I downloaded mali graphics debugger v2.0 for win7 32bit, but i can't capture any data after setting up host and target following the MGD user guide, what should i do?
In your explanation, you didnt mention a reboot of the device.
You will need to reboot the device once you have installed the interceptor library, libGLES_mgd.so.
If this doesnt help, then please let us know what the output from the daemon is when you connect the UI and try to run your target app.
Kind Regards,
Michael McGeagh
The 4th step in the detailed description is rebooting the target system. And in the logcat output I found this entry: D/libEGL ( 4630): loaded /system/lib/egl/libGLES_mali.so. I think this means the interceptor library is loaded by the system, but MGD on host still got nothing.
Below is the output of logcat FROM the start of MGDDaemon.apk TO the full startup of an 3D game app:
130|root@m201:/system/lib/egl # logcat -c
--------- beginning of /dev/log/system
I/ActivityManager( 967): START u0 {act=android.intent.action.MAIN cat=[android.intent.category.LAUNCHER] flg=0x10200000 cmp=com.arm.mgd.mgddaemon/.MainActivity} from pid 2988
I/ActivityManager( 967): start package name is com.arm.mgd.mgddaemon, class name is com.arm.mgd.mgddaemon.MainActivity, error code is 0
[ 6057.562705@0] video_disable_store(2)
[ 6057.562747@0] DisableVideoLayer()
[ 6057.571261@0] VsyncDisableVideoLayer
--------- beginning of /dev/log/main
D/MediaBoxLauncher( 2988): ------onPause
I/ActivityManager( 967): Start proc com.arm.mgd.mgddaemon for activity com.arm.mgd.mgddaemon/.MainActivity: pid=4852 uid=10047 gids={50047, 3003}
D/dalvikvm( 4852): GC_CONCURRENT freed 207K, 25% free 723K/960K, paused 2ms+4ms, total 9ms
D/dalvikvm( 4852): GC_CONCURRENT freed 175K, 18% free 935K/1140K, paused 1ms+0ms, total 6ms
D/dalvikvm( 4852): GC_CONCURRENT freed 200K, 18% free 1128K/1360K, paused 2ms+6ms, total 16ms
I/InputDispatcher( 967): Dropping event because there is no touchable window at (411, 519).
D/TextLayoutCache( 4852): Using debug level = 0 - Debug Enabled = 0
W/MGD App List View( 4852): AppListFragment.onCreateView
D/dalvikvm( 4852): GC_FOR_ALLOC freed 35K, 7% free 1404K/1504K, paused 6ms, total 6ms
D/dalvikvm( 4852): GC_CONCURRENT freed 33K, 4% free 1787K/1848K, paused 0ms+4ms, total 11ms
I/InputDispatcher( 967): Dropping event because there is no touchable window at (413, 518).
I/InputDispatcher( 967): Dropping event because there is no touchable window at (415, 518).
I/InputDispatcher( 967): Dropping event because there is no touchable window at (418, 516).
I/InputDispatcher( 967): Dropping event because there is no touchable window at (421, 515).
I/InputDispatcher( 967): Dropping event because there is no touchable window at (424, 513).
V/MGD GL Info View( 4852): Creating new GL View
I/InputDispatcher( 967): Dropping event because there is no touchable window at (427, 512).
I/InputDispatcher( 967): Dropping event because there is no touchable window at (431, 510).
I/InputDispatcher( 967): Dropping event because there is no touchable window at (436, 508).
E/MGD App List View( 4852): Repopulating application list.
I/InputDispatcher( 967): Dropping event because there is no touchable window at (440, 506).
I/InputDispatcher( 967): Dropping event because there is no touchable window at (444, 503).
I/InputDispatcher( 967): Dropping event because there is no touchable window at (450, 500).
I/InputDispatcher( 967): Dropping event because there is no touchable window at (456, 498).
I/InputDispatcher( 967): Dropping event because there is no touchable window at (461, 493).
I/InputDispatcher( 967): Dropping event because there is no touchable window at (465, 489).
I/InputDispatcher( 967): Dropping event because there is no touchable window at (471, 486).
I/InputDispatcher( 967): Dropping event because there is no touchable window at (478, 482).
