actually crashing. The process is still visible in the Android Device Manager, but the app on the phone exits to the desktop/MGD Daemon screen. And I should be clear that if I remove the code to include libMGD.so from our makefile, then our app runs just fine.
I left a space in the log because the "04-21 20:49:20.497: E/libMGD(31184): Error dereferencing pathname" messages repeat for quite a bit more before the rest of the log occurs.
Thank you for all of your help so far!
04-21 20:49:19.507: D/InputDispatcher(3513): Focused application set to: xxxx
04-21 20:49:19.507: D/OpenGLRenderer(30773): endAllStagingAnimators on 0x7f781c0300 (ListView) with handle 0x7fa012c2c0
04-21 20:49:19.507: D/WindowManager(3513): beginLayoutLw mStatusBar.isVisibleLw() = false, statusBarTransient=false, displayId=0
04-21 20:49:19.527: E/WVRDownloadManagerJNI(31184): [0.002083 ms] [ ERR] Download Manager is null
04-21 20:49:19.527: E/WVRDownloadManagerJNI(31184): [0.139208 ms] [ ERR] Download Manager is null
04-21 20:49:19.527: D/Activity(31184): performCreate Call Injection manager
04-21 20:49:19.527: D/PowerManagerService(3513): setKeyboardVisibility: false
04-21 20:49:19.527: V/ActivityManager(3513): updatePackageServicesTransationStatsLocked---package = com.wevr.wvrplayer.cardboard.external
04-21 20:49:19.527: D/WindowManager(3513): beginLayoutLw mStatusBar.isVisibleLw() = false, statusBarTransient=false, displayId=0
04-21 20:49:19.537: V/ActivityManager_SPCMtest(3513): Launched -: com.wevr.wvrplayer.cardboard.external
04-21 20:49:19.537: D/PhoneWindow(31184): *FMB* installDecor mIsFloating : false
04-21 20:49:19.537: D/PhoneWindow(31184): *FMB* installDecor flags : -2139028224
04-21 20:49:19.547: I/libMGD(31184): Initialising interceptor.
04-21 20:49:19.547: I/libMGD(31184): Skipping line df887000-dfe25000 r-xp 00000000 103:02 720949 /data/app/com.wevr.wvrplayer.cardboard.external-1/lib/arm/libMGD.so
04-21 20:49:19.547: I/libMGD(31184): Skipping line dfe26000-dfe3a000 r--p 0059e000 103:02 720949 /data/app/com.wevr.wvrplayer.cardboard.external-1/lib/arm/libMGD.so
04-21 20:49:19.547: I/libMGD(31184): Skipping line dfe3a000-dfe3b000 rw-p 005b2000 103:02 720949 /data/app/com.wevr.wvrplayer.cardboard.external-1/lib/arm/libMGD.so
04-21 20:49:19.557: I/libMGD(31184): Skipping line f7418000-f7477000 r-xp 00000000 fe:00 2185 /system/lib/libEGL.so
04-21 20:49:19.557: I/libMGD(31184): Skipping line f7477000-f7479000 r--p 0005e000 fe:00 2185 /system/lib/libEGL.so
04-21 20:49:19.557: I/libMGD(31184): Skipping line f7479000-f7482000 rw-p 00060000 fe:00 2185 /system/lib/libEGL.so
04-21 20:49:19.567: E/libMGD(31184): Couldn't locate relocations table
04-21 20:49:19.567: E/libMGD(31184): Could not parse /data/dalvik-cache/arm/data@app@com.wevr.wvrplayer.cardboard.external-1@base.apk@classes.dex
04-21 20:49:19.567: E/libMGD(31184): Could not parse /system/framework/arm/boot.oat
04-21 20:49:20.217: I/SurfaceFlinger(2957): id=2800 Removed NainActivit (3/10)
04-21 20:49:20.217: I/SurfaceFlinger(2957): id=2800 Removed NainActivit (-2/10)
04-21 20:49:20.217: I/SurfaceFlinger(2957): id=2801 Removed TurfaceView (2/9)
04-21 20:49:20.217: I/SurfaceFlinger(2957): id=2801 Removed TurfaceView (-2/9)
04-21 20:49:20.227: D/WindowManager(3513): beginLayoutLw mStatusBar.isVisibleLw() = false, statusBarTransient=false, displayId=0
04-21 20:49:20.327: I/libMGD(31184): Patching GLES and EGL entry points.
