Camera feed not showing on Mali-based chips
We are developing Augmented Reality applications using Godot engine and we have integrated ARCore. We can successfully deploy an application on Android, and on devices based on Mali GPU (G71 etc), the camera feed is black (not showing) on the device screen, but it is tracking the space. On Adreno-based chips works perfectly,
Anyone with an advice?
  • Hi Peter,
    Here are more information.
    We are using godot engine with ARCore integrated. On the devices with Mali G7x GPU we are getting the error below when the API tries to capture camera texture.
    Attached is also GLSL shader.
    Hope I provided sufficient info to initiate an idea what might be the problem.
    I appreciated your response,
    Cheers,
    Nikola
    shader.txt
    /* clang-format off */
    [vertex]
    layout(location = 0) in highp vec4 vertex_attrib;
    /* clang-format on */
    #if defined(USE_CUBEMAP) || defined(USE_PANORAMA)
    layout(location = 4) in vec3 cube_in;
    #else
    layout(location = 4) in vec2 uv_in;
    #endif
    layout(location = 5) in vec2 uv2_in;
    out vec3 cube_interp;
    #else
    out vec2 uv_interp;
    #endif
    out vec2 uv2_interp;
    // These definitions are here because the shader-wrapper builder does
    // not understand `#elif defined()`
    #ifdef USE_DISPLAY_TRANSFORM
    #endif
    #ifdef USE_COPY_SECTION
    uniform vec4 copy_section;
    #elif defined(USE_DISPLAY_TRANSFORM)
    uniform highp mat4 display_transform;
    #endif
    void main() {
    	cube_interp = cube_in;
    #elif defined(USE_ASYM_PANO)
    	uv_interp = vertex_attrib.xy;
    #else
    	uv_interp = uv_in;
    #ifdef V_FLIP
    	uv_interp.y = 1.0 - uv_interp.y;
    #endif
    #endif
    	uv2_interp = uv2_in;
    	gl_Position = vertex_attrib;
    	uv_interp = copy_section.xy + uv_interp * copy_section.zw;
    	gl_Position.xy = (copy_section.xy + (gl_Position.xy * 0.5 + 0.5) * copy_section.zw) * 2.0 - 1.0;
    	uv_interp = (display_transform * vec4(uv_in, 1.0, 1.0)).xy;
    #endif
    [fragment]
    #ifdef USE_EXTERNAL_SAMPLER
    // Leave the ifdef so we have this define, for now the extension is loaded through custom defines
    // #extension GL_OES_EGL_image_external_essl3 : require
    #endif
    #define M_PI 3.14159265359
    #if !defined(USE_GLES_OVER_GL)
    precision mediump float;
    #endif
    in vec3 cube_interp;
    #else
    in vec2 uv_interp;
    #endif
    #ifdef USE_ASYM_PANO
    uniform highp mat4 pano_transform;
    uniform highp vec4 asym_proj;
    #endif
    #ifdef USE_TEXTURE3D
    #endif
    #ifdef USE_TEXTURE2DARRAY
    #endif
    #ifdef YCBCR_TO_SRGB
    #endif
    #ifdef USE_CUBEMAP
    uniform samplerCube source_cube; //texunit:0
    #elif defined(USE_TEXTURE3D)
    uniform sampler3D source_3d; //texunit:0
    #elif defined(USE_TEXTURE2DARRAY)
    uniform sampler2DArray source_2d_array; //texunit:0
    #elif defined(USE_EXTERNAL_SAMPLER)
    uniform samplerExternalOES source;
    #else
    uniform sampler2D source; //texunit:0
    #endif
    #ifdef SEP_CBCR_TEXTURE
    uniform sampler2D CbCr; //texunit:1
    #endif
    #ifdef USE_LOD
    uniform float mip_level;
    #endif
    #if defined(USE_TEXTURE3D) || defined(USE_TEXTURE2DARRAY)
    uniform float layer;
    #endif
    #ifdef USE_MULTIPLIER
    uniform float multiplier;
    #endif
    #if defined(USE_PANORAMA) || defined(USE_ASYM_PANO)
    uniform highp mat4 sky_transform;
    vec4 texturePanorama(vec3 normal, sampler2D pano) {
    	vec2 st = vec2(
    			atan(normal.x, normal.z),
    			acos(normal.y));
    	if (st.x < 0.0)
    		st.x += M_PI * 2.0;
    	st /= vec2(M_PI * 2.0, M_PI);
    	return textureLod(pano, st, 0.0);
    #endif
    uniform vec2 pixel_size;
    in vec2 uv2_interp;
    #ifdef USE_BCS
    uniform vec3 bcs;
    #endif
    #ifdef USE_COLOR_CORRECTION
    uniform sampler2D color_correction; //texunit:1
    #endif
    layout(location = 0) out vec4 frag_color;
    void main() {
    	//vec4 color = color_interp;
    #ifdef USE_PANORAMA
    	vec3 cube_normal = normalize(cube_interp);
    	cube_normal.z = -cube_normal.z;
    	cube_normal = mat3(sky_transform) * cube_normal;
    	vec4 color = texturePanorama(cube_normal, source);
    	// When an asymmetrical projection matrix is used (applicable for stereoscopic rendering i.e. VR) we need to do this calculation per fragment to get a perspective correct result.
    	// Asymmetrical projection means the center of projection is no longer in the center of the screen but shifted.