D/libEGL ( 4852): loaded /system/lib/egl/libGLES_mali.so
D/OpenGLRenderer( 4852): Enabling debug mode 0
D/dalvikvm( 4852): GC_CONCURRENT freed 82K, 5% free 2111K/2220K, paused 2ms+9ms, total 25ms
V/MGD GL Info View( 4852): glInfoReady
I/ActivityManager( 967): Displayed com.arm.mgd.mgddaemon/.MainActivity: +1s251ms
D/dalvikvm( 4852): GC_CONCURRENT freed 196K, 9% free 2338K/2556K, paused 1ms+1ms, total 17ms
I/MGD Daemon GUI( 4852): Enabling MGD Daemon.
D/dalvikvm( 4852): Trying to load lib /data/app-lib/com.arm.mgd.mgddaemon-1/libcom.arm.mgd.mgddaemon.so 0x420b41a0
D/dalvikvm( 4852): Added shared lib /data/app-lib/com.arm.mgd.mgddaemon-1/libcom.arm.mgd.mgddaemon.so 0x420b41a0
D/dalvikvm( 4852): No JNI_OnLoad found in /data/app-lib/com.arm.mgd.mgddaemon-1/libcom.arm.mgd.mgddaemon.so 0x420b41a0, skipping init
I/MGD Daemon Service( 4852): Received start id 1: Intent { cmp=com.arm.mgd.mgddaemon/.MainService }
I/MGDDAEMON( 4852): MGD Daemon thread started
I/MGDDAEMON( 4852): Set signal handler
I/MGDDAEMON( 4852): Daemon is version: B002
I/MGDDAEMON( 4852): Waiting for an interceptor to connect...
I/MGD Daemon Service( 4852): called startservice JNI f-n
I/MGDDAEMON( 4852): Waiting for a connection from the host on port 5002...
I/MGDDAEMON( 4852): Host connected.
[ 6092.049237@0] CPU1: shutdown
V/AudioFlinger( 133): AUDIO_OUTPUT_FLAG_FAST denied: isTimed=0 sharedBuffer=0xb71b73e0 frameCount=12992 mFrameCount=1024 format=1 isLinear=1 channelMask=0x3 sampleRate=48000 mSampleRate=48000 hasFastMixer=0 tid=4875 fastTrackAvailMask=0xfe
V/A[ 6112.324312@0] [aml-i2s-dai]i2s dma ef300000,phy addr 2f500000,mode 0,ch 2
udioFlinger( 133): Thr[ 6112.333517@0] speaker_events--mute =1
eadBase::setParameters() routing=2
V/AudioFlinger( 133): thread 0xb367e008 type [ 6112.345648@0] ----aml_hw_iec958_init,runtime->rate=48000--
[ 6112.349131@0] ----aml_hw_iec958_init,runtime->rate=48000,sample_rate=4--
[ 6112.356288@0] iec958 mode PCM16
[ 6112.358925@0] IEC958 16bit
[ 6112.361874@0] hdmitx: audio: aout notify rate 48000
0 TID 5[ 6112.367259@0] hdmitx: audio: aout notify size 16
[ 6112.371640@0] hdmitx: audio: audio channel num is 1
[ 6112.376593@0] hdmitx: audio: SPDIF
[ 6112.379914@0] aiu i2s playback enable
[ 6112.379914@0]
[ 6112.385362@0] hdmitx: audio: current VIC: 16
[ 6112.389307@0] hdmitx: audio: audio sample rate: 3
[ 6112.393892@0] hdmitx: audio: reset audio N para
[ 6112.400685@0] hdmitx: audio: PCM out to HDMI
[ 6112.402594@0] hdmitx: audio: i2s_to_spdif_flag:1
[ 6112.407367@0] hdmitx: audio: Enable audio spdif to HDMI
[ 6112.412635@0] hdmitx: audio: Audio Type: PCM
48 waking up[ 6112.418115@0] hdmitx: audio: set audio param
[ 6112.422358@0] [aml-spdif-dai]aiu 958 playback enable
V/AudioFlinger( 133): acquireWakeLock_l() AudioOut_2 status 0
D/audio_hw_primary( 133): out_set_parameters(kvpairs(routing=2), out_device=0x2)
V/AudioFlinger( 133): ThreadBase::setParameters() routing=1024
V/AudioFlinger( 133): thread 0xb34fc008 type 0 TID 557 waking up
V/AudioFlinger( 133): acquireWakeLock_l() AudioOut_7 status 0
