Does anyone know how to open the samples from the text guide, Chapter 16 for W7?
I have already downloaded the emulator, cmake and Visual Studio.
The instructions are somewhat confusing for me on page 448.
trying to get started with the 'Hello Triangle' code.
Hi borikensis7,
Sorry but I do not fully understand your question, can you rephrase it, or provide links etc to what you mean?
What 'OpenGL ES 2.0 Text Guide' do you refer to?
Do you mean the Mali OpenGL ES SDK?
The source code for all of our samples are contained within the SDK's that we provide: SDKs - Mali Developer Center
Please download either the Android or the Linux SDK, and you will find the source code within that package.
I hope that helps.
Kind Regards,
Michael McGeagh
Hello McGeagh,
This is my purchased book from the Amazon link:
http://www.amazon.com/OpenGL-3-0-Programming-Guide-Edition/dp/0321933885
I want to build the samples for Microsoft Windows with Visual Studio. I am currently using W7.
It tells that in order to download and build the samples go to this link:
https://github.com/danginsburg/opengles3-book/
But then I stumbled upon this other link:
https://github.com/benosteen/opengles-book-samples/tree/master/Windows
I have already installed Visual Studio 2013, CMake and the Mali Cube Emulator.
The book also instructs to create folders or directories.
But how do I do that?
Thanks In Advance,
Lester R.
Hello.
According to the book, that's what it says.
I went to qualcomm developer site to download
the Adreno SDK emulator, but there's a bunch
of links there.
Have no idea what to pick.
Thanks,
Update:
I was able to download the Adreno Qualcomm SDK 3.9
after searching.
Just so you know, we do not own the Qualcomm Adreno SDK so cannot give any further guidance for this.
We can help with any Mali Emulator questions you may have however.
Hi Lester,
Ok so basically the guide is directing you to download one of three possible Open GLES 3 emulators, and then point CMAKE at it so it can generate working Visual Studio projects for you. They give example paths for the Adreno SDK if extracted at C:\AdrenoSDK, but basically you should be able to download and extract any of the emulators and point CMAKE at the EGL and GLES libraries contained within. It also wants you to point it at the root directory of the examples which you can download from Dan Ginsburg's git repo, the link for which you already have. Does this make sense?
Hope that helps,
Chris
OK.
So when I open CMake, where and how do I exactly
type this command to point at the Mali emulator's EGL libraries,
in 'Search:'?
Thanks in Advance,
The guide you scanned in shows the steps, at the top of the dialog there is a field labeled "Where is the source code", fill that in and it should populate the view with all the variables it wants you to fill in. You shouldn't need to use the search as it looks like there's only 3 things to fill in.
Hth,
Hello Chris V.!
During this time I was
getting somewhat familiar with Visual Studio.
It looks like when I try to build the OpenGL examples,
I get errors and I think that's due for not having the setup
for 'environment variables' in 'advance settings' on my w7 pc.
I was able to do it with Android Studio, but still no luck with VS 2013.
I've never tried to compile this specifically but it seems like it should "just work" if you've run the CMake steps correctly. What are the errors you're seeing in VS2013?
Cheers,
Hello!
When I open CMake and locate folder it builds up the project, I believe.
I have already installed Adreno and Mali.
I am not sure what ' point CMAKE at the EGL and GLES libraries contained within the Adreno SDK' entails.
When I open the 'build folder', I click on 'Project.sln', it opens VS and this is the list of errors that I get.
For sure, I am missing a step here.
VS2013 is complaining that it can't find the include files (and therefore a bunch of undefined blah) 99% likely because you haven't set the include path to include the directory where they are stored.
The actual reason for this not just working however appears to be that you're pointing CMake at the directory for a specific example project, when you should be pointing it at the root directory of the repo you have cloned, in your case appears to be E:/OpenGL ES/opengles3-book-master/
Hi Chris,
I am missing an entry here on my end.
This is what I entered in CMake GUI
and got this error.
Les
No such issues on my end:
Give it a try with 3.3.0-rc4 (latest available on the site at time of writing) and give a different directory for "Where to build the binaries" is worth doing.
Hello Chris.
Late reply from my part.
I can get CMake to configure and generate with no errors.
But it fails to point to any specific EGL Libraries.
In Visual Studio it generates error code C1083.
Thanks in advance.
Sincerely,
les
Starting with earliest error first, I noticed you're still pointing CMake at a specific sample code, you should instead be pointing it AT THE ROOT! In your case this looks to be E:/OpenGL ES/opengles3-book-master/
Deleted all files and uploaded them again.
It looks like I may have to alter a line somewhere on the CMake list.
It also says to look into build/CmakeFiles/CmakeOutput.log.
Can't find it. Will start again.
As the error states you just need to set EGL_LIBRARY and OPENGLES3_LIBRARY in the CMake window, you've left them as EGL_LIBRARY-NOTFOUND and OPENGLES3_LIBRARY-NOTFOUND respectively.
