JOB cancelled by GPU reset. event code 0x4002
my compute shader program runs on samsung sm-g9200 android 5.1.1(api22) get this error output.
but it works well on qualcomm snapdragon.
in fact, i test my code on every mali or snapdragon, it happened the same.
// compute.glsl
layout(binding = 0) buffer VertexPositionOut
    vec3 Position[];
layout(binding = 1) buffer VertexNormalCoordOut
    vec2 NormalCoord[];
layout (r32f, binding = 0) mediump readonly uniform image2D height_data;
layout(local_size_x = 8, local_size_z = 8) in;
uniform float height_data_scale;
uniform ivec2 vertex_map_size;
void main(void)
    ivec2 start = ivec2(gl_LocalInvocationID.x, gl_LocalInvocationID.z);
    ivec2 step = ivec2(gl_WorkGroupSize.x, gl_WorkGroupSize.z);
   ivec2 face_size = vertex_map_size - ivec2(1, 1);
    for (int j = start.y; j < vertex_map_size.y; j += step.y)
        for (int i = start.x; i < vertex_map_size.x; i += step.x)
            int position_index = i + j * vertex_map_size.x;
            vec3 position = vec3(i, 0.0, j);
            position.y = imageLoad(height_data, ivec2(position.xz)).r * height_data_scale;
            Position[position_index] = position;
            vec2 normal_coord = position.xz / vec2(face_size);
            NormalCoord[position_index] = normal_coord;
// dispatch code
m_terrain_uncompress_compute_program->enable();
glBindBufferBase(GL_SHADER_STORAGE_BUFFER, 0, m_vbo_position);
glBindBufferBase(GL_SHADER_STORAGE_BUFFER, 1, m_vbo_normal_coord);
glBindImageTexture(0, m_height_map, 0, GL_FALSE, 0, GL_READ_ONLY, GL_R32F);
glBindImageTexture(1, m_normal_map, 0, GL_FALSE, 0, GL_WRITE_ONLY, GL_RGBA32F);
m_terrain_uncompress_compute_program->set_uniform("vertex_map_size", vertex_map_size);
m_terrain_uncompress_compute_program->set_uniform("height_data_scale", m_heightmap_data->m_fHeightScale);
glBindBuffer(GL_DISPATCH_INDIRECT_BUFFER, m_vbo_compute_indirect);
glDispatchComputeIndirect(0);
glBindBufferBase(GL_SHADER_STORAGE_BUFFER, 0, 0);
glBindBufferBase(GL_SHADER_STORAGE_BUFFER, 1, 0);
m_terrain_uncompress_compute_program->disable();