D/audio_hw_hdmi( 133): out_set_parameters(kvpairs(routing=1024), out_device=0x400)
V/AudioFlinger( 133): thread 0xb33bb008 type 2 TID 560 waking up
V/AudioFlinger( 133): acquireWakeLock_l() AudioOut_8 status 0
I/Track ( 133): OutPut Track restore active track to thread 0xb34fc008
[ 6112.505884@0] video_disable_store(2) active track to thread 0xb367e008
[ 6112.509036@0] DisableVideoLayer()
I/Track ( 133): O[ 6112.521259@0] VsyncDisableVideoLayer
utPut Track restore active track to thread 0xb367e008
I/Track ( 133): OutPut Track restore active track to thread 0xb367e008
V/AudioFlinger( 133): remove track (4099) and delete from mixer
D/audio_hw_primary( 133): start_output_stream(adev->out_device=0x2, adev->mode=0)
D/audio_hw_primary( 133): select_devices(mode=0, out_device=0x2)
D/audio_hw_primary( 133): ~~~~ select_devices : hs=0 , hp=0, sp=2, hdmi=0x0,earpiece=0x0
D/audio_hw_primary( 133): ~~~~ select_devices : in_device(0x4), mic_in(0x4), headset_mic(0)
D/audio_hw_primary( 133): ****select_devices : output_standby=1,input_standby=1
D/audio_hw_primary( 133): *start_output_stream, open card(0) port(0)-------
D/audio_hw_primary( 133): channels=2---format=0---period_count4---period_size1024---rate=48000---
D/audio_hw_hdmi( 133): select_output_device(mode=0, out_device=0x400)
D/audio_hw_hdmi( 133): start_output_stream(adev->out_device=0x400, adev->mode=0)
I/audio_hw_hdmi( 133): hdmi sound card id 0,device id 1
D/audio_hw_hdmi( 133): ------------open on board audio-------
I/audio_hw_hdmi( 133): channels=2---format=0---period_count4---period_size1024---rate=48000---
I/ActivityManager( 967): START u0 {act=android.intent.action.MAIN cat=[android.intent.category.LAUNCHER] flg=0x10000000 pkg=com.vectorunit.redcmgeplaycn cmp=com.vectorunit.redcmgeplaycn/.Red} from pid 4852
I/ActivityManager( 967): start package name is com.vectorunit.redcmgeplaycn, class name is com.vectorunit.redcmgeplaycn.Red, error code is 0
D/dalvikvm( 967): GC_FOR_ALLOC freed 738K, 19% free 5661K/6924K, paused 43ms, total 46ms
V/MGD Daemon GUI( 4852): onPause
I/ActivityManager( 967): Start proc com.vectorunit.redcmgeplaycn for activity com.vectorunit.redcmgeplaycn/.Red: pid=4876 uid=10046 gids={50046, 3003, 1028, 1015}
D/dalvikvm( 4876): Late-enabling CheckJNI
D/dalvikvm( 4876): GC_CONCURRENT freed 210K, 25% free 723K/960K, paused 2ms+5ms, total 9ms
D/dalvikvm( 4876): GC_CONCURRENT freed 175K, 18% free 935K/1140K, paused 2ms+0ms, total 6ms
I/InputDispatcher( 967): Dropping event because there is no touchable window at (322, 476).
I/InputDispatcher( 967): Dropping event because there is no touchable window at (324, 475).
I/InputDispatcher( 967): Dropping event because there is no touchable window at (326, 475).
I/InputDispatcher( 967): Dropping event because there is no touchable window at (328, 474).
I/InputDispatcher( 967): Dropping event because there is no touchable window at (330, 473).
I/InputDispatcher( 967): Dropping event because there is no touchable window at (332, 472).
