Hi
I am looking for example / articles on how to perform updates to an Open GL ES texture (without using low Performing glTexSubImage2D approach) in a zero copy approach.
I am currently focused on odroid XU3 with MALI T628 running ubuntu.
I studied and tried eglcreateImageKHR approach without success (I cannot create an eglImage: error EGL_BAD_PARAMETER is returned when using EGL_NATIVE_PIXMAP_KHRas a target).
I read that MALI driver has support for UMP data transfer, but I still need a reference to the inner buffer in a openGL ES texture.
Any help needed
Andrea
There has already been several threads posted about this issue, have you had a chance to search around for a potential solution?
From a brief look at the specification, you need to ensure the device supports these two extensions at least:
KHR_image_base KHR_image_pixmap
KHR_image_base
KHR_image_pixmap
Can you confirm this is the case?
Without more information about your error, for example a code snippet or reproducer, we can only give general advice.
Hope it helps,
Michael McGeagh
Hi Michael
Sorry for my late answer but I had to buy and wait another board.
I looked around a lot but I am not successfull.
I am running on odroid xu3 (MALI T628), ubuntu 15.04, kernel with X11 enabled.
Linux odroid 3.10.72-23 #1 SMP PREEMPT Sat May 23 17:58:14 BRT 2015 armv7l armv7l armv7l GNU/Linux.
I get error 0x300c out of eglCreateImageKHR.
Basically I do the following (I attached complete source code)
1) setup EGL creating an X11 windows as argument of eglCreateWindowSurface
2) create compile and link minimum shaders to perform a texture rendering
3) create a texture
4) allocate a RGBA 8888 buffer filled with some data (vertical white bar)
5) try to create an EGLImage using eglCreateImageKHR and passing a fbdev_pixmap structure
Thanks for your help
====== TestEGLImage.cpp ======
#include "EGL/egl.h"
#define EGL_EGLEXT_PROTOTYPES
#include "EGL/eglext.h"
#include "GLES2/gl2.h"
#define GL_GLEXT_PROTOTYPES
#include "GLES2/gl2ext.h"
#include "assert.h"
#include "stdio.h"
#include "stdlib.h"
#include <unistd.h>
#include "AVWindow.h"
#include "string.h"
#define WIDTH 1280
#define HEIGHT 720
#define NCYCLES 1
EGLint g_configAttributes[] =
/* DO NOT MODIFY. */
/* These attributes are in a known order and may be re-written at initialization according to application requests. */
EGL_SAMPLES, 4,
EGL_ALPHA_SIZE, 0,
EGL_RED_SIZE, 8,
EGL_GREEN_SIZE, 8,
EGL_BLUE_SIZE, 8,
EGL_BUFFER_SIZE, 32,
EGL_STENCIL_SIZE, 0,
EGL_RENDERABLE_TYPE, 0, /* This field will be completed according to application request. */
EGL_SURFACE_TYPE, EGL_WINDOW_BIT,
EGL_DEPTH_SIZE, 16,
/* MODIFY BELOW HERE. */
/* If you need to add or override EGL attributes from above, do it below here. */
EGL_NONE
EGLint g_contextAttributes[] =
EGL_CONTEXT_CLIENT_VERSION, 0, /* This field will be completed according to application request. */
EGL_NONE, EGL_NONE, /* If we use OpenGL ES 3.1, we will have to use EGL_CONTEXT_MINOR_VERSION,
and we overwrite these fields. */
EGLConfig g_config;
EGLint g_windowAttributes[] =
* Uncomment and remove EGL_NONE above to specify EGL_RENDER_BUFFER value to eglCreateWindowSurface.
