mali driver ioctl failure
I have to install mali r5p2 driver on radxa rock pro board.
i had successfully build kernel and user space driver.
but i am getting the following error:
     MALI PHYSICAL RANGE VALIDATION ERROR:
          the range supply was: phys_base=0x97000000, size=0x007E9000
     bind externel buf failed
     _mali_ukk_mem_bind, return ERROR
i had build user space driver with ump support for Android kitkat.
how can i make it work?
Thank you.
  • Hi mohit28,
    Considering you are stating you can build the user space driver, this must mean you have access to our proprietary DDK.
    This means you are most likely a partner of ARM and are thus entitled to dedicated support.
    Please contact ARM Support for this as we cannot discuss non-public information on the public community.
    Kind Regards,
    Michael McGeagh