I/InputDispatcher( 967): Dropping event because there is no touchable window at (334, 471).
I/InputDispatcher( 967): Dropping event because there is no touchable window at (336, 470).
I/InputDispatcher( 967): Dropping event because there is no touchable window at (340, 468).
D/dalvikvm( 4876): GC_CONCURRENT freed 200K, 18% free 1122K/1356K, paused 4ms+3ms, total 14ms
I/InputDispatcher( 967): Dropping event because there is no touchable window at (343, 466).
I/InputDispatcher( 967): Dropping event because there is no touchable window at (346, 464).
I/InputDispatcher( 967): Dropping event because there is no touchable window at (350, 463).
I/InputDispatcher( 967): Dropping event because there is no touchable window at (354, 461).
I/InputDispatcher( 967): Dropping event because there is no touchable window at (358, 459).
I/InputDispatcher( 967): Dropping event because there is no touchable window at (364, 457).
I/InputDispatcher( 967): Dropping event because there is no touchable window at (369, 455).
I/InputDispatcher( 967): Dropping event because there is no touchable window at (374, 452).
I/InputDispatcher( 967): Dropping event because there is no touchable window at (378, 451).
I/InputDispatcher( 967): Dropping event because there is no touchable window at (382, 449).
I/InputDispatcher( 967): Dropping event because there is no touchable window at (387, 447).
D/dalvikvm( 4876): Trying to load lib /data/app-lib/com.vectorunit.redcmgeplaycn-1/libfmodex.so 0x4208bd50
D/dalvikvm( 4876): Added shared lib /data/app-lib/com.vectorunit.redcmgeplaycn-1/libfmodex.so 0x4208bd50
D/dalvikvm( 4876): No JNI_OnLoad found in /data/app-lib/com.vectorunit.redcmgeplaycn-1/libfmodex.so 0x4208bd50, skipping init
D/dalvikvm( 4876): Trying to load lib /data/app-lib/com.vectorunit.redcmgeplaycn-1/libfmodevent.so 0x4208bd50
D/dalvikvm( 4876): Added shared lib /data/app-lib/com.vectorunit.redcmgeplaycn-1/libfmodevent.so 0x4208bd50
D/dalvikvm( 4876): No JNI_OnLoad found in /data/app-lib/com.vectorunit.redcmgeplaycn-1/libfmodevent.so 0x4208bd50, skipping init
D/dalvikvm( 4876): Trying to load lib /data/app-lib/com.vectorunit.redcmgeplaycn-1/libRed.so 0x4208bd50
I/InputDispatcher( 967): Dropping event because there is no touchable window at (391, 446).
I/InputDispatcher( 967): Dropping event because there is no touchable window at (394, 444).
D/dalvikvm( 4876): Added shared lib /data/app-lib/com.vectorunit.redcmgeplaycn-1/libRed.so 0x4208bd50
D/dalvikvm( 4876): No JNI_OnLoad found in /data/app-lib/com.vectorunit.redcmgeplaycn-1/libRed.so 0x4208bd50, skipping init
I/InputDispatcher( 967): Dropping event because there is no touchable window at (396, 442).
I/InputDispatcher( 967): Dropping event because there is no touchable window at (399, 441).
I/InputDispatcher( 967): Dropping event because there is no touchable window at (402, 439).
I/InputDispatcher( 967): Dropping event because there is no touchable window at (404, 437).
I/InputDispatcher( 967): Dropping event because there is no touchable window at (407, 435).
I/InputDispatcher( 967): Dropping event because there is no touchable window at (410, 432).
I/InputDispatcher( 967): Dropping event because there is no touchable window at (413, 430).
I/InputDispatcher( 967): Dropping event because there is no touchable window at (414, 428).
I/InputDispatcher( 967): Dropping event because there is no touchable window at (417, 426).
I/InputDispatcher( 967): Dropping event because there is no touchable window at (418, 424).
I/InputDispatcher( 967): Dropping event because there is no touchable window at (420, 423).
I/InputDispatcher( 967): Dropping event because there is no touchable window at (422, 421).
I/InputDispatcher( 967): Dropping event because there is no touchable window at (423, 420).
