Generate errors when I compile the mali-400 kernel drivers .
Hello ,everyone
I meet some problems when I compile the mali-400 kernel drivers
I copy the mali0400 drivers to the linux kernel and config the linux kernel .but when I compile the kernel the compiler just generate errors
                                                  Here is the .config of my linux kernel :.
# Graphics support
CONFIG_DRM=y
CONFIG_DRM_KMS_HELPER=y
# CONFIG_DRM_LOAD_EDID_FIRMWARE is not set
# I2C encoder or helper chips
# CONFIG_DRM_I2C_CH7006 is not set
# CONFIG_DRM_I2C_SIL164 is not set
# CONFIG_DRM_MALI is not set
CONFIG_DRM_EXYNOS=y
CONFIG_DRM_EXYNOS_DMABUF=y
CONFIG_DRM_EXYNOS_VIDI=y
CONFIG_DRM_EXYNOS_G2D=y
# CONFIG_DRM_UDL is not set
CONFIG_MALI400=y
# CONFIG_MALI450 is not set
CONFIG_MALI400_DEBUG=y
CONFIG_MALI400_PROFILING=y
CONFIG_MALI400_INTERNAL_PROFILING=y
CONFIG_MALI400_UMP=y
# CONFIG_MALI400_POWER_PERFORMANCE_POLICY is not set
CONFIG_MALI_DMA_BUF_MAP_ON_ATTACH=y
# CONFIG_MALI_SHARED_INTERRUPTS is not set
# CONFIG_MALI_PMU_PARALLEL_POWER_UP is not set
CONFIG_UMP=y
# CONFIG_UMP_DEBUG is not set
CONFIG_ION=y
CONFIG_ION_EXYNOS=y
# CONFIG_VGASTATE is not set
# CONFIG_VIDEO_OUTPUT_CONTROL is not set
CONFIG_FB=y
# Frame buffer hardware drivers
CONFIG_FB_S3C=y
CONFIG_FB_S3C_NR_BUFFERS=3
CONFIG_BACKLIGHT_LCD_SUPPORT=y
CONFIG_LCD_CLASS_DEVICE=y
                    Here is the errors when I make :.
LD      drivers/gpu/mali_r4p0-00rel1/built-in.o
drivers/gpu/mali_r4p0-00rel1/devicedrv/ump/built-in.o: In function `_mali_osk_break':
/home/larrychen/kernel-src/linux-3.5/drivers/gpu/mali_r4p0-00rel1/devicedrv/ump/../mali/linux/mali_osk_misc.c:53: multiple definition of `_mali_osk_break'
drivers/gpu/mali_r4p0-00rel1/devicedrv/mali/built-in.o:/home/larrychen/kernel-src/linux-3.5/drivers/gpu/mali_r4p0-00rel1/devicedrv/mali/linux/mali_osk_misc.c:53: first defined here
drivers/gpu/mali_r4p0-00rel1/devicedrv/ump/built-in.o: In function `fls':
/home/larrychen/kernel-src/linux-3.5/arch/arm/include/asm/bitops.h:268: multiple definition of `_mali_osk_clz'
drivers/gpu/mali_r4p0-00rel1/devicedrv/mali/built-in.o:/home/larrychen/kernel-src/linux-3.5/arch/arm/include/asm/bitops.h:268: first defined here
drivers/gpu/mali_r4p0-00rel1/devicedrv/ump/built-in.o: In function `_mali_osk_memcpy':
/home/larrychen/kernel-src/linux-3.5/drivers/gpu/mali_r4p0-00rel1/devicedrv/ump/../mali/linux/mali_osk_memory.c:47: multiple definition of `_mali_osk_memcpy'
drivers/gpu/mali_r4p0-00rel1/devicedrv/mali/built-in.o:/home/larrychen/kernel-src/linux-3.5/drivers/gpu/mali_r4p0-00rel1/devicedrv/mali/linux/mali_osk_memory.c:47: first defined here
drivers/gpu/mali_r4p0-00rel1/devicedrv/ump/built-in.o: In function `_mali_osk_valloc':