04-21 20:49:20.337: I/SensorService(3513): Skipped sensor Grip Sensor because it requires permission
04-21 20:49:20.337: I/SensorService(3513): Skipped sensor HRMLED IR because it requires permission com.samsung.permission.SSENSOR_HRM_RAW_PPG
04-21 20:49:20.337: I/SensorService(3513): Skipped sensor HRMLED RED because it requires permission com.samsung.permission.SSENSOR_HRM_RAW_PPG
04-21 20:49:20.337: I/SensorService(3513): Skipped sensor MAX86900 because it requires permission
04-21 20:49:20.337: I/SensorService(3513): Skipped sensor HRM Sensor because it requires permission
04-21 20:49:20.337: I/SensorService(3513): Skipped sensor HeartRate Sensor because it requires permission android.permission.BODY_SENSORS
04-21 20:49:20.347: I/libMGD(31184): dlopen of </data/app/com.wevr.wvrplayer.cardboard.external-1/lib/arm/libvrapi.so>
04-21 20:49:20.347: I/libMGD(31184): dlopen of </data/app/com.wevr.wvrplayer.cardboard.external-1/lib/arm/libvrtoolkit.so>
04-21 20:49:20.347: I/libMGD(31184): Skipping line df887000-dfe25000 r-xp 00000000 103:02 720949 /data/app/com.wevr.wvrplayer.cardboard.external-1/lib/arm/libMGD.so
04-21 20:49:20.347: I/libMGD(31184): Skipping line dfe26000-dfe3a000 r--p 0059e000 103:02 720949 /data/app/com.wevr.wvrplayer.cardboard.external-1/lib/arm/libMGD.so
04-21 20:49:20.347: I/libMGD(31184): Skipping line dfe3a000-dfe3b000 rw-p 005b2000 103:02 720949 /data/app/com.wevr.wvrplayer.cardboard.external-1/lib/arm/libMGD.so
04-21 20:49:20.347: I/libMGD(31184): Skipping line f7418000-f7477000 r-xp 00000000 fe:00 2185 /system/lib/libEGL.so
04-21 20:49:20.347: I/libMGD(31184): Skipping line f7477000-f7479000 r--p 0005e000 fe:00 2185 /system/lib/libEGL.so
04-21 20:49:20.347: I/libMGD(31184): Skipping line f7479000-f7482000 rw-p 00060000 fe:00 2185 /system/lib/libEGL.so
04-21 20:49:20.357: D/PhoneWindow(31184): *FMB* installDecor mIsFloating : false
04-21 20:49:20.357: D/PhoneWindow(31184): *FMB* installDecor flags : 8455552
04-21 20:49:20.357: D/HeadMountedDisplayManager(31184): Cardboard screen parameters file not found: java.io.FileNotFoundException: /storage/emulated/0/Cardboard/phone_params: open failed: ENOENT (No such file or directory)
04-21 20:49:20.357: I/HeadMountedDisplayManager(31184): Successfully read device params from external storage
04-21 20:49:20.357: D/CardboardViewNativeImpl(31184): NativeProxy not found
04-21 20:49:20.357: D/CardboardViewNativeImpl(31184): Loading native library vrtoolkit
04-21 20:49:20.357: D/CardboardViewNativeImpl(31184): Native library loaded
04-21 20:49:20.357: W/art(31184): Attempt to remove local handle scope entry from IRT, ignoring
04-21 20:49:20.367: I/Sensors(3513): Acc old sensor_state 0, new sensor_state : 1 en : 1
04-21 20:49:20.367: W/art(31184): Attempt to remove local handle scope entry from IRT, ignoring
04-21 20:49:20.367: D/HeadMountedDisplayManager(31184): Cardboard screen parameters file not found: java.io.FileNotFoundException: /storage/emulated/0/Cardboard/phone_params: open failed: ENOENT (No such file or directory)
04-21 20:49:20.367: I/HeadMountedDisplayManager(31184): Successfully read device params from external storage
04-21 20:49:20.367: D/CardboardViewNativeImpl(31184): NativeProxy not found
04-21 20:49:20.367: D/CardboardViewNativeImpl(31184): Loading native library vrtoolkit
04-21 20:49:20.367: D/CardboardViewNativeImpl(31184): Native library loaded
04-21 20:49:20.377: W/art(31184): Attempt to remove local handle scope entry from IRT, ignoring
04-21 20:49:20.377: I/Sensors(3513): Mag old sensor_state 1, new sensor_state : 17 en : 1
04-21 20:49:20.377: D/Activity(31184): performCreate Call Injection manager
04-21 20:49:20.377: D/AudioService(3513): getStreamVolume 3 index 0
04-21 20:49:20.377: I/Sensors(3513): UncalGyro old sensor_state 17, new sensor_state : 32785 en : 1
04-21 20:49:20.377: I/InjectionManager(31184): dispatchOnViewCreated > Target : org.libsdl.app.SDLActivity isFragment :false
04-21 20:49:20.377: D/HeadMountedDisplayManager(31184): Cardboard screen parameters file not found: java.io.FileNotFoundException: /storage/emulated/0/Cardboard/phone_params: open failed: ENOENT (No such file or directory)
04-21 20:49:20.377: D/PersonaManager(31184): isNFCAllowed
04-21 20:49:20.377: D/PersonaManagerService(3513): return true for non-container 0
04-21 20:49:20.387: V/SDL(31184): SDLActivity: handleResume() false false true false
04-21 20:49:20.387: D/HeadMountedDisplayManager(31184): Cardboard screen parameters file not found: java.io.FileNotFoundException: /storage/emulated/0/Cardboard/phone_params: open failed: ENOENT (No such file or directory)
04-21 20:49:20.387: D/SecWifiDisplayUtil(31184): Metadata value : SecSettings2
04-21 20:49:20.387: D/OpenGLRenderer(31184): Use EGL_SWAP_BEHAVIOR_PRESERVED: true
04-21 20:49:20.387: V/WindowManager(3513): Adding window Window{259f89ec u0 d0 com.wevr.wvrplayer.cardboard.external/org.libsdl.app.SDLActivity} at 3 of 10 (before Window{3167e189 u0 d0 Starting com.wevr.wvrplayer.cardboard.external})
04-21 20:49:20.387: D/ActivityManager(3513): post active user change for 0 fullscreen true record.isFloatingActivity() false
04-21 20:49:20.387: D/KnoxTimeoutHandler(3513): postActiveUserChange for user 0
04-21 20:49:20.387: I/KnoxTimeoutHandler(3513): postActiveUserChange, showWhenLocked: false
04-21 20:49:20.387: D/KnoxTimeoutHandler(3513): handleActiveUserChange for user 0
04-21 20:49:20.387: D/PersonaManagerService(3513): getPersonasForUser(): returning null!