I/InputDispatcher( 967): Dropping event because there is no touchable window at (424, 419).
I/InputDispatcher( 967): Dropping event because there is no touchable window at (426, 418).
I/InputDispatcher( 967): Dropping event because there is no touchable window at (428, 417).
I/InputDispatcher( 967): Dropping event because there is no touchable window at (430, 416).
I/InputDispatcher( 967): Dropping event because there is no touchable window at (433, 415).
I/InputDispatcher( 967): Dropping event because there is no touchable window at (436, 414).
I/Red ( 4876): OnInitApp
D/sys ( 4876): VuAndroidSys::bindJavaMethods()
D/GamePad ( 4876): VuAndroidGamePad::bindJavaMethods()
W/dalvikvm( 4876): dvmFindClassByName rejecting 'com/vectorunit/VuGamePadHelper'
D/Http ( 4876): VuAndroidHttpClient::bindJavaMethods()
W/dalvikvm( 4876): dvmFindClassByName rejecting 'com/vectorunit/VuHttpHelper'
D/ofm ( 4876): VuAndroidAnalyticsManager::bindJavaMethods()
W/dalvikvm( 4876): dvmFindClassByName rejecting 'com/vectorunit/VuAnalyticsHelper'
D/ofm ( 4876): VuAndroidCommunityManager::bindJavaMethods()
W/dalvikvm( 4876): dvmFindClassByName rejecting 'com/vectorunit/VuCommunityHelper'
D/Online ( 4876): VuAndroidSignInManager::bindJavaMethods()
W/dalvikvm( 4876): dvmFindClassByName rejecting 'com/vectorunit/VuOnlineHelper'
D/Online ( 4876): VuAndroidNetGameManager::bindJavaMethods()
D/Leaderboard( 4876): VuAndroidLeaderboardManager::bindJavaMethods()
W/dalvikvm( 4876): dvmFindClassByName rejecting 'com/vectorunit/VuLeaderboardHelper'
D/Achievement( 4876): VuAndroidAchievementManager::bindJavaMethods()
W/dalvikvm( 4876): dvmFindClassByName rejecting 'com/vectorunit/VuAchievementHelper'
D/Billing ( 4876): VuAndroidBillingManager::bindJavaMethods()
W/dalvikvm( 4876): dvmFindClassByName rejecting 'com/vectorunit/VuBillingHelper'
D/NvInput ( 4876): Initialized (Supported)
I/InputDispatcher( 967): Dropping event because there is no touchable window at (439, 413).
I/InputDispatcher( 967): Dropping event because there is no touchable window at (442, 410).
I/Red ( 4876): OnStart
I/InputDispatcher( 967): Dropping event because there is no touchable window at (445, 408).
I/InputDispatcher( 967): Dropping event because there is no touchable window at (451, 406).
I/InputDispatcher( 967): Dropping event because there is no touchable window at (458, 402).
I/InputDispatcher( 967): Dropping event because there is no touchable window at (467, 398).
I/InputDispatcher( 967): Dropping event because there is no touchable window at (476, 396).
I/InputDispatcher( 967): Dropping event because there is no touchable window at (488, 393).
I/InputDispatcher( 967): Dropping event because there is no touchable window at (500, 390).
D/dalvikvm( 4876): GC_CONCURRENT freed 99K, 9% free 1416K/1548K, paused 0ms+2ms, total 11ms
W/FlurryAgent( 4876): Start session
I/InputDispatcher( 967): Dropping event because there is no touchable window at (512, 385).
I/Red ( 4876): OnResume
I/InputDispatcher( 967): Dropping event because there is no touchable window at (527, 382).
I/InputDispatcher( 967): Dropping event because there is no touchable window at (540, 382).
I/InputDispatcher( 967): Dropping event because there is no touchable window at (554, 379).
E/MobileUtils( 4876): the appkey is empty,please init datau.sdk
W/MobileUtils( 4876): Could not read MOBILE_CHANNEL meta-data from AndroidManifest.xml.
E/UploadThread( 4876): unexpected empty channelId
I/InputDispatcher( 967): Dropping event because there is no touchable window at (567, 379).
