Dear Community,
since my Hardkernel Odroid U3 is now (most of all) good supported by the mainline kernel, I tried to build the "mali" driver for linux 4.2 and noticed that there is no 'legacy' method by using USING_DT=0.
Therefore I have to add an "gpu@" entry to the device tree, so the mali driver can find the GPU on my Samsung 4412 Prime SoC.
I read your example how to add the missing entry and also found this dt implimentation made for the r4p0 by Tobias Jakobi.
mali@13000000 { compatible = "arm,mali400-mp4"; #address-cells = <1>; #size-cells = <1>; shared-memory-size = <0x10000000>; /* Mali DVFS */ utilization-interval = <1000>; power-domains = <&pd_g3d>; status = "okay"; /* Propagate VPLL output clock to SCLK_G3D and ensure that the DIV_G3D * divider is 1. */ assigned-clocks = <&clock CLK_MOUT_G3D1>, <&clock CLK_MOUT_G3D>, <&clock CLK_FOUT_VPLL>, <&clock CLK_SCLK_G3D>; assigned-clock-parents = <&clock CLK_SCLK_VPLL>, <&clock CLK_MOUT_G3D1>; assigned-clock-rates = <0>, <0>, <533000000>, <533000000>; clocks = <&clock CLK_SCLK_G3D>, <&clock CLK_G3D>; clock-names = "sclk_g3d", "g3d"; reg = <0x13001000 0x200>, <0x13000000 0x100>, <0x13003000 0x100>, <0x13008000 0x1100>, <0x13004000 0x100>, <0x1300A000 0x1100>, <0x13005000 0x100>, <0x1300C000 0x1100>, <0x13006000 0x100>, <0x1300E000 0x1100>, <0x13007000 0x100>, <0x13012000 0x100>; reg-names = "l2", "gp", "gp_mmu", "pp_0", "pp_mmu_0", "pp_1", "pp_mmu_1", "pp_2", "pp_mmu_2", "pp_3", "pp_mmu_3", "dma"; interrupts = <0 127 0>, <0 122 0>, <0 123 0>, <0 118 0>, <0 124 0>, <0 119 0>, <0 125 0>, <0 120 0>, <0 126 0>, <0 121 0>; interrupt-names = "gp", "gp_mmu", "pp_0", "pp_mmu_0", "pp_1", "pp_mmu_1", "pp_2", "pp_mmu_2", "pp_3", "pp_mmu_3"; gpu-supply = <&buck4_reg>;
mali@13000000 {
#size-cells = <1>;
/* Mali DVFS */
status = "okay";
* divider is 1. */
So I 'converted' these most of these entries to fit your dt layout:
gpu@13000000 { compatible = "arm,mali-400", "arm,mali-utgard"; reg = <0x13000000 0x30000>; interrupts = <0 127 0>, <0 122 0>, <0 123 0>, <0 118 0>, <0 124 0>, <0 119 0>, <0 125 0>, <0 120 0>, <0 126 0>, <0 121 0>, <0 117 0>; interrupt-names = "IRQGP", "IRQGPMMU", "IRQPP0", "IRQPPMMU0", "IRQPP1", "IRQPPMMU1", "IRQPP2", "IRQPPMMU2", "IRQPP3", "IRQPPMMU3", "IRQPMU"; pmu_domain_config = <0x1 0x4 0x0 0x0 0x0 0x0 0x0 0x0 0x0 0x2 0x0 0x0>; pmu_switch_delay = <0xff>; clocks = <&clock CLK_SCLK_G3D>, <&clock CLK_G3D>; clock-names = "mali_parent", "mali"; vdd_g3d-supply = <&buck4_reg>; };
But during modprobe I get this on dmesg:
[ 359.340576] Mali<2>: Inserting Mali v600 device driver. [ 359.340627] Mali<2>: Compiled: Oct 22 2015, time: 23:12:22.