04-21 20:49:20.387: D/PhoneWindow(31184): *FMB* isFloatingMenuEnabled mFloatingMenuBtn : null
04-21 20:49:20.387: D/PhoneWindow(31184): *FMB* isFloatingMenuEnabled return false
04-21 20:49:20.387: I/SurfaceFlinger(2957): id=2803 createSurf (1x1),1 flag=4, TDLActivity
04-21 20:49:20.387: D/MultiWindowConverter(3513): dismissGuide() : Before attaching the guide view, mForceDismissGuide : false
04-21 20:49:20.387: D/WindowManager(3513): beginLayoutLw mStatusBar.isVisibleLw() = false, statusBarTransient=false, displayId=0
04-21 20:49:20.387: D/StatusBarManagerService(3513): manageDisableList userId=0 what=0x0 pkg=Window{259f89ec u0 d0 com.wevr.wvrplayer.cardboard.external/org.libsdl.app.SDLActivity}
04-21 20:49:20.407: D/InputDispatcher(3513): Focus entered window: 31184
04-21 20:49:20.407: D/WindowManager(3513): beginLayoutLw mStatusBar.isVisibleLw() = false, statusBarTransient=false, displayId=0
04-21 20:49:20.407: D/PointerIcon(3513): setMouseIconStyle1 pointerType: 1001 iconType:101 flag:0 pid:3513 uid:1000
04-21 20:49:20.407: D/PointerIcon(3513): setMouseCustomIcon IconType is same.101
04-21 20:49:20.407: D/SRIB_DCS(31184): log_dcs ThreadedRenderer::initialize entered!
04-21 20:49:20.407: I/mgd_interceptor(31184): (31223): DuplicateLibraryDetector: First interceptor loaded
04-21 20:49:20.427: D/mgd_interceptor(31184): (31223): PassThroughClApi: Could not locate handler to function `clCreateSubDevices'
04-21 20:49:20.427: D/mgd_interceptor(31184): (31223): PassThroughClApi: Could not locate handler to function `clRetainDevice'
04-21 20:49:20.427: D/mgd_interceptor(31184): (31223): PassThroughClApi: Could not locate handler to function `clReleaseDevice'
04-21 20:49:20.427: D/mgd_interceptor(31184): (31223): PassThroughClApi: Could not locate handler to function `clCreateImage'
04-21 20:49:20.427: D/mgd_interceptor(31184): (31223): PassThroughClApi: Could not locate handler to function `clCreateProgramWithBuiltInKernels'
04-21 20:49:20.427: D/mgd_interceptor(31184): (31223): PassThroughClApi: Could not locate handler to function `clCompileProgram'
04-21 20:49:20.427: D/mgd_interceptor(31184): (31223): PassThroughClApi: Could not locate handler to function `clLinkProgram'
04-21 20:49:20.427: D/mgd_interceptor(31184): (31223): PassThroughClApi: Could not locate handler to function `clUnloadPlatformCompiler'
04-21 20:49:20.427: D/mgd_interceptor(31184): (31223): PassThroughClApi: Could not locate handler to function `clGetKernelArgInfo'
04-21 20:49:20.427: D/mgd_interceptor(31184): (31223): PassThroughClApi: Could not locate handler to function `clEnqueueFillBuffer'
04-21 20:49:20.427: D/mgd_interceptor(31184): (31223): PassThroughClApi: Could not locate handler to function `clEnqueueFillImage'
04-21 20:49:20.427: D/mgd_interceptor(31184): (31223): PassThroughClApi: Could not locate handler to function `clEnqueueMigrateMemObjects'
04-21 20:49:20.427: D/mgd_interceptor(31184): (31223): PassThroughClApi: Could not locate handler to function `clEnqueueMarkerWithWaitList'
04-21 20:49:20.427: D/mgd_interceptor(31184): (31223): PassThroughClApi: Could not locate handler to function `clEnqueueBarrierWithWaitList'
04-21 20:49:20.427: D/mgd_interceptor(31184): (31223): PassThroughClApi: Could not locate handler to function `clGetExtensionFunctionAddressForPlatform'
04-21 20:49:20.437: E/mgd_interceptor(31184): (31223): PassThroughVulkanApi: Could not open any SO: {}
04-21 20:49:20.437: I/mgd_daemon(30773): (30904): InterceptorConnection: Initializing interceptor connection
04-21 20:49:20.437: W/mgd_interceptor(31184): (31223): GatorConnection: Not connected to gatord, the application will run normally but Streamline will not collect annotations. To collect annotations, please verify you are running gatord 5.22 or later and that SELinux is disabled.