/home/larrychen/kernel-src/linux-3.5/drivers/gpu/mali_r4p0-00rel1/devicedrv/ump/../mali/linux/mali_osk_memory.c:37: multiple definition of `_mali_osk_valloc'
drivers/gpu/mali_r4p0-00rel1/devicedrv/mali/built-in.o:/home/larrychen/kernel-src/linux-3.5/drivers/gpu/mali_r4p0-00rel1/devicedrv/mali/linux/mali_osk_memory.c:37: first defined here
drivers/gpu/mali_r4p0-00rel1/devicedrv/ump/built-in.o: In function `current_thread_info':
/home/larrychen/kernel-src/linux-3.5/arch/arm/include/asm/thread_info.h:97: multiple definition of `_mali_osk_get_pid'
drivers/gpu/mali_r4p0-00rel1/devicedrv/mali/built-in.o:/home/larrychen/kernel-src/linux-3.5/arch/arm/include/asm/thread_info.h:97: first defined here
drivers/gpu/mali_r4p0-00rel1/devicedrv/ump/built-in.o: In function `_mali_osk_atomic_read':
/home/larrychen/kernel-src/linux-3.5/drivers/gpu/mali_r4p0-00rel1/devicedrv/ump/../mali/linux/mali_osk_atomics.c:49: multiple definition of `_mali_osk_atomic_read'
drivers/gpu/mali_r4p0-00rel1/devicedrv/mali/built-in.o:/home/larrychen/kernel-src/linux-3.5/drivers/gpu/mali_r4p0-00rel1/devicedrv/mali/linux/mali_osk_atomics.c:49: first defined here
drivers/gpu/mali_r4p0-00rel1/devicedrv/ump/built-in.o: In function `_mali_osk_atomic_inc_return':
/home/larrychen/kernel-src/linux-3.5/drivers/gpu/mali_r4p0-00rel1/devicedrv/ump/../mali/linux/mali_osk_atomics.c:36: multiple definition of `_mali_osk_atomic_inc_return'
drivers/gpu/mali_r4p0-00rel1/devicedrv/mali/built-in.o:/home/larrychen/kernel-src/linux-3.5/drivers/gpu/mali_r4p0-00rel1/devicedrv/mali/linux/mali_osk_atomics.c:36: first defined here
drivers/gpu/mali_r4p0-00rel1/devicedrv/ump/built-in.o: In function `_mali_osk_memset':
/home/larrychen/kernel-src/linux-3.5/drivers/gpu/mali_r4p0-00rel1/devicedrv/ump/../mali/linux/mali_osk_memory.c:52: multiple definition of `_mali_osk_memset'
drivers/gpu/mali_r4p0-00rel1/devicedrv/mali/built-in.o:/home/larrychen/kernel-src/linux-3.5/drivers/gpu/mali_r4p0-00rel1/devicedrv/mali/linux/mali_osk_memory.c:52: first defined here
drivers/gpu/mali_r4p0-00rel1/devicedrv/ump/built-in.o: In function `_mali_osk_abort':
/home/larrychen/kernel-src/linux-3.5/drivers/gpu/mali_r4p0-00rel1/devicedrv/ump/../mali/linux/mali_osk_misc.c:45: multiple definition of `_mali_osk_abort'
drivers/gpu/mali_r4p0-00rel1/devicedrv/mali/built-in.o:/home/larrychen/kernel-src/linux-3.5/drivers/gpu/mali_r4p0-00rel1/devicedrv/mali/linux/mali_osk_misc.c:45: first defined here
drivers/gpu/mali_r4p0-00rel1/devicedrv/ump/built-in.o: In function `_mali_osk_mem_check_allocated':
/home/larrychen/kernel-src/linux-3.5/drivers/gpu/mali_r4p0-00rel1/devicedrv/ump/../mali/linux/mali_osk_memory.c:61: multiple definition of `_mali_osk_mem_check_allocated'
drivers/gpu/mali_r4p0-00rel1/devicedrv/mali/built-in.o:/home/larrychen/kernel-src/linux-3.5/drivers/gpu/mali_r4p0-00rel1/devicedrv/mali/linux/mali_osk_memory.c:61: first defined here
