Is it possible to benefit from DMA in r6p0 using DRM + GPU?
I own an odroid XU3 wich runs currently with the newest mali driver (r6p0) on ubuntu 15.01 without X.
I spend the last days in trying to pass the drm buffer using gbm into the mali gpu, until now with no success.
Problem is, that I'm not able to set up a renderable surface, I tried several extensions (MESA_GBM for example) but they all fail.
Can you pls. provide me with the information if its possible or not?
If it should be possible - are there any resources / samples where to look or the key?
Thanks!
Markus