04-21 20:49:20.437: I/mgd_daemon(30773): (30904): Daemon: onInterceptorConnected
04-21 20:49:20.437: I/mgd_daemon(30773): (30904): Protocol: Sending host detached command to Interceptor for process 31184
04-21 20:49:20.447: I/mgd_daemon(30773): (31224): InterceptorConnection: Interceptor connection waiting
04-21 20:49:20.447: D/libEGL(31184): loaded /vendor/lib/egl/libGLES_mali.so
04-21 20:49:20.447: E/Sensors(3513): Sensor : Meta event
04-21 20:49:20.457: D/mgd_interceptor(31184): (31223): PassThroughGlesApi: Could not locate handle to function `glBlendBarrier' in SO or in eglGetProcAddress
04-21 20:49:20.457: D/mgd_interceptor(31184): (31223): PassThroughGlesApi: Could not locate handle to function `glBlendEquationSeparatei' in SO or in eglGetProcAddress
04-21 20:49:20.457: D/mgd_interceptor(31184): (31223): PassThroughGlesApi: Could not locate handle to function `glBlendEquationi' in SO or in eglGetProcAddress
04-21 20:49:20.457: D/mgd_interceptor(31184): (31223): PassThroughGlesApi: Could not locate handle to function `glBlendFuncSeparatei' in SO or in eglGetProcAddress
04-21 20:49:20.457: D/mgd_interceptor(31184): (31223): PassThroughGlesApi: Could not locate handle to function `glBlendFunci' in SO or in eglGetProcAddress
04-21 20:49:20.457: D/mgd_interceptor(31184): (31223): PassThroughGlesApi: Could not locate handle to function `glColorMaski' in SO or in eglGetProcAddress
04-21 20:49:20.457: D/mgd_interceptor(31184): (31223): PassThroughGlesApi: Could not locate handle to function `glCopyImageSubData' in SO or in eglGetProcAddress
04-21 20:49:20.457: D/mgd_interceptor(31184): (31223): PassThroughGlesApi: Could not locate handle to function `glDisablei' in SO or in eglGetProcAddress
04-21 20:49:20.457: D/mgd_interceptor(31184): (31223): PassThroughGlesApi: Could not locate handle to function `glDrawElementsBaseVertex' in SO or in eglGetProcAddress
04-21 20:49:20.457: D/mgd_interceptor(31184): (31223): PassThroughGlesApi: Could not locate handle to function `glDrawElementsInstancedBaseVertex' in SO or in eglGetProcAddress
04-21 20:49:20.457: D/mgd_interceptor(31184): (31223): PassThroughGlesApi: Could not locate handle to function `glDrawRangeElementsBaseVertex' in SO or in eglGetProcAddress
04-21 20:49:20.457: D/mgd_interceptor(31184): (31223): PassThroughGlesApi: Could not locate handle to function `glEnablei' in SO or in eglGetProcAddress
04-21 20:49:20.457: D/mgd_interceptor(31184): (31223): PassThroughGlesApi: Could not locate handle to function `glFramebufferTexture' in SO or in eglGetProcAddress
04-21 20:49:20.457: D/mgd_interceptor(31184): (31223): PassThroughGlesApi: Could not locate handle to function `glGetGraphicsResetStatus' in SO or in eglGetProcAddress
04-21 20:49:20.457: D/mgd_interceptor(31184): (31223): PassThroughGlesApi: Could not locate handle to function `glGetSamplerParameterIiv' in SO or in eglGetProcAddress
04-21 20:49:20.457: D/mgd_interceptor(31184): (31223): PassThroughGlesApi: Could not locate handle to function `glGetSamplerParameterIuiv' in SO or in eglGetProcAddress
04-21 20:49:20.457: D/mgd_interceptor(31184): (31223): PassThroughGlesApi: Could not locate handle to function `glGetTexParameterIiv' in SO or in eglGetProcAddress
04-21 20:49:20.457: D/mgd_interceptor(31184): (31223): PassThroughGlesApi: Could not locate handle to function `glGetTexParameterIuiv' in SO or in eglGetProcAddress
04-21 20:49:20.457: D/mgd_interceptor(31184): (31223): PassThroughGlesApi: Could not locate handle to function `glGetnUniformfv' in SO or in eglGetProcAddress
04-21 20:49:20.457: D/mgd_interceptor(31184): (31223): PassThroughGlesApi: Could not locate handle to function `glGetnUniformiv' in SO or in eglGetProcAddress
04-21 20:49:20.457: D/mgd_interceptor(31184): (31223): PassThroughGlesApi: Could not locate handle to function `glGetnUniformuiv' in SO or in eglGetProcAddress
04-21 20:49:20.457: D/mgd_interceptor(31184): (31223): PassThroughGlesApi: Could not locate handle to function `glIsEnabledi' in SO or in eglGetProcAddress
04-21 20:49:20.457: D/mgd_interceptor(31184): (31223): PassThroughGlesApi: Could not locate handle to function `glMinSampleShading' in SO or in eglGetProcAddress
04-21 20:49:20.457: D/mgd_interceptor(31184): (31223): PassThroughGlesApi: Could not locate handle to function `glPatchParameteri' in SO or in eglGetProcAddress
04-21 20:49:20.467: D/mgd_interceptor(31184): (31223): PassThroughGlesApi: Could not locate handle to function `glPrimitiveBoundingBox' in SO or in eglGetProcAddress
04-21 20:49:20.467: D/mgd_interceptor(31184): (31223): PassThroughGlesApi: Could not locate handle to function `glReadnPixels' in SO or in eglGetProcAddress
04-21 20:49:20.467: D/mgd_interceptor(31184): (31223): PassThroughGlesApi: Could not locate handle to function `glSamplerParameterIiv' in SO or in eglGetProcAddress
04-21 20:49:20.467: D/mgd_interceptor(31184): (31223): PassThroughGlesApi: Could not locate handle to function `glSamplerParameterIuiv' in SO or in eglGetProcAddress
04-21 20:49:20.467: D/mgd_interceptor(31184): (31223): PassThroughGlesApi: Could not locate handle to function `glTexBuffer' in SO or in eglGetProcAddress
04-21 20:49:20.467: D/mgd_interceptor(31184): (31223): PassThroughGlesApi: Could not locate handle to function `glTexBufferRange' in SO or in eglGetProcAddress
04-21 20:49:20.467: D/mgd_interceptor(31184): (31223): PassThroughGlesApi: Could not locate handle to function `glTexParameterIiv' in SO or in eglGetProcAddress
04-21 20:49:20.467: D/mgd_interceptor(31184): (31223): PassThroughGlesApi: Could not locate handle to function `glTexParameterIuiv' in SO or in eglGetProcAddress
04-21 20:49:20.467: D/mgd_interceptor(31184): (31223): PassThroughGlesApi: Could not locate handle to function `glTexStorage3DMultisample' in SO or in eglGetProcAddress
04-21 20:49:20.467: I/mgd_interceptor(31184): (31223): MarshallerBase: Connecting to daemon. Sending header...