* EGL_RENDER_BUFFER, EGL_BACK_BUFFER,
* EGL_NONE
EGLConfig findConfig(EGLDisplay display)
bool strictMatch;
#if defined(__arm__)
strictMatch = true;
#else
strictMatch = false;
#endif
EGLConfig *configsArray = NULL;
EGLint numberOfConfigs = 0;
EGLBoolean success = EGL_FALSE;
/* Enumerate available EGL configurations which match or exceed our required attribute list. */
success = eglChooseConfig(display, g_configAttributes, NULL, 0, &numberOfConfigs);
if (success != EGL_TRUE)
printf("Failed to enumerate EGL configs");
exit(1);
printf("Number of configs found is %d\n", numberOfConfigs);
if (numberOfConfigs == 0)
printf("Disabling AntiAliasing to try and find a config.\n");
g_configAttributes[1] = EGL_DONT_CARE;
printf("Failed to enumerate EGL configs 2");
printf("No configs found with the requested attributes");
else
printf("Configs found when antialiasing disabled.\n ");
/* Allocate space for all EGL configs available and get them. */
configsArray = (EGLConfig *)calloc(numberOfConfigs, sizeof(EGLConfig));
success = eglChooseConfig(display, g_configAttributes, configsArray, numberOfConfigs, &numberOfConfigs);
printf("Failed to enumerate EGL configs 3");
bool matchFound = false;
int matchingConfig = -1;
if (strictMatch)
* Loop through the EGL configs to find a color depth match.
* Note: This is necessary, since EGL considers a higher color depth than requested to be 'better'
* even though this may force the driver to use a slow color conversion blitting routine.
EGLint redSize = g_configAttributes[5];
EGLint greenSize = g_configAttributes[7];
EGLint blueSize = g_configAttributes[9];
for (int configsIndex = 0; (configsIndex < numberOfConfigs) && !matchFound; configsIndex++)
EGLint attributeValue = 0;
success = eglGetConfigAttrib(display, configsArray[configsIndex], EGL_RED_SIZE, &attributeValue);
printf("Failed to get EGL attribute");
if (attributeValue == redSize)
success = eglGetConfigAttrib(display, configsArray[configsIndex], EGL_GREEN_SIZE, &attributeValue);
printf("Failed to get EGL attribute 2");
if (attributeValue == greenSize)
success = eglGetConfigAttrib(display, configsArray[configsIndex], EGL_BLUE_SIZE, &attributeValue);
printf("Failed to get EGL attribute 3");
if (attributeValue == blueSize)
matchFound = true;
matchingConfig = configsIndex;
/* If not strict we can use any matching config. */
matchingConfig = 0;
if (!matchFound)
printf("Failed to find matching EGL config");
/* Return the matching config. */
EGLConfig configToReturn = configsArray[matchingConfig];
free(configsArray);
return configToReturn;
#define _GLCheck()\
GLenum glError = glGetError(); \
if(glError != GL_NO_ERROR) \
printf ("glGetError() = %i (0x%.8x) at line %i\n", glError, glError, __LINE__); \
#define VERTEXPOS 1.0f
#define TEXTUREPOS 1.0f
GLfloat vVertices[] = {
-VERTEXPOS, VERTEXPOS, 0.0f, // Position 0
0.0f, 0.0f, // TexCoord 0
-VERTEXPOS, -VERTEXPOS, 0.0f, // Position 1
0.0f, TEXTUREPOS, // TexCoord 1
VERTEXPOS, -VERTEXPOS, 0.0f, // Position 2
TEXTUREPOS, TEXTUREPOS, // TexCoord 2
VERTEXPOS, VERTEXPOS, 0.0f, // Position 3
TEXTUREPOS, 0.0f, // TexCoord 3
const GLushort indices[] = { 0, 1, 2, 0, 2, 3 };
const char _VShaderSource_Blender[] =
"attribute vec4 a_position; \n"
"attribute vec2 a_texCoord; \n"
"varying vec2 v_texCoord; \n"