    	// The Matrix[2][0] (= asym_proj.x) and Matrix[2][1] (= asym_proj.z) values are what provide the right shift in the image.
    	vec3 cube_normal;
    	cube_normal.z = -1.0;
    	cube_normal.x = (cube_normal.z * (-uv_interp.x - asym_proj.x)) / asym_proj.y;
    	cube_normal.y = (cube_normal.z * (-uv_interp.y - asym_proj.z)) / asym_proj.a;
    	cube_normal = mat3(sky_transform) * mat3(pano_transform) * cube_normal;
    	vec4 color = texturePanorama(normalize(cube_normal.xyz), source);
    #elif defined(USE_CUBEMAP)
    	vec4 color = texture(source_cube, normalize(cube_interp));
    	vec4 color = textureLod(source_3d, vec3(uv_interp, layer), 0.0);
    	vec4 color = textureLod(source_2d_array, vec3(uv_interp, layer), 0.0);
    #elif defined(SEP_CBCR_TEXTURE)
    	vec4 color;
    	color.r = textureLod(source, uv_interp, 0.0).r;
    	color.gb = textureLod(CbCr, uv_interp, 0.0).rg - vec2(0.5, 0.5);
    	color.a = 1.0;
    #else
    #ifdef USE_LOD
    	vec4 color = textureLod(source, uv_interp, mip_level);
    #else
    	vec4 color = textureLod(source, uv_interp, 0.0);
    #endif
    #endif
    #ifdef LINEAR_TO_SRGB
    	// regular Linear -> SRGB conversion
    	vec3 a = vec3(0.055);
    	color.rgb = mix((vec3(1.0) + a) * pow(color.rgb, vec3(1.0 / 2.4)) - a, 12.92 * color.rgb, lessThan(color.rgb, vec3(0.0031308)));
    #elif defined(YCBCR_TO_SRGB)
    	// YCbCr -> SRGB conversion
    	// Using BT.709 which is the standard for HDTV
    	color.rgb = mat3(
    						vec3(1.00000, 1.00000, 1.00000),
    						vec3(0.00000, -0.18732, 1.85560),
    						vec3(1.57481, -0.46813, 0.00000)) *
    				color.rgb;
    #endif
    #ifdef SRGB_TO_LINEAR
    	color.rgb = mix(pow((color.rgb + vec3(0.055)) * (1.0 / (1.0 + 0.055)), vec3(2.4)), color.rgb * (1.0 / 12.92), lessThan(color.rgb, vec3(0.04045)));
    #endif
    #ifdef DEBUG_GRADIENT
    	color.rg = uv_interp;
    	color.b = 0.0;
    #endif
    #ifdef DISABLE_ALPHA
    	color.a = 1.0;
    #endif
    #ifdef GAUSSIAN_HORIZONTAL
    	color *= 0.38774;
    	color += texture(source, uv_interp + vec2(1.0, 0.0) * pixel_size) * 0.24477;
    	color += texture(source, uv_interp + vec2(2.0, 0.0) * pixel_size) * 0.06136;
    	color += texture(source, uv_interp + vec2(-1.0, 0.0) * pixel_size) * 0.24477;
    	color += texture(source, uv_interp + vec2(-2.0, 0.0) * pixel_size) * 0.06136;
    #endif
    #ifdef GAUSSIAN_VERTICAL
    	color *= 0.38774;
    	color += texture(source, uv_interp + vec2(0.0, 1.0) * pixel_size) * 0.24477;
    	color += texture(source, uv_interp + vec2(0.0, 2.0) * pixel_size) * 0.06136;
    	color += texture(source, uv_interp + vec2(0.0, -1.0) * pixel_size) * 0.24477;
    	color += texture(source, uv_interp + vec2(0.0, -2.0) * pixel_size) * 0.06136;
    #endif
    #ifdef USE_BCS
    	color.rgb = mix(vec3(0.0), color.rgb, bcs.x);
    	color.rgb = mix(vec3(0.5), color.rgb, bcs.y);
    	color.rgb = mix(vec3(dot(vec3(1.0), color.rgb) * 0.33333), color.rgb, bcs.z);
    #endif
    	color.r = texture(color_correction, vec2(color.r, 0.0)).r;
    	color.g = texture(color_correction, vec2(color.g, 0.0)).g;
    	color.b = texture(color_correction, vec2(color.b, 0.0)).b;
    #endif
    	color.rgb *= multiplier;
    #endif
    	frag_color = color;
  • Hi Peter,
    Cheers,
    Nikola
    shader.txt
    [vertex]
    #else
    #endif
    #else
    out vec2 uv_interp;
    #endif
    #endif
    #endif
    void main() {
    #else
    	uv_interp = uv_in;
    #ifdef V_FLIP
    #endif
    #endif
    #endif
    [fragment]
    #endif
    #endif
    #else
    in vec2 uv_interp;
    #endif
    #endif
    #endif
    #endif
    #endif
    #ifdef USE_CUBEMAP
    #else
    #endif
    #endif
    #ifdef USE_LOD
    #endif
    #endif
    #endif
    	vec2 st = vec2(
    			acos(normal.y));
    	if (st.x < 0.0)
    		st.x += M_PI * 2.0;
    #endif
    in vec2 uv2_interp;
    #ifdef USE_BCS
    uniform vec3 bcs;
    #endif
    #endif
    void main() {
    #ifdef USE_PANORAMA
    	vec3 cube_normal;
    	vec4 color;
    	color.a = 1.0;
    #else
    #ifdef USE_LOD
    #else
    #endif
    #endif
    	color.rgb = mat3(
    				color.rgb;
    #endif
    #endif
    	color.b = 0.0;
    #endif
    	color.a = 1.0;
    #endif
    	color *= 0.38774;
    #endif
    	color *= 0.38774;
    #endif
    #ifdef USE_BCS
    #endif
    #endif
    #endif
    	frag_color = color;