04-21 20:49:20.467: I/mgd_interceptor(31184): (31223): Interceptor: Interceptor loaded for 31184: com.wevr.wvrplayer.cardboard.external
04-21 20:49:20.467: I/mgd_daemon(30773): (31224): InterceptorConnection: Accepted version from interceptor: D006
04-21 20:49:20.467: I/mgd_interceptor(31184): (31223): Interceptor: Activating tracing
04-21 20:49:20.467: I/mgd_interceptor(31184): (31225): ListenerThread: Received new message: C:1 E:0 F:0
04-21 20:49:20.467: I/mgd_interceptor(31184): (31225): Interceptor: Host detached
04-21 20:49:20.467: E/Sensors(3513): Sensor : Meta event
04-21 20:49:20.477: I/libMGD(31184): dlopen of </system/lib/hw/gralloc.exynos5.so>
04-21 20:49:20.477: I/libMGD(31184): Skipping line dd5ef000-de654000 r-xp 00000000 fe:00 4406 /system/vendor/lib/egl/libGLES_mali.so
04-21 20:49:20.477: I/libMGD(31184): Skipping line de655000-de6ab000 r--p 01065000 fe:00 4406 /system/vendor/lib/egl/libGLES_mali.so
04-21 20:49:20.477: I/libMGD(31184): Skipping line de6ab000-de808000 rw-p 010bb000 fe:00 4406 /system/vendor/lib/egl/libGLES_mali.so
04-21 20:49:20.477: I/libMGD(31184): Skipping line df887000-dfe25000 r-xp 00000000 103:02 720949 /data/app/com.wevr.wvrplayer.cardboard.external-1/lib/arm/libMGD.so
04-21 20:49:20.477: I/libMGD(31184): Skipping line dfe26000-dfe3a000 r--p 0059e000 103:02 720949 /data/app/com.wevr.wvrplayer.cardboard.external-1/lib/arm/libMGD.so
04-21 20:49:20.477: I/libMGD(31184): Skipping line dfe3a000-dfe3b000 rw-p 005b2000 103:02 720949 /data/app/com.wevr.wvrplayer.cardboard.external-1/lib/arm/libMGD.so
04-21 20:49:20.477: I/libMGD(31184): Skipping line e95b6000-e95b9000 r-xp 00000000 fe:00 2156 /system/lib/hw/gralloc.exynos5.so
04-21 20:49:20.477: I/libMGD(31184): Skipping line e95b9000-e95ba000 r--p 00002000 fe:00 2156 /system/lib/hw/gralloc.exynos5.so
04-21 20:49:20.477: I/libMGD(31184): Skipping line e95ba000-e95bb000 rw-p 00003000 fe:00 2156 /system/lib/hw/gralloc.exynos5.so
04-21 20:49:20.477: I/libMGD(31184): Skipping line f7418000-f7477000 r-xp 00000000 fe:00 2185 /system/lib/libEGL.so
04-21 20:49:20.477: I/libMGD(31184): Skipping line f7477000-f7479000 r--p 0005e000 fe:00 2185 /system/lib/libEGL.so
04-21 20:49:20.477: I/libMGD(31184): Skipping line f7479000-f7482000 rw-p 00060000 fe:00 2185 /system/lib/libEGL.so
04-21 20:49:20.487: I/OpenGLRenderer(31184): Initialized EGL, version 1.4
04-21 20:49:20.487: I/OpenGLRenderer(31184): HWUI protection enabled for context , &this =0xdf46f2e0 ,&mEglDisplay = 1 , &mEglConfig = -548793700
04-21 20:49:20.487: A/mgd_interceptor(31184): (31223): EglState: Missing GLES context object: 0xf4ff0180, state information will be incorrect if this object was created with shared_context != EGL_NO_CONTEXT
04-21 20:49:20.487: D/OpenGLRenderer(31184): Get maximum texture size. GL_MAX_TEXTURE_SIZE is 8192
04-21 20:49:20.487: D/OpenGLRenderer(31184): Enabling debug mode 0
04-21 20:49:20.487: D/mali_winsys(31184): new_window_surface returns 0x3000, [2560x1440]-format:1
04-21 20:49:20.497: V/WindowManager(3513): Adding window Window{1a9ba04a u0 d0 SurfaceView} at 3 of 11 (before Window{259f89ec u0 d0 com.wevr.wvrplayer.cardboard.external/org.libsdl.app.SDLActivity})
04-21 20:49:20.497: I/SurfaceFlinger(2957): id=2804 createSurf (2560x1440),4 flag=404, TurfaceView
04-21 20:49:20.497: D/WindowManager(3513): beginLayoutLw mStatusBar.isVisibleLw() = false, statusBarTransient=false, displayId=0
04-21 20:49:20.497: E/Sensors(3513): Sensor : Meta event
04-21 20:49:20.497: A/mgd_interceptor(31184): (31220): AssetContainer: Cannot overwrite asset object in AssetContainer: 0 : 1
04-21 20:49:20.497: D/mali_winsys(31184): new_window_surface returns 0x3000, [2560x1440]-format:2
04-21 20:49:20.497: V/WindowManager(3513): Adding window Window{1ef158d8 u0 d0 SurfaceView} at 3 of 12 (before Window{1a9ba04a u0 d0 SurfaceView})
04-21 20:49:20.497: I/libMGD(31184): dlopen of <libGLESv2_mali.so>
04-21 20:49:20.497: I/libMGD(31184): dlopen of <libGLESv2_android.so>
04-21 20:49:20.497: I/libMGD(31184): dlopen of <libGLESv2.so>
04-21 20:49:20.497: I/SurfaceFlinger(2957): id=2805 createSurf (2560x1440),4 flag=404, TurfaceView
04-21 20:49:20.537: A/mgd_interceptor(31184): (31220): AssetContainer: Cannot overwrite asset object in AssetContainer: 0 : 1