"void main() \n"
"{ \n"
" gl_Position = a_position; \n"
" v_texCoord = a_texCoord; \n"
"} \n";
const char _FShaderSource_Blender[] =
"precision mediump float; \n"
"uniform sampler2D InputTex; \n"
" \n"
"void main(void) \n"
" //gl_FragColor=texture2D(InputTex,v_texCoord); \n"
" vec4 col=texture2D(InputTex,v_texCoord); \n"
" gl_FragColor=vec4(col.b, col.g, col.r, col.a); \n"
void UploadTexture_UsingTextSubImage2D(unsigned char *InPicture, GLuint _iTex)
glActiveTexture(GL_TEXTURE0);
glPixelStorei(GL_UNPACK_ALIGNMENT, 1);
glBindTexture(GL_TEXTURE_2D, _iTex);
glTexSubImage2D(GL_TEXTURE_2D, 0, 0, 0, WIDTH, HEIGHT, GL_RGBA, GL_UNSIGNED_BYTE, InPicture);
_GLCheck();
typedef enum
FBDEV_PIXMAP_DEFAULT = 0,
FBDEV_PIXMAP_SUPPORTS_UMP = (1 << 0),
FBDEV_PIXMAP_ALPHA_FORMAT_PRE = (1 << 1),
FBDEV_PIXMAP_COLORSPACE_sRGB = (1 << 2),
FBDEV_PIXMAP_EGL_MEMORY = (1 << 3) /* EGL allocates/frees this memory */
} fbdev_pixmap_flags;
typedef struct fbdev_window
unsigned short width;
unsigned short height;
} fbdev_window;
typedef struct fbdev_pixmap
unsigned int height;
unsigned int width;
unsigned int bytes_per_pixel;
unsigned char buffer_size;
unsigned char red_size;
unsigned char green_size;
unsigned char blue_size;
unsigned char alpha_size;
unsigned char luminance_size;
fbdev_pixmap_flags flags;
unsigned short *data;
unsigned int format; /* extra format information in case rgbal is not enough, especially for YUV formats */
} fbdev_pixmap;
void UploadTexture_UsingEGLImage(EGLDisplay sEGLDisplay, EGLContext sEGLContext, unsigned char *InPicture, GLuint _iTex)
fbdev_pixmap pixmap;
pixmap.height = HEIGHT;
pixmap.width = WIDTH;
pixmap.bytes_per_pixel = 4;
pixmap.buffer_size = 32;
pixmap.red_size = 8;
pixmap.green_size = 8;
pixmap.blue_size = 8;
pixmap.alpha_size = 8;
pixmap.luminance_size = 0;
pixmap.flags = FBDEV_PIXMAP_DEFAULT;
pixmap.data = (unsigned short*)InPicture;
pixmap.format = 1;
EGLImageKHR eglImage = eglCreateImageKHR(sEGLDisplay, sEGLContext, EGL_NATIVE_PIXMAP_KHR, &pixmap, NULL);
EGLint eglError = eglGetError();
if (eglError != EGL_SUCCESS)
printf("eglGetError() = %i (0x%.8x) at line %i\n", eglError, eglError, __LINE__);
glEGLImageTargetTexture2DOES(GL_TEXTURE_2D, eglImage);
int main(int argc, char **argv)
CAVWindow wind;
EGLDisplay m_sEGLDisplay;
EGLSurface m_sEGLSurface;
EGLContext m_sEGLContext;
EGLint major, minor;
GLuint m_iVShader, m_iFShader;
GLuint m_iProgram;
GLint m_iLocPosition;
GLint m_iLocTexCoord;
GLint iStatus;
m_sEGLDisplay = eglGetDisplay(EGL_DEFAULT_DISPLAY); assert(m_sEGLDisplay != EGL_NO_DISPLAY);
EGLBoolean success = eglInitialize(m_sEGLDisplay, &major, &minor); assert(success == EGL_TRUE);
printf ("major=%d, minor = %d\n", major, minor );
g_configAttributes[15] = EGL_OPENGL_ES2_BIT;
g_contextAttributes[1] = 2;
g_contextAttributes[2] = EGL_NONE;
g_config = findConfig(m_sEGLDisplay);
wind.CreaFinestra(WIDTH, HEIGHT, L"testEGLImage", 0, 0, m_sEGLDisplay, g_config);
m_sEGLSurface = eglCreateWindowSurface(m_sEGLDisplay, g_config, (EGLNativeWindowType)wind.GethWnd(), g_windowAttributes); assert(m_sEGLSurface != EGL_NO_SURFACE);
eglBindAPI(EGL_OPENGL_ES_API);
m_sEGLContext = eglCreateContext(m_sEGLDisplay, g_config, EGL_NO_CONTEXT, g_contextAttributes); assert(m_sEGLContext != EGL_NO_CONTEXT);
