How can I set PremultipliedAlpha false?
Any help will be appreciated!
This is my command line.
etcpack "$src" "$dest" -c etc1 -as -s fast -e perceptual -progress
I don't want RGB to multiply alpha value.
I've used Mali Texture Compression Tool GUI and etcpack with the options you specified to compress an image with an alpha channel.In both cases the RGB values in the resulting image were nearly identical to the ones in the original image, so no sign of premultiplied alpha.
Could you please upload an image that we could use to reproduce the problem?
Thanks,
Jacek