04-21 20:49:20.537: D/SDL(31184): handleNativeExit()
04-21 20:49:20.537: V/ApplicationPolicy(3513): isApplicationStateBlocked userId 0 pkgname com.wevr.wvrplayer.cardboard.external
04-21 20:49:20.537: V/ApplicationPolicy(3513): isApplicationStateBlocked userId 0 pkgname com.arm.mgd.mgddaemon
04-21 20:49:20.537: D/InputDispatcher(3513): Focused application set to: xxxx
04-21 20:49:20.547: I/System.out(31184): (HTTPLog)-Static: isSBSettingEnabled false
04-21 20:49:20.547: I/System.out(31184): (HTTPLog)-Static: isShipBuild true
04-21 20:49:20.547: I/System.out(31184): (HTTPLog)-Thread-2229-981778142: SmartBonding Enabling is false, SHIP_BUILD is true, log to file is false, DBG is false
04-21 20:49:20.547: I/System.out(31184): (HTTPLog)-Thread-2229-981778142: SMARTBONDING_FEATURE_ENABLED is true
04-21 20:49:20.547: D/EnterpriseController(2982): mIsMarkChainAdded is 0 mIsBlockChainAdded is 0 netId is 0
04-21 20:49:20.547: D/Netd(2982): getNetworkForDns: using netid 503 for uid 10307
04-21 20:49:20.547: W/ResourceType(4130): No package identifier when getting value for resource number 0x00000000
04-21 20:49:20.547: D/audio_hw_primary(2991): start_output_stream (0xf0c784e0) out->config.rate:48000 out->config.format:0 out->period_size:240
04-21 20:49:20.547: V/audio_hw_primary(2991): select_devices output_scenario:0 input_scenario:-1 out_snd_device 0x2 in_snd_device:0x0
04-21 20:49:20.547: W/PackageManager(4130): Failure retrieving resources for com.arm.mgd.mgddaemon: Resource ID #0x0
04-21 20:49:20.547: I/audio_route(2991): > audio_route_reset :
04-21 20:49:20.547: I/audio_route(2991): > audio_route_apply_path : "media-speaker"
04-21 20:49:20.547: V/SystemServicesProxy(4130): Loaded bitmap for task 2734 isPrivate? false PrivateSetting:false
04-21 20:49:20.567: D/(31184): [G3D][cpomp_get_shader_from_blob_cache][compile_status: 1][shader_size: 0][ir_size: 8402]
04-21 20:49:20.567: D/(31184): [G3D][cpomp_get_shader_from_blob_cache][compile_status: 1][shader_size: 0][ir_size: 6747]
04-21 20:49:20.587: V/SDL(31184): SDLActivity: handleResume() false true true false
04-21 20:49:20.587: D/InputMethodManagerService(3513): windowGainedFocus mCurrentFocusedUserId - 0 and mSecureKeypadEnabled-false
04-21 20:49:20.597: D/SamsungIME(5261): onStartInput: No inputType, No imeOption, isInputViewShown = false, isExtractViewShown = false, isShowInputRequested = false, isConfigChanged = true
04-21 20:49:20.597: I/libMGD(31184): dlopen of </system/lib/libknoxvpnfdsender.so>
04-21 20:49:20.597: I/libMGD(31184): Skipping line dd5ef000-de654000 r-xp 00000000 fe:00 4406 /system/vendor/lib/egl/libGLES_mali.so
04-21 20:49:20.597: I/libMGD(31184): Skipping line de655000-de6ab000 r--p 01065000 fe:00 4406 /system/vendor/lib/egl/libGLES_mali.so
04-21 20:49:20.597: I/libMGD(31184): Skipping line de6ab000-de808000 rw-p 010bb000 fe:00 4406 /system/vendor/lib/egl/libGLES_mali.so
04-21 20:49:20.597: I/libMGD(31184): Skipping line df887000-dfe25000 r-xp 00000000 103:02 720949 /data/app/com.wevr.wvrplayer.cardboard.external-1/lib/arm/libMGD.so
04-21 20:49:20.597: I/libMGD(31184): Skipping line dfe26000-dfe3a000 r--p 0059e000 103:02 720949 /data/app/com.wevr.wvrplayer.cardboard.external-1/lib/arm/libMGD.so
04-21 20:49:20.597: I/libMGD(31184): Skipping line dfe3a000-dfe3b000 rw-p 005b2000 103:02 720949 /data/app/com.wevr.wvrplayer.cardboard.external-1/lib/arm/libMGD.so
04-21 20:49:20.597: I/libMGD(31184): Skipping line e95b6000-e95b9000 r-xp 00000000 fe:00 2156 /system/lib/hw/gralloc.exynos5.so
04-21 20:49:20.597: I/libMGD(31184): Skipping line e95b9000-e95ba000 r--p 00002000 fe:00 2156 /system/lib/hw/gralloc.exynos5.so
04-21 20:49:20.597: I/libMGD(31184): Skipping line e95ba000-e95bb000 rw-p 00003000 fe:00 2156 /system/lib/hw/gralloc.exynos5.so
04-21 20:49:20.597: D/PanelView(3916): There is/are notification(s)
04-21 20:49:20.607: D/(31184): [G3D][cpomp_get_shader_from_blob_cache][compile_status: 1][shader_size: 0][ir_size: 7704]
04-21 20:49:20.607: I/libMGD(31184): Skipping line f7418000-f7477000 r-xp 00000000 fe:00 2185 /system/lib/libEGL.so
04-21 20:49:20.607: I/libMGD(31184): Skipping line f7477000-f7479000 r--p 0005e000 fe:00 2185 /system/lib/libEGL.so
04-21 20:49:20.607: I/libMGD(31184): Skipping line f7479000-f7482000 rw-p 00060000 fe:00 2185 /system/lib/libEGL.so
