I create an read_write buffer on device. After computing the CL kernel I'm ready to read is back to the host, but it appears an CL_EXEC_STATUS_ERROR_FOR_EVENTS_IN_WAIT_LIST error. The documents online says:
if the read and write operations are blocking and the execution status of any of the events in event_wait_list is a negative integer value.
event_wait_list
But the event_wait_list I pass into is null and the number of event is zero. This help nothing. It runs no error in any other gpu but mali (mali-T760). What the reason cause this?
Best wishes,
phenix
Hi Phenix,
CL_EXEC_STATUS_ERROR_FOR_EVENTS_IN_WAIT_LIST means that one of the jobs in the queue failed. It's not necessarily related to the read or write operation.
Most of the time the error comes from a read or write out of bound. (Usually you can find whether it's a read or write error by checking the kernel messages in "dmesg").
If you have several kernels in the queue I would recommend removing them all and adding them back one by one to find which one causes the error.
Hope this helps,
Hi Anthony,
Thanks a lot for your help.
I have already found that this issue was appeared after compute one of kernels, but the err_code return by this NDRange is right. The problem produces again when I trying read result back to host. Is this the read error ? or how to ckeck the kernel messages in "dmesg" in the Android system ?
Thx .
Phenix.
Thanks very much.
I rewrite the code as your recommendation:
cl_event event;
cl_int status;
ret = clEnqueueNDRangeKernel(pGpuMgr->cmdQueue[0],
pNLFlt->CLKernelFNL[i].kernel,
2,MNull,
pNLFlt->CLKernelFNL[i].globalSize,
pNLFlt->CLKernelFNL[i].localSize,0,MNull,&event);
if (ret != CL_SUCCESS)
mlog("ERROR: parameters are invalid CLKernelFNL[%d] \n",i);
ss_gpuOCLErrCode(ret);
return;
ret = clWaitForEvents(1,&event);
if(ret != CL_SUCCESS){
mlog("ERROR: Failed to wait for event.\n");
ret = clGetEventInfo(event,CL_EVENT_COMMAND_EXECUTION_STATUS,sizeof(status),&status,NULL);
mlog("ERROR: Failed to get event info.\n");
if(status != CL_COMPLETE){
printf("ERROR executing the kernel %d\n",status);
and find that the error occur again after call clWaitForEvents(CL_EXEC_STATUS_ERROR_FOR_EVENTS_IN_WAIT_LIST). Can it be sure that it's caused by the kernel?
My bad, this is normal, you don't actually need to use clGetEventInfo
According to the specs for clWaitForEvents:
CL_EXEC_STATUS_ERROR_FOR_EVENTS_IN_WAIT_LIST if the execution status of any of the events in event_list is a negative integer value.
event_list
You would only need to use clGetEventInfo to find out which event failed in the case where you have several events in the queue.
I'm going to edit my previous reply to reflect that.
