Dear ARM Forum,
I am looking for a GPU Benchmark , which can reveal the information like below.
a) Tool should have graphics sub-module wise tests? Like Vertex processor intensive test? Pixel processor intensive test? to capture GPU standalone performance numbers for each sub-module.
b) Tool should be able to run with a specific set of test inputs. Like example in below I). What is the frame-rate for .Inputs Frame-buffer size: 1200x720 , Number of Triangles : 10k triangles , Texture size: 2048 x1536
c) Tool should have stress test results on each VP and PP ? specifically OpenGLES 2.0 based?
d) Is there any system load + Graphics testing ? Example below,
I) The test should start some continues non-cached memory copy test on application processor or in the system and start the graphics test on GPU and capture the performance marks ?
Could you please add if any interesting and important points missing ,with respect to GPU Bench Mark.
Could you please suggest me some good commercial GPU Benchmarks which can solve my purpose.
Thanks,
Ravinder Are
mcgeah couldn't have said it better. It would help to have some background as to the need for a benchmarking application. Given the fact that benchmark results is no indication of other application performance, they are in my opinion useless, unless the intent is to brag about benchmark scores. For development purposes ( if this is the intent ), I would suggest find a decent profiler.