I/InputDispatcher( 967): Dropping event because there is no touchable window at (579, 379).
I/InputDispatcher( 967): Dropping event because there is no touchable window at (586, 379).
D/dalvikvm( 4876): GC_CONCURRENT freed 404K, 23% free 1510K/1944K, paused 1ms+2ms, total 25ms
D/dalvikvm( 4876): WAIT_FOR_CONCURRENT_GC blocked 8ms
I/Red ( 4876): OnInitWindow
D/libEGL ( 4876): loaded /system/lib/egl/libGLES_mali.so
I/Red ( 4876): onWindowFocusChanged()
I/Red ( 4876): onSystemUiVisibilityChange()
I/ActivityManager( 967): Displayed com.vectorunit.redcmgeplaycn/.Red: +762ms
I/Red ( 4876): Creating surface (8,8,8,24) - Success
I/Red ( 4876): Surface size: 1280, 720
V/nv_syscaps( 4876): ##> GL_VENDOR: ARM
V/nv_syscaps( 4876): ##> GL_RENDERER: Mali-450 MP
V/nv_syscaps( 4876): ##> GL_VERSION: OpenGL ES 2.0
V/nv_syscaps( 4876): ##> Has NvTime: false
V/nv_syscaps( 4876): ##> Has S3TC: false
V/nv_syscaps( 4876): ##> Has NLZ: false
V/nv_syscaps( 4876): ##> Has CSAA: false
V/nv_syscaps( 4876): ##> Has PVRTC: false
V/nv_syscaps( 4876): ##> Has ATITC: false
V/nv_syscaps( 4876): ##> Present CPUs: 4
V/nv_syscaps( 4876): ##> CPU0 max freq: 1536MHz
V/nv_syscaps( 4876): ##> CPU has NEON
V/nv_syscaps( 4876): ##> CPU is VFPv4
V/nv_syscaps( 4876): ##> Total reported memory is 829MB
V/AudioFlinger( 133): sendIoConfigEvent() num events 1 event 0, param 0
I/fmod ( 4876): FMOD: AudioDevice::run : Min buffer size: 6144 bytes
I/fmod ( 4876): FMOD: AudioDevice::run : Actual buffer size: 8192 bytes
V/AudioFlinger( 133): ThreadBase::setParameters() routing=2
V/AudioFlinger( 133): processConfigEvents() remaining events 1
V/AudioFlinger( 133): PlaybackThread::audioConfigChanged_l, thread 0xb33bb008, event 0, param 0
V/AudioFlinger( 133): PlaybackThread::audioConfigChanged_l, thread 0xb367e008, event 0, param 0
V/AudioFlinger( 133): PlaybackThread::audioConfigChanged_l, thread 0xb34fc008, event 0, param 0
D/dalvikvm( 4876): GC_CONCURRENT freed 291K, 21% free 1616K/2028K, paused 3ms+2ms, total 21ms
V/AudioFlinger( 133): removeTracks_l removing track on session 114,mId 8
D/dalvikvm( 4876): GC_CONCURRENT freed 295K, 16% free 1745K/2068K, paused 2ms+1ms, total 13ms
I/MobileAgent( 4876): act log sd
W/FlurryAgent( 4876): FlurryDataSender: report bff13abc-7f06-4d43-ae98-b61600d0dd2b sent. HTTP response: 200 : OK
[ 6114.545957@0] CPU1: shutdown
I/Red ( 4876): OnGainedFocus
I/InputDispatcher( 967): Window 'Window{4244bb18 u0 com.vectorunit.redcmgeplaycn/com.vectorunit.redcmgeplaycn.Red}' spent 2786.4ms processing the last input event: MotionEvent(deviceId=11, source=0x00002002, action=7, flags=0x00000000, metaState=0x00000000, buttonState=0x00000000, edgeFlags=0x00000000, xPrecision=1.0, yPrecision=1.0, displayId=0, pointers=[0: (587.9, 379.1)]), policyFlags=0x42000000
I/InputDispatcher( 967): Window 'Window{4244bb18 u0 com.vectorunit.redcmgeplaycn/com.vectorunit.redcmgeplaycn.Red}' spent 2787.0ms processing the last input event: MotionEvent(deviceId=11, source=0x00002002, action=7, flags=0x00000000, metaState=0x00000000, buttonState=0x00000000, edgeFlags=0x00000000, xPrecision=1.0, yPrecision=1.0, displayId=0, pointers=[0: (587.9, 379.1)]), policyFlags=0x42000000