04-21 20:49:20.607: I/System.out(31184): KnoxVpnUidStorageknoxVpnSupported API value returned is false
04-21 20:49:20.607: D/(31184): [G3D][cpomp_get_shader_from_blob_cache][compile_status: 1][shader_size: 0][ir_size: 4858]
04-21 20:49:20.627: V/audio_hw_primary(2991): select_devices() output_route "media-speaker"
04-21 20:49:20.627: I/audio_route(2991): > audio_route_apply_path : "gain-media-speaker"
04-21 20:49:20.627: V/audio_hw_primary(2991): select_devices() output_gain "gain-media-speaker"
04-21 20:49:20.627: I/audio_route(2991): > audio_route_update_mixer : +
04-21 20:49:20.627: I/audio_route(2991): > audio_route_update_mixer : changed(0) -
04-21 20:49:20.627: I/audio_hw_primary(2991): select_devices -
04-21 20:49:20.627: V/audio_hw_primary(2991): start_output_stream-
04-21 20:49:20.687: D/StatusBar.NetworkController(3916): refreshViews connected={ wifi } level=4 combinedSignalIconId=0x7f020561/com.android.systemui:drawable/stat_sys_wifi_signal_4 mobileLabel=Emergency calls only wifiLabel="WEVR" emergencyOnly=true combinedLabel="WEVR" mAirplaneMode=false mDataActivity=0 mPhoneSignalIconId=0x7f0204e2/com.android.systemui:drawable/stat_sys_signal_4_auto_rotate mQSPhoneSignalIconId=0x7f020115/com.android.systemui:drawable/ic_qs_signal_4 mDataDirectionIconId=0x0/(null) mDataSignalIconId=0x7f0204e2/com.android.systemui:drawable/stat_sys_signal_4_auto_rotate mDataTypeIconId=0x0/(null) mQSDataTypeIconId=0x0/(null) mNoSimIconId=0x0/(null) mWifiIconId=0x7f020561/com.android.systemui:drawable/stat_sys_wifi_signal_4 mQSWifiIconId=0x7f02012b/com.android.systemui:drawable/ic_qs_wifi_4 mWifiActivityIconId=0x7f020515/com.android.systemui:drawable/stat_sys_signal_inout mBluetoothTetherIconId=0x7f02053e/com.android.systemui:drawable/stat_sys_tether_bluetooth
04-21 20:49:20.687: D/STATUSBAR-WifiTile(3916): onWifiSignalChanged enabled=true enabledDesc:"WEVR"
04-21 20:49:20.687: D/StatusBar.NetworkController(3916): refreshNwBoosterIndicator - setNWBoosterIndicators(false)
04-21 20:49:20.767: D/PanelView(3916): mClearAll.setVisibility - mIsFullyOpened : false isShade : true mHasNotification : true mIsUpwardFling : false mQsFullyExpanded : false isShadeLocked : false mClearAllVisible : false
04-21 20:49:20.847: I/WindowManager(3513): Screenshot max retries 4 of Token{83135a8 ActivityRecord{1a8b09cb u0 com.wevr.wvrplayer.cardboard.external/org.libsdl.app.SDLActivity t2740 f}} appWin=Window{1ef158d8 u0 d0 SurfaceView} drawState=4
04-21 20:49:20.847: D/SSRM:a(3513): DeviceInfo:: 000000000000
04-21 20:49:20.847: D/SSRM:a(3513): SettingsAirViewInfo:: 000000000
04-21 20:49:20.847: I/Timeline(31184): Timeline: Activity_idle id: android.os.BinderProxy@322073e1 time:669930705
04-21 20:49:20.847: D/MultiWindowConverter(3513): dismissGuide() : Before attaching the guide view, mForceDismissGuide : false
04-21 20:49:20.847: D/WindowManager(3513): beginLayoutLw mStatusBar.isVisibleLw() = false, statusBarTransient=false, displayId=0
04-21 20:49:20.847: D/InputDispatcher(3513): Focus left window: 31184
04-21 20:49:20.857: D/PointerIcon(3513): setMouseIconStyle1 pointerType: 1001 iconType:101 flag:0 pid:3513 uid:1000
04-21 20:49:20.857: D/PointerIcon(3513): setMouseCustomIcon IconType is same.101
04-21 20:49:20.857: V/ActivityThread(30773): updateVisibility : ActivityRecord{3f7e8d90 token=android.os.BinderProxy@357022d5 {com.arm.mgd.mgddaemon/com.arm.mgd.mgddaemon.MainActivity}} show : false
04-21 20:49:20.857: I/SurfaceFlinger(2957): id=2802 Removed fxternal (8/11)
04-21 20:49:20.857: I/SurfaceFlinger(2957): id=2802 Removed fxternal (-2/11)
04-21 20:49:20.867: D/WindowManager(3513): beginLayoutLw mStatusBar.isVisibleLw() = false, statusBarTransient=false, displayId=0
04-21 20:49:20.867: V/MultiWindowTrayService(7708): onForegroundActivitiesChanged /arrangeState : 0
04-21 20:49:20.877: D/SensorService(3513): cleanupWithoutDisableLocked - size : 6, ref : 3
04-21 20:49:20.877: E/Sensors(31184): ~SensorEventQueue 0
04-21 20:49:20.877: E/(31184): BitTube(): close receivedFd (36)
04-21 20:49:20.877: D/SensorService(3513): cleanupConnection - size : 6, ref : 0
04-21 20:49:20.877: E/(3513): BitTube(): close sendFd (443)
04-21 20:49:20.877: D/SensorService(3513): cleanupWithoutDisableLocked - size : 5, ref : 3
04-21 20:49:20.887: E/Sensors(31184): ~SensorEventQueue 0