drivers/gpu/mali_r4p0-00rel1/devicedrv/ump/built-in.o: In function `map_errcode':
/home/larrychen/kernel-src/linux-3.5/drivers/gpu/mali_r4p0-00rel1/devicedrv/ump/linux/ump_kernel_linux.c:360: multiple definition of `map_errcode'
drivers/gpu/mali_r4p0-00rel1/devicedrv/mali/built-in.o:/home/larrychen/kernel-src/linux-3.5/drivers/gpu/mali_r4p0-00rel1/devicedrv/mali/linux/mali_kernel_linux.c:552: first defined here
drivers/gpu/mali_r4p0-00rel1/devicedrv/ump/built-in.o: In function `_mali_osk_calloc':
/home/larrychen/kernel-src/linux-3.5/drivers/gpu/mali_r4p0-00rel1/devicedrv/ump/../mali/linux/mali_osk_memory.c:21: multiple definition of `_mali_osk_calloc'
drivers/gpu/mali_r4p0-00rel1/devicedrv/mali/built-in.o:/home/larrychen/kernel-src/linux-3.5/drivers/gpu/mali_r4p0-00rel1/devicedrv/mali/linux/mali_osk_memory.c:21: first defined here
drivers/gpu/mali_r4p0-00rel1/devicedrv/ump/built-in.o: In function `atomic_add':
/home/larrychen/kernel-src/linux-3.5/arch/arm/include/asm/atomic.h:44: multiple definition of `_mali_osk_atomic_inc'
drivers/gpu/mali_r4p0-00rel1/devicedrv/mali/built-in.o:/home/larrychen/kernel-src/linux-3.5/arch/arm/include/asm/atomic.h:44: first defined here
drivers/gpu/mali_r4p0-00rel1/devicedrv/ump/built-in.o: In function `_mali_osk_atomic_term':
/home/larrychen/kernel-src/linux-3.5/drivers/gpu/mali_r4p0-00rel1/devicedrv/ump/../mali/linux/mali_osk_atomics.c:55: multiple definition of `_mali_osk_atomic_term'
drivers/gpu/mali_r4p0-00rel1/devicedrv/mali/built-in.o:/home/larrychen/kernel-src/linux-3.5/drivers/gpu/mali_r4p0-00rel1/devicedrv/mali/linux/mali_osk_atomics.c:55: first defined here
drivers/gpu/mali_r4p0-00rel1/devicedrv/ump/built-in.o: In function `atomic_sub':
/home/larrychen/kernel-src/linux-3.5/arch/arm/include/asm/atomic.h:82: multiple definition of `_mali_osk_atomic_dec'
drivers/gpu/mali_r4p0-00rel1/devicedrv/mali/built-in.o:/home/larrychen/kernel-src/linux-3.5/arch/arm/include/asm/atomic.h:82: first defined here
drivers/gpu/mali_r4p0-00rel1/devicedrv/ump/built-in.o: In function `_mali_osk_atomic_xchg':
/home/larrychen/kernel-src/linux-3.5/drivers/gpu/mali_r4p0-00rel1/devicedrv/ump/../mali/linux/mali_osk_atomics.c:58: multiple definition of `_mali_osk_atomic_xchg'
drivers/gpu/mali_r4p0-00rel1/devicedrv/mali/built-in.o:/home/larrychen/kernel-src/linux-3.5/drivers/gpu/mali_r4p0-00rel1/devicedrv/mali/linux/mali_osk_atomics.c:58: first defined here
drivers/gpu/mali_r4p0-00rel1/devicedrv/ump/built-in.o: In function `kmalloc':
/home/larrychen/kernel-src/linux-3.5/include/linux/slub_def.h:283: multiple definition of `_mali_osk_malloc'
drivers/gpu/mali_r4p0-00rel1/devicedrv/mali/built-in.o:/home/larrychen/kernel-src/linux-3.5/include/linux/slub_def.h:283: first defined here