eglMakeCurrent(m_sEGLDisplay, m_sEGLSurface, m_sEGLSurface, m_sEGLContext);
printf ("Vendor =%s\n", eglQueryString(m_sEGLDisplay, EGL_VENDOR));
printf ("API =%s\n", eglQueryString(m_sEGLDisplay, EGL_CLIENT_APIS));
printf ("Version=%s\n", eglQueryString(m_sEGLDisplay, EGL_VERSION));
printf ("Extens =%s\n", eglQueryString(m_sEGLDisplay, EGL_EXTENSIONS));
const GLubyte *strExt = glGetString(GL_EXTENSIONS);
printf("GL_EXTENSIONS: %s\n", strExt);
glDisable(GL_CULL_FACE);
glDisable(GL_DEPTH_TEST);
glDisable(GL_DITHER);
glDisable(GL_POLYGON_OFFSET_FILL);
glDisable(GL_SAMPLE_ALPHA_TO_COVERAGE);
glDisable(GL_SAMPLE_COVERAGE);
glDisable(GL_SCISSOR_TEST);
glDisable(GL_STENCIL_TEST);
glEnable(GL_BLEND);
glBlendFunc(GL_SRC_ALPHA, GL_ONE_MINUS_SRC_ALPHA);
m_iVShader = glCreateShader(GL_VERTEX_SHADER);
m_iFShader = glCreateShader(GL_FRAGMENT_SHADER);
const char *pVShader = _VShaderSource_Blender;
const char *pFShader = _FShaderSource_Blender;
glShaderSource(m_iVShader, 1, &pVShader, NULL);
glShaderSource(m_iFShader, 1, &pFShader, NULL);
glCompileShader(m_iVShader);
glGetShaderiv(m_iVShader, GL_COMPILE_STATUS, &iStatus); assert(iStatus != GL_FALSE);
glCompileShader(m_iFShader);
glGetShaderiv(m_iFShader, GL_COMPILE_STATUS, &iStatus);assert(iStatus != GL_FALSE);
m_iProgram = glCreateProgram();
glAttachShader(m_iProgram, m_iVShader);
glAttachShader(m_iProgram, m_iFShader);
glLinkProgram(m_iProgram);
m_iLocPosition = glGetAttribLocation(m_iProgram, "a_position");
m_iLocTexCoord = glGetAttribLocation(m_iProgram, "a_texCoord");
GLuint iTex;
glGenTextures(1, &iTex);
glBindTexture(GL_TEXTURE_2D, iTex);
glTexImage2D(GL_TEXTURE_2D, 0, GL_RGBA, WIDTH, HEIGHT, 0, GL_RGBA, GL_UNSIGNED_BYTE, NULL);
glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_MIN_FILTER, GL_NEAREST);
glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_MAG_FILTER, GL_NEAREST);
glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_WRAP_S, GL_CLAMP_TO_EDGE);
glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_WRAP_T, GL_CLAMP_TO_EDGE);
unsigned char *TexData = new unsigned char[WIDTH * HEIGHT * 4];
for (int iCycles = 0; iCycles < NCYCLES; iCycles++)
memset(TexData, 0, WIDTH * HEIGHT * 4);
for (int y = 0; y < HEIGHT; y++)
for (int x = iCycles; x < iCycles + 16; x++)
TexData[y * WIDTH * 4 + 4 * x + 0] = 255;
TexData[y * WIDTH * 4 + 4 * x + 1] = 255;
TexData[y * WIDTH * 4 + 4 * x + 2] = 255;
TexData[y * WIDTH * 4 + 4 * x + 3] = 255;
//UploadTexture_UsingTextSubImage2D(TexData, iTex);
UploadTexture_UsingEGLImage(m_sEGLDisplay, m_sEGLContext, TexData, iTex);
//draw
glUseProgram(m_iProgram);
GLint BlenderSamplerLocInput = glGetUniformLocation(m_iProgram, "InputTex");
glVertexAttribPointer(m_iLocTexCoord, 2, GL_FLOAT, GL_FALSE, 5 * sizeof(GLfloat), &vVertices[3]);
glEnableVertexAttribArray(m_iLocTexCoord);
glUniform1i(BlenderSamplerLocInput, 0);
glVertexAttribPointer(m_iLocPosition, 3, GL_FLOAT, GL_FALSE, 5 * sizeof(GLfloat), vVertices);
glEnableVertexAttribArray(m_iLocPosition);
glDrawElements(GL_TRIANGLES, 6, GL_UNSIGNED_SHORT, indices);
if (!eglSwapBuffers(m_sEGLDisplay, m_sEGLSurface))
printf("Failed to swap buffers.\n");
printf("typer enter\n");
getchar();
delete[] TexData;
//glClearColor(1.0, 1.0, 0.0, 1.0);
//glClear(GL_COLOR_BUFFER_BIT);
//glFlush();
