Hi all,
recently I wanted to use a brand new Topaz image processing program on my PC.
Could not because of an OPENGL error saying OpenGL 3.3+ needed !
As you can see on screenshot, the version detected is much earlier.
My question is : Must I update my GPU card or do I need to do something else ?
If it is the GPU, how to check that another one I could buy on Internet would be fine ?
Thanks !
Notes :
(I tried Mali cube sorfware ... run time error)
Here is some PC detail :
--------[ Résumé ]------------------------------------------------------------------------------------------------------ Ordinateur: Type de système ACPI x64-based PC Système d'exploitation Windows 7 Professional Media Center Edition Internet Explorer 9.11.9600.19155 DirectX DirectX 10.0 Date / Heure 2020-11-29 / 14:07 Carte mère: Type de processeur QuadCore Intel Bloomfield, 3066 MHz (23 x 133) Nom de la carte mère /Inconnu/ P6T Chipset de la carte mère Intel Tylersburg X58, Intel Nehalem Mémoire système / [ TRIAL VERSION ]/ 18 GB Type de BIOS AMI (09/21/10) Port de communication High-Speed PCI Serial Port (COM40) Port de communication High-Speed PCI Serial Port (COM41) Port de communication PCI ECP Parallel Port (LPT2) Moniteur: Carte vidéo ATI Radeon HD 5700 Series (Engineering Sample - WDDM v1.20) (1024 Mo) Moniteur Acer P243W [24" LCD] (LAF040067210) Moniteur Generic PnP Monitor [NoDB] (200520090129)
It's always worth trying newer drivers, but the Radeon 5700 was released in 2009, so its unlikely to be getting much in the way of new driver support. Most vendors will list the level of OpenGL support on the product pages.
Cheers,Pete