/home/larrychen/kernel-src/linux-3.5/arch/arm/include/asm/thread_info.h:97: multiple definition of `_mali_osk_get_tid'
drivers/gpu/mali_r4p0-00rel1/devicedrv/ump/built-in.o: In function `_mali_osk_atomic_dec_return':
/home/larrychen/kernel-src/linux-3.5/drivers/gpu/mali_r4p0-00rel1/devicedrv/ump/../mali/linux/mali_osk_atomics.c:26: multiple definition of `_mali_osk_atomic_dec_return'
drivers/gpu/mali_r4p0-00rel1/devicedrv/mali/built-in.o:/home/larrychen/kernel-src/linux-3.5/drivers/gpu/mali_r4p0-00rel1/devicedrv/mali/linux/mali_osk_atomics.c:26: first defined here
drivers/gpu/mali_r4p0-00rel1/devicedrv/ump/built-in.o: In function `_mali_osk_snprintf':
/home/larrychen/kernel-src/linux-3.5/drivers/gpu/mali_r4p0-00rel1/devicedrv/ump/../mali/linux/mali_osk_misc.c:33: multiple definition of `_mali_osk_snprintf'
drivers/gpu/mali_r4p0-00rel1/devicedrv/mali/built-in.o:/home/larrychen/kernel-src/linux-3.5/drivers/gpu/mali_r4p0-00rel1/devicedrv/mali/linux/mali_osk_misc.c:33: first defined here
drivers/gpu/mali_r4p0-00rel1/devicedrv/ump/built-in.o: In function `_mali_osk_atomic_init':
/home/larrychen/kernel-src/linux-3.5/drivers/gpu/mali_r4p0-00rel1/devicedrv/ump/../mali/linux/mali_osk_atomics.c:42: multiple definition of `_mali_osk_atomic_init'
drivers/gpu/mali_r4p0-00rel1/devicedrv/mali/built-in.o:/home/larrychen/kernel-src/linux-3.5/drivers/gpu/mali_r4p0-00rel1/devicedrv/mali/linux/mali_osk_atomics.c:42: first defined here
drivers/gpu/mali_r4p0-00rel1/devicedrv/ump/built-in.o: In function `_mali_osk_dbgmsg':
/home/larrychen/kernel-src/linux-3.5/drivers/gpu/mali_r4p0-00rel1/devicedrv/ump/../mali/linux/mali_osk_misc.c:24: multiple definition of `_mali_osk_dbgmsg'
drivers/gpu/mali_r4p0-00rel1/devicedrv/mali/built-in.o:/home/larrychen/kernel-src/linux-3.5/drivers/gpu/mali_r4p0-00rel1/devicedrv/mali/linux/mali_osk_misc.c:24: first defined here
drivers/gpu/mali_r4p0-00rel1/devicedrv/ump/built-in.o: In function `_mali_osk_vfree':
/home/larrychen/kernel-src/linux-3.5/drivers/gpu/mali_r4p0-00rel1/devicedrv/ump/../mali/linux/mali_osk_memory.c:42: multiple definition of `_mali_osk_vfree'
drivers/gpu/mali_r4p0-00rel1/devicedrv/mali/built-in.o:/home/larrychen/kernel-src/linux-3.5/drivers/gpu/mali_r4p0-00rel1/devicedrv/mali/linux/mali_osk_memory.c:42: first defined here
/home/larrychen/kernel-src/linux-3.5/arch/arm/include/asm/bitops.h:268: multiple definition of `_mali_osk_fls'
drivers/gpu/mali_r4p0-00rel1/devicedrv/ump/built-in.o: In function `_mali_osk_free':
/home/larrychen/kernel-src/linux-3.5/drivers/gpu/mali_r4p0-00rel1/devicedrv/ump/../mali/linux/mali_osk_memory.c:32: multiple definition of `_mali_osk_free'
drivers/gpu/mali_r4p0-00rel1/devicedrv/mali/built-in.o:/home/larrychen/kernel-src/linux-3.5/drivers/gpu/mali_r4p0-00rel1/devicedrv/mali/linux/mali_osk_memory.c:32: first defined here
