create errors when I build the Mali™ GPU User Interface Engine
Hello ,everyone
I have a problem when I make the code of Mali™ GPU User Interface Engine which I download today.
my system is ubuntu 14.0  --32bit .And I had install the Xlib by apt-get install libX11-dev
after I enter the command :
make all CONFIG=release VARIANT=x11linux-gles20 TOOLCHAIN=gcc
the following is the echo errors:
/usr/bin/ld: build/gcc-i686-linux-release-x11linux-gles20/lib/libmde.a(x11_event_handler.small.o): undefined reference to symbol 'XNextEvent'
/usr/lib/i386-linux-gnu/libX11.so.6: error adding symbols: DSO missing from command line
collect2: error: ld returned 1 exit status
make: *** [build/gcc-i686-linux-release-x11linux-gles20/bin/mde_test/mde_test] Error 1
I had check it on the Internet that the errors was link error rather than the compilers error .but I can't find how to solve the problem .
