Hi!
I've tried to use extensions EGL_KHR_partial_update and EGL_EXT_swap_buffers_with_damage on the devices with Mali-T760 gpu.
For extension EGL_KHR_partial_update specification says:
Use the command EGLBoolean eglSetDamageRegionKHR( EGLDisplay dpy, EGLSurface surface, EGLint *rects, EGLint n_rects)...<n_rects> specifies the number of rectangles comprising the damage region. <rects> is a pointer to a list of values describing the rectangles. The list should consist of <n_rects> groups of four values, with each group representing a single rectangle in surface coordinates in the form {x, y, width, height}. Coordinates are specified relative to the lower left corner of the surface.
But on devices with Mali-T760 for correct drawing, n_rects coordinates have to be relative to the upper left corner of the surface.
Is it a driver bug?
P.S. eglSwapBuffersWithDamageEXT works correct (the rectangles are specified relative to the bottom-left of the surface)
Thanks in advance,
Igor
Hi Igor,
Please let us know the version of the driver that you experience this issue with.
There is a known issue with this when using older drivers, but it has since been fixed in r7p0.
If you can, please update your driver to at least r7p0 or later, and see if the problem persists.
Kind Regards,
Michael McGeagh
Version of the driver is: v1.r7p0-03rel0...
Apologies, I was misinformed. It was raised in our system from r7p0. It has since been resolved and in r10p0.
Hi Michael,
Thank you for the information.