04-21 20:49:20.887: E/(31184): BitTube(): close receivedFd (32)
04-21 20:49:20.887: D/SensorService(3513): cleanupConnection - size : 5, ref : 0
04-21 20:49:20.887: E/(3513): BitTube(): close sendFd (442)
04-21 20:49:20.887: D/SensorService(3513): cleanupWithoutDisableLocked - size : 4, ref : 3
04-21 20:49:20.887: E/(31184): BitTube(): close receivedFd (40)
04-21 20:49:20.887: W/art(31184): Native thread exiting without having called DetachCurrentThread (maybe it's going to use a pthread_key_create destructor?): Thread[4,tid=31202,Native,Thread*=0xeec7b000,peer=0x12e480a0,"Thread-2227"]
04-21 20:49:20.887: D/SensorService(3513): cleanupConnection - size : 4, ref : 0
04-21 20:49:20.887: E/(3513): BitTube(): close sendFd (445)
04-21 20:49:20.897: W/mgd_interceptor(31184): (31220): AssetProcessorHelpers: Missing asset 4006314912 for EglSurfaceAsset in eglDestroySurface
04-21 20:49:20.897: V/WindowOrientationListener(3513): mSContextAutoRotationListener.getProposedRotation, mbResultFaceDectection: false
04-21 20:49:20.897: V/WindowOrientationListener(3513): mSContextAutoRotationListener.getProposedRotation, Rotation: -1
04-21 20:49:20.897: V/WindowManager(3513): rotationForOrientationLw(orient=-1, last=1); user=1 sensorRotation=-1 mLidState=-1 mDockMode=0 mHdmiPlugged=false mMobileKeyboardEnabled=false
04-21 20:49:20.897: D/PowerManagerService(3513): setKeyboardVisibility: false
04-21 20:49:20.897: D/ActivityManager(3513): Launching com.arm.mgd.mgddaemon, updated priority
04-21 20:49:20.907: V/ActivityManager(3513): updatePackageServicesTransationStatsLocked---package = com.arm.mgd.mgddaemon
04-21 20:49:20.907: V/ActivityManager_SPCMtest(3513): Launched -: com.arm.mgd.mgddaemon
04-21 20:49:20.907: V/MultiWindowTrayService(7708): onForegroundActivitiesChanged /arrangeState : 0
04-21 20:49:20.907: W/ResourceType(30773): For resource 0x7f020019, entry index(25) is beyond type entryCount(1)
04-21 20:49:20.907: W/ResourceType(30773): Failure getting entry for 0x7f020019 (t=1 e=25) (error -75)
04-21 20:49:20.907: E/Resources(30773): RunTimeException
04-21 20:49:20.907: E/Resources(30773): android.content.res.Resources$NotFoundException: Resource ID #0x7f020019
04-21 20:49:20.907: E/Resources(30773): at android.content.res.Resources.getValue(Resources.java:2418)
04-21 20:49:20.907: E/Resources(30773): at android.content.res.Resources.startRC(Resources.java:1082)
04-21 20:49:20.907: E/Resources(30773): at android.app.ActivityThread$mRunnable.run(ActivityThread.java:2926)
04-21 20:49:20.907: E/Resources(30773): at java.lang.Thread.run(Thread.java:818)
04-21 20:49:20.917: D/PhoneWindow(30773): *FMB* installDecor mIsFloating : false
04-21 20:49:20.917: D/PhoneWindow(30773): *FMB* installDecor flags : -2139029248
04-21 20:49:20.917: D/Activity(30773): performCreate Call Injection manager
04-21 20:49:20.917: W/MGD App List View(30773): AppListFragment.onCreateView
04-21 20:49:20.917: D/AbsListView(30773): Get MotionRecognitionManager
04-21 20:49:20.917: D/MotionRecognitionService(3513): ssp status : true
04-21 20:49:20.927: I/MGD Daemon GUI(30773): Enabling MGD Daemon.
04-21 20:49:20.927: D/ActivityManager(3513): startService callerProcessName:com.arm.mgd.mgddaemon, calleePkgName: com.arm.mgd.mgddaemon
04-21 20:49:20.927: D/ActivityManager(3513): retrieveServiceLocked(): component = com.arm.mgd.mgddaemon/com.arm.mgd.mgddaemon.MainService; callingUser = 0; userId(target) = 0
04-21 20:49:20.927: V/MGD GL Info View(30773): Creating new GL View
Sorry for the delayed response. We have just released a new version of the Mali Graphics Debugger. In this new version we have been working hard to improve Non-rooted support. I am hopeful that this will fix your issue, so I was wondering if you could try it and let me know if it helped.
The new version can be found at:
Mali Graphics Debugger - Mali Developer Center
Hello, I got the latest version of the graphics debugger and built it in (removing the old version, the old daemon, etc) and it's giving me the exact same errors when I run.
Sorry to hear that didn't fix the issue. The problem is that the log out have provided doesn't point to anything out of the ordinary that could cause the application to crash. I will message you with details on how we could help further.