//eglSwapBuffers(m_sEGLDisplay, m_sEGLSurface);
return 0;
====== AVWindow.h (create x11 window) =======
#pragma once
#include "os_types.h"
#include <string>
#ifdef _WIN32
#ifndef WIN32_LEAN_AND_MEAN
#define WIN32_LEAN_AND_MEAN 1
#include <windows.h>
#include "CBaseThread.h"
class IAVWindowCBF
public:
virtual void OnEnd() {};
class CAVWindow : public CBaseThread
int m_cx, m_cy, m_PosX, m_PosY;
std::wstring m_windowName;
HWND m_hwnd;
void OnInit()
const HINSTANCE hInstance = NULL;
WNDCLASS wc;
* set up and register window class
wc.style = CS_HREDRAW | CS_VREDRAW;
wc.lpfnWndProc = WindowProc;
wc.cbClsExtra = 0;
wc.cbWndExtra = 0;
wc.hInstance = hInstance;
wc.hIcon = LoadIcon(hInstance, IDI_APPLICATION);
wc.hCursor = LoadCursor(NULL, IDC_ARROW);
wc.hbrBackground = NULL;
wc.lpszMenuName = NULL;
wc.lpszClassName = m_windowName.c_str();
RegisterClass(&wc);
* create a window
RECT rc = { 0, 0, m_cx, m_cy };
AdjustWindowRect(&rc, WS_OVERLAPPEDWINDOW, FALSE);
m_hwnd = CreateWindowEx(
NULL,
m_windowName.c_str(),
m_PosX,
m_PosY,
rc.right - rc.left,
rc.bottom - rc.top,
hInstance,
NULL);
assert(m_hwnd);
SetWindowLongPtr(m_hwnd, GWLP_USERDATA, (LONG)this);
ShowWindow(m_hwnd, SW_SHOW);
void DoLoop()
MSG Msg;
//here we force queue creation. Very important, this must be done before sending any message...
PeekMessage(&Msg, NULL, WM_USER, WM_USER, PM_NOREMOVE);
while (GetMessage(&Msg, NULL, 0, 0))
TranslateMessage(&Msg);
DispatchMessage(&Msg);
void OnEnd()
DestroyWindow(m_hwnd);
static LRESULT CALLBACK WindowProc(HWND hWnd, UINT message, WPARAM wParam, LPARAM lParam)
CAVWindow *pThis = (CAVWindow *)GetWindowLongPtr(hWnd, GWLP_USERDATA);
long r = pThis->MyWindowProc(hWnd, message, wParam, lParam);
return r;
long MyWindowProc(HWND hWnd, UINT message, WPARAM wParam, LPARAM lParam)
switch (message)
case WM_CLOSE:
//PostQuitMessage(0);
case WM_PAINT:
return 0; //break;
return (long)DefWindowProc(hWnd, message, wParam, lParam);
CAVWindow()
m_hwnd = NULL;
~CAVWindow()
void CreaFinestra(int cx, int cy, const std::wstring &wName, int posx, int posy)
m_cx = cx;
m_cy = cy;
m_windowName = wName;
m_PosX = posx;
m_PosY = posy;
Start();
void ChiudiFinestra()
if (m_bThreadRunning)
PostThreadMessage(m_ThreadId, WM_QUIT, 0, 0);
WaitThreadEnded();
HWND GethWnd()
return m_hwnd;
#include <stdio.h>
#include <stdlib.h>
#include <X11/Xlib.h>
class CAVWindow
Colormap m_colormap;
XVisualInfo *m_visual;
Window m_window;
Display* m_display;
static Bool wait_for_map(Display *display, XEvent *event, char *windowPointer)
return (event->type == MapNotify && event->xmap.window == (*((Window*)windowPointer)));
void CreaFinestra(int windowWidth, int windowHeight, const std::wstring &wName, int posx, int posy, EGLDisplay eglDisplay, EGLConfig config)
XSetWindowAttributes windowAttributes;
XSizeHints sizeHints;
XEvent event;
XVisualInfo visualInfoTemplate;
unsigned long mask;
long screen;
int visualID, numberOfVisuals;
m_display = XOpenDisplay(NULL);
screen = DefaultScreen(m_display);
eglGetConfigAttrib(eglDisplay, config, EGL_NATIVE_VISUAL_ID, &visualID);
visualInfoTemplate.visualid = visualID;
m_visual = XGetVisualInfo(m_display, VisualIDMask, &visualInfoTemplate, &numberOfVisuals);
if (m_visual == NULL)
printf("Couldn't get X visual info\n");
throw "Couldn't get X visual info";