[ 359.340666] Mali<2>: Driver revision: r5p0-01rel0-8edbaa0[ 359.340702] Mali<2>: mali_module_init() registering driver[ 359.341638] Mali<2>: mali_probe(): Called for platform device 13000000.gpu[ 359.342014] Mali<2>: Mali memory settings (shared: 0xFFFFFFFF)[ 359.342037] Mali<2>: Using device defined frame buffer settings (0x00000000@0x00000000)[ 359.342067] Mali<2>: Mali PM domain: Creating Mali PM domain (mask=0x00001000)[ 359.342114] Mali<2>: Mali PP: Creating Mali PP core: Mali_PP0[ 359.342153] Mali<2>: Mali PP: Base address of PP core: 0x13008000[ 359.343326] Mali: ERR: /source/mali/DX910/drivers/r5p0/src/devicedrv/mali/common/mali_pp.c[ 359.343346] mali_pp_reset_wait() 267 Mali PP: Failed to reset core Mali_PP0, rawstat: 0x00000000[ 359.343385] Mali: ERR: /source/mali/DX910/drivers/r5p0/src/devicedrv/mali/common/mali_kernel_core.c[ 359.343399] mali_parse_product_info() 167 Failed to create initial PP object[ 359.343429] Mali<2>: terminate_subsystems() called[ 359.343566] Mali: ERR: /source/mali/DX910/drivers/r5p0/src/devicedrv/mali/linux/mali_kernel_linux.c[ 359.343583] mali_probe() 507 mali_probe(): Failed to initialize Mali device driver.[ 359.343774] mali-utgard: probe of 13000000.gpu failed with error -14[ 359.344002] Mali: Mali device driver loaded
(This was actually what I get before adding IRQ_PMU. The new output just throws additional lines with errors about PMU, but I think we can start with these, isn't it?)
Do you have maybe more examples how to create this gpu entry? A better example which is specific for my Mali400-MP4 or even SoC?
It would be great if you could help getting my GPU working with the mali driver
PS: Here is the /proc/interrupts of the vendors 3.8.y kernel:
CPU0 CPU1 CPU2 CPU3 11: 0 0 0 0 max77686 rtc-alarm0 28: 3625399 2705490 1989068 1964778 GIC MCT 66: 0 0 0 0 GIC dma-pl330.2 67: 187354 0 0 0 GIC dma-pl330.0 68: 0 0 0 0 GIC dma-pl330.1 85: 371 0 0 0 GIC exynos4210-uart 89: 10 0 0 0 GIC mct_comp_irq 90: 152893 0 0 0 GIC s3c2440-i2c.0 91: 492 0 0 0 GIC s3c2440-i2c.1 93: 0 0 0 0 GIC s3c2440-i2c.3 97: 0 0 0 0 GIC s3c2440-i2c.7102: 35739125 0 0 0 GIC ehci_hcd:usb1, ohci_hcd:usb2103: 0 0 0 0 GIC s3c-hsotg107: 10380 0 0 0 GIC mmc0109: 75 0 0 0 GIC dw-mci121: 0 0 0 0 GIC drm_g2d123: 604531 0 0 0 GIC drm_mixer125: 72 0 0 0 GIC s3c2440-hdmiphy-i2c126: 26 0 0 0 GIC s5p-mfc150: 0 0 0 0 GIC Mali_PP0_MMU151: 0 0 0 0 GIC Mali_PP1_MMU152: 0 0 0 0 GIC Mali_PP2_MMU 153: 0 0 0 0 GIC Mali_PP3_MMU 154: 0 0 0 0 GIC Mali_GP_MMU 155: 74966 0 0 0 GIC Mali_PP0 156: 74963 0 0 0 GIC Mali_PP1 157: 74957 0 0 0 GIC Mali_PP2 158: 74954 0 0 0 GIC Mali_PP3 159: 97884 0 0 0 GIC Mali_GP 180: 0 0 0 0 COMBINER exynos-tmu 194: 0 0 0 0 COMBINER exynos-sysmmu.5 195: 0 0 0 0 COMBINER exynos-sysmmu.6 196: 0 0 0 0 COMBINER exynos-sysmmu.7 197: 0 0 0 0 COMBINER exynos-sysmmu.8 198: 0 0 0 0 COMBINER exynos-sysmmu.3 199: 0 0 0 0 COMBINER exynos-sysmmu.14 200: 0 0 0 0 COMBINER exynos-sysmmu.4 202: 0 0 0 0 COMBINER exynos-sysmmu.10 204: 0 0 0 0 COMBINER exynos-sysmmu.2 205: 0 0 0 0 COMBINER exynos-sysmmu.1 206: 0 0 0 0 COMBINER exynos-sysmmu.0 416: 2 0 0 0 exynos-eint max98090_interrupt 427: 1 0 0 0 exynos-eint KEY_POWER 430: 1 0 0 0 exynos-eint DEVICE_DETECT 434: 0 0 0 0 exynos-eint KEY_USER 441: 0 0 0 0 exynos-eint HOST_DETECT 442: 0 0 0 0 exynos-eint max77686-irq 447: 0 0 0 0 exynos-eint hdmi IPI0: 0 1 55 41 CPU wakeup interrupts IPI1: 0 0 0 0 Timer broadcast interrupts IPI2: 5268640 16511481 13345249 3560029 Rescheduling interrupts IPI3: 350 381 227 374 Function call interrupts IPI4: 77 79 384 307 Single function call interrupts IPI5: 0 0 0 0 CPU stop interrupts Err: 0
