Mali Graphics Debugger: Not getting trace data in GUI
I've been working on this all day and I can't quite get the last mile done.
I've followed the Help documentation to a T, as well as, looked around this site for relevant info.  Specifically, Re: Re: Mali Graphics Debugger : libGLES_mgd.so makes crash application  Though, no applications are crashing in my case, I'm just not getting trace data.  Similarly, I'm working on a Samsung Note 8.0 GT-N5110 with a Mali-400 GPU.  I think, for some reason that mgddaemon isn't able to send traces, and I'm trying to track down why.
I'll answer the first few questions in the above post by default.
  • Firstly /vendor/lib/egl doesn't exist
  • Here's /system/lib/egl
shell@konawifi:/system/lib/egl $ ls -al
-rwxrwxrwx root     root            8 2015-07-22 14:42 egl.cfg
-rwxrwxrwx root     root          416 2015-07-22 14:42 egl.cfg.bak
-rwxrwxrwx root     root        13344 2014-08-04 07:15 libEGL_mali.so
lrwxrwxrwx root     root              2015-07-22 14:46 libEGL_mgd.so -> /system/lib/egl/libGLES_mgd.so
lrwxrwxrwx root     root              2015-07-22 14:42 libGLES.so -> /system/lib/egl/libGLES_mgd.so
-rwxrwxrwx root     root        79116 2014-08-04 07:14 libGLES_android.so
-rwxrwxrwx root     root      3724781 2015-07-22 16:21 libGLES_mgd.so
-rwxrwxrwx root     root        25640 2014-08-04 07:15 libGLESv1_CM_mali.so
lrwxrwxrwx root     root              2015-07-22 14:46 libGLESv1_CM_mgd.so -> /system/lib/egl/libGLES_mgd.so
-rwxrwxrwx root     root        21540 2014-08-04 07:15 libGLESv2_mali.so
lrwxrwxrwx root     root              2015-07-22 14:46 libGLESv2_mgd.so -> /system/lib/egl/libGLES_mgd.so
Macintosh:arm_android snovak$ adb shell mgddaemon
1437602372514: mgd_daemon[6520]: INFO: Main: The MGD daemon is starting
Daemon is version: B002
Socket is: \0mgddaemon
1437602372519: mgd_daemon[6520]: INFO: HostConnection: Initializing host connection
1437602372522: mgd_daemon[6520]: INFO: InterceptorListener: Initializing interceptor listener
1437602372523: mgd_daemon[6520]: INFO: Daemon: Daemon initializing
1437602372527: mgd_daemon[6520]: INFO: Daemon: Daemon running
1437602372529: mgd_daemon[6520]: INFO: InterceptorListener: Interceptor Listener waiting for connections
1437602372531: mgd_daemon[6520]: INFO: HostConnection: Host connection listening
    • Firstly, this sort of indicates that the daemon isn't started on boot.  I think that's bad.
    • I don't see anything saying that it's on port 5002.... as you see @~2:40 on the video
    • I see Socket is: \0mgddaemon, but I don't see anything about a port, so is \0mgddaemon local TCP/IP, or something else?
    • I do forward the port as outlined in the Help documentation via `adb forward tcp:5002 tcp:5002`
    • The GUI connects to the port, but again, I see no traces.  If the calls are being intercepted, I don't think they're going down the right pipe.