m_colormap = XCreateColormap(m_display, RootWindow(m_display, screen), m_visual->visual, AllocNone);
windowAttributes.colormap = m_colormap;
windowAttributes.background_pixel = 0xFFFFFFFF;
windowAttributes.border_pixel = 0;
windowAttributes.event_mask = StructureNotifyMask | ExposureMask;
mask = CWBackPixel | CWBorderPixel | CWEventMask | CWColormap;
m_window = XCreateWindow(m_display, RootWindow(m_display, screen), 0, 0, windowWidth, windowHeight,
0, m_visual->depth, InputOutput, m_visual->visual, mask, &windowAttributes);
sizeHints.flags = USPosition;
sizeHints.x = 10;
sizeHints.y = 10;
XSetStandardProperties(m_display, m_window, "Mali OpenGL ES SDK", "", None, 0, 0, &sizeHints);
XMapWindow(m_display, m_window);
XIfEvent(m_display, &event, wait_for_map, (char*)(&m_window));
XSetWMColormapWindows(m_display, m_window, &m_window, 1);
XFlush(m_display);
XSelectInput(m_display, m_window, KeyPressMask | ExposureMask | EnterWindowMask
| LeaveWindowMask | PointerMotionMask | VisibilityChangeMask | ButtonPressMask
| ButtonReleaseMask | StructureNotifyMask);
XDestroyWindow(m_display, m_window);
XFreeColormap(m_display, m_colormap);
XFree(m_visual);
XCloseDisplay(m_display);
return (unsigned long)m_window;
I forgot to attach output of the application, where can be seen that extensions required are available on this platform
major=1, minor = 4
Number of configs found is 2
Vendor =ARM
API =OpenGL_ES
Version=1.4 Midgard-"r5p1-00rel1"
Extens =EGL_KHR_config_attribs EGL_KHR_image EGL_KHR_image_base EGL_KHR_fence_sync EGL_KHR_wait_sync EGL_KHR_gl_colorspace EGL_KHR_get_all_proc_addresses EGL_ARM_pixmap_multisample_discard EGL_KHR_gl_texture_2D_image EGL_KHR_gl_renderbuffer_image EGL_KHR_create_context EGL_KHR_surfaceless_context EGL_KHR_gl_texture_cubemap_image EGL_KHR_cl_event2 EGL_KHR_image_pixmap
GL_EXTENSIONS: GL_ARM_rgba8 GL_ARM_mali_shader_binary GL_OES_depth24 GL_OES_depth_texture GL_OES_depth_texture_cube_map GL_OES_packed_depth_stencil GL_OES_rgb8_rgba8 GL_EXT_read_format_bgra GL_OES_compressed_paletted_texture GL_OES_compressed_ETC1_RGB8_texture GL_OES_standard_derivatives GL_OES_EGL_image GL_OES_EGL_image_external GL_OES_EGL_sync GL_OES_texture_npot GL_OES_vertex_half_float GL_OES_required_internalformat GL_OES_vertex_array_object GL_OES_mapbuffer GL_EXT_texture_format_BGRA8888 GL_EXT_texture_rg GL_EXT_texture_type_2_10_10_10_REV GL_OES_fbo_render_mipmap GL_OES_element_index_uint GL_EXT_shadow_samplers GL_OES_texture_compression_astc GL_KHR_texture_compression_astc_ldr GL_KHR_texture_compression_astc_hdr GL_KHR_debug GL_EXT_occlusion_query_boolean GL_EXT_disjoint_timer_query GL_EXT_blend_minmax GL_EXT_discard_framebuffer GL_OES_get_program_binary GL_OES_texture_3D GL_EXT_texture_storage GL_EXT_multisampled_render_to_texture GL_OES_surfaceless_context GL_OES_texture_stencil8 GL_EXT_shader_pixel_local_storage GL_ARM_shader_framebuffer_fetch GL_ARM_shader_framebuffer_fetch_depth_stencil GL_ARM_mali_program_binary GL_EXT_sRGB GL_EXT_sRGB_write_control GL_EXT_texture_sRGB_decode GL_KHR_blend_equation_advanced GL_OES_texture_storage_multisample_2d_array GL_OES_shader_image_atomic
eglGetError() = 12300 (0x0000300c) at line 252
glGetError() = 1282 (0x00000502) at line 257
I also tried to use a XPixMap but nope....