CPU0 CPU1 CPU2 CPU3
Err: 0
Regards
Thomas Pietrowski
Hi Thomas,
The fact the reset is failing seems to imply that the GPU either isn't powered or isn't at the address you are poking (I would guess the former). The power management control hardware for the GPU is not actually part of the Mali GPU itself, and is provided by the chipset manufacturer, so in your case will be provided by Samsung. Copying the power management DT configuration from a different chipset (especially if from a different chipset vendor) is unlikely to work.
I'll try and find someone around here who has some familiarity with that chipset, but you may get some luck on the Samsung support forums too, as they are more likely to know more about that specific PM hardware than us.
Cheers, Pete
Thank you for your help! By asking on the Samsung forums, do you think Forum | SAMSUNG Developers is the right forum? Don't know whether there are more specific forums.
Both DT entries use the same SoC. The entry above is by someone working on a Odroid X2 which also has a Exynos4412 Prime like the Odroid U3.
Looking at Samsung's documentation, I found via Google (http://www.samsung.com/global/business/semiconductor/file/product/Exynos_4_Quad_User_Manaul_Public_REV1.00-0.pdf ), the G3D adress at @13000000 should be correct (page 35 in the docs).
Also the interrupts should be correct while looking at page 547. Thats actually where I took the IRQPMU from, because it was missing in the first DT above.
Additionally I tried verify all the other values by browsing driver shipped in a 3.8.y kernel by the vendor, but without any luck.
Again, thank you for your efforts!
You can refer following repository tobiasjakobi/linux-odroid · GitHub for Mali400 configuration.
He uses the own DT implementation I mentioned above. I tried his driver, but first of all it is based on r4p0 and I couldn't get the driver working with the r4p0 blob. Applications don't crash but they just close without any error message.
I compared the IRQ numbers in /proc/interrupts in hardkernels linux 3.8.y with my DT entry and they are different. Shouldn't they be the same?
(Will upload the output later)
Is it possible that you can send me some more examples for other devices?
* How the dt entry should look like (for dummies)
* How to setup the driver (is a custom MALI_PLATFORM needed?)
* etc.
Additionally, I really miss a full documentation of your driver. For example the Intel EMGD driver was horrible, as I had to upgrade Xserver and Mesa to a specific version depending on the libGL blob and had to vmalloc some memory to get libVA working, but I got all this info from the docs.
Or is there a download I missed so far about such a documentation?
