problems using Open GL ES 3.x SDK for Android
Hi ,
I am trying to use "Open GL ES 3.x SDK for Android" using android  studio for compilation. I am facing issue while compiling the sample cases in the SDK .I tried to compile "TextureCube" example . Below I have mentioned the errors which I receive while compilation:
Error:(12, 0) Error: NDK integration is deprecated in the current plugin.  Consider trying the new experimental plugin.  For details, see http://tools.android.com/tech-docs/new-build-system/gradle-experimental.  Set "android.useDeprecatedNdk=true" in gradle.properties to continue using the current NDK integration.
<a href="openFile:C:\Users\jpatil1\AndroidStudioProjects\TextureCube\app\build.gradle">Open File</a>
So can someone provide the steps necessary to compile the examples provided in SDK using android studio ?
regards,
jitender