instead of performing
I tried the following
Where can I find source code for libmali.so (ARM Mali Midgard GPU User Space Drivers Release r5p0-06rel0 MALI for T628)? I whould like to debug why I am not able to create an EGLImage.
Hi andrea.varesio,
Regarding your sample code, thank you for providing that. I have created a ticket so we can begin investigating further. I cannot give you an ETA however, but will try to update you periodically on the progress.
Regarding your source code question, although the kernel side component of the Mali driver is open source and under GPL, the user space side is not, and proprietary. As such, the source code is not accessible to anyone without legal contracts in place.
Typically this is a standard procedure for our licensees and partners. If you are one of those, I would advise going through the proper ARM channels to secure the source code.
However if you are not, and still would like access, we can begin talks regarding costs and licensing with the appropriate people.
I hope that clarifies things for you.
If you have any further questions, please do not hesitate to ask.
Kind Regards,
A colleague has pointed me to this thread: How to share texture memory between CPU/GPU for firefly's/rk3288 fbdev Mali-T764
The required parts needed is currently not available in the driver version r5pX, but should be available to you in the next release.
Please note that when we release new drivers, there may be a delay before our partners decide to update their BSPs such as HardKernel in your example, and this is out of our control. As such I am unable to give you an accurate estimate on how long it would take before the update is available to you.
Thanks a lot Michael
First of all I cleaned my source code and commited to git
https://github.com/andreavaresio/testEGLImage.git.
Then I was able to step forward: eglCreateImageKHR now works, but I am
still not able to draw texture changes to screen.
In order to have eglCreateImageKHR working I had to invert intialisation
sequence: instead of setting up EGL with defaults and try to create a X11
Pixmap according to egl parameters (as is suggested in ARM SDK), I reversed
the order. I initialised X according to default screen and setup egl
according to X parameters.
When I try to run the code in mode 1 (changes to Pixmap are performed using
a memcpy) no changes are drawn on the screen.
When I try to run the code in mode 2 (changes to Pixmap are performed
using XFillRectangle) eglSwapBuffer return with error 0x3000d
The thread you pointed me to refers to fbdev driver version, I am using X11
driver.
Regarding the driver (I am not an expert ...). As far as I read r5p1-00rel1
has DMA_BUF implementation. In my understaning this means ability to
perform scatter and gather memory transfer, i.e. ability to copy buffers in
virtual memory.
So which feature is needed in the driver in order to perform zero copy
rendering?
Andrea Varesio
2015-06-04 16:32 GMT+02:00 ARM Connected Community Admin <community@arm.com>
<http://community.arm.com/?et=notification.mention> You have beenmentionedby Michael McGeagh<http://community.arm.com/people/mcgeagh?et=notification.mention> *in Re:Rendering using OpenGL ES 2.0/3.0 in a zero copy mode on MALI T628 in ARMConnected Community* - View Michael McGeagh's reference to you<http://community.arm.com/message/28304?et=notification.mention#28304>
mentioned
by Michael McGeagh
I tried fbdev user space driver on xu3.
Issues:
1) There is a unacceptable tear-off effect, even with a very simple texture.
2) no way to create an an EGLImage
I resolved tear effect running x11 full screen
still no way to have eglCreateImageKHR working. Waiting for new driver release