I/InputDispatcher( 967): Window 'Window{4244bb18 u0 com.vectorunit.redcmgeplaycn/com.vectorunit.redcmgeplaycn.Red}' spent 2770.6ms processing the last input event: MotionEvent(deviceId=11, source=0x00002002, action=7, flags=0x00000000, metaState=0x00000000, buttonState=0x00000000, edgeFlags=0x00000000, xPrecision=1.0, yPrecision=1.0, displayId=0, pointers=[0: (587.9, 378.1)]), policyFlags=0x42000000
I/InputDispatcher( 967): Window 'Window{4244bb18 u0 com.vectorunit.redcmgeplaycn/com.vectorunit.redcmgeplaycn.Red}' spent 2739.8ms processing the last input event: MotionEvent(deviceId=11, source=0x00002002, action=7, flags=0x00000000, metaState=0x00000000, buttonState=0x00000000, edgeFlags=0x00000000, xPrecision=1.0, yPrecision=1.0, displayId=0, pointers=[0: (588.9, 377.1)]), policyFlags=0x42000000
D/dalvikvm( 4876): GC_CONCURRENT freed 401K, 20% free 1729K/2160K, paused 2ms+2ms, total 22ms
yangw wrote: in the logcat output I found this entry: D/libEGL ( 4630): loaded /system/lib/egl/libGLES_mali.so. I think this means the interceptor library is loaded by the system
Actually this is Android's EGL layer telling you that it has loaded libGLES_mali.so, it has ignored the mgd interceptor completely which is why you aren't getting any trace. Can you provide a directory listing with `ls -al` on /system/lib/egl/ and /vendor/lib/egl? It's possible the permissions aren't set up correctly.
Cheers,
Chris
root@m201:/system/lib/egl # ll
-rw-r--r-- root root 429 2015-01-16 04:45 egl.cfg
lrwxrwxrwx root root 1974-12-08 23:04 libGLES.so -> libGLES_mgd.so
-rw-r--r-- root root 79116 2015-01-16 04:45 libGLES_android.so
-rw-r--r-- root root 1078872 2015-01-16 04:45 libGLES_mali.so
-rwx------ root root 1939020 2015-01-20 19:58 libGLES_mgd.so
-rw------- root root 29 2015-01-21 19:36 processlist.cfg
root@m201:/system/lib/egl # cd /vendor/lib/egl
/system/bin/sh: cd: /vendor/lib/egl: No such file or directory
2|root@m201:/system/lib/egl #
Yep can you run the following:
chmod 644 libGLES_mgd.so
That should make it pick up mgd.
I change the permissions of libGLES.so and libGLES_mgd.so, now the interceptor library is loaded, but it crashes every 3D app.
Below is what logcat says:
V/AudioFlinger( 133): AUDIO_OUTPUT_FLAG_FAST denied: isTimed=0 sharedBuffer=0xb71ac1f0 frameCount=12992 mFrameCount=1024 format=1 isLinear=1 channelMask=0x3 sampleRate=48000 mSampleRate=48000 hasFastMixer=0 tid=5093 fastTrackAvailMask=0xfe
V/AudioFlinger( 133): thread 0xb367e008 type 0 TID 548 waking up
V/AudioFlinger( 133): acquireWakeLock_l() AudioOut_2 statu[ 8096.058943@0] ----aml_hw_iec958_init,runtime->rate=48000--
s [ 8096.064796@0] ----aml_hw_iec958_init,runtime->rate=48000,sample_rate=4--
[ 8096.071130@0] iec958 mode PCM16
[ 8096.074534@0] IEC958 16bit
[ 8096.076803@0] hdmitx: audio: aout notify rate 48000
[ 8096.081657@0] hdmitx: audio: aout notify size 16
[ 8096.087046@0] hdmitx: audio: audio channel num is 1
0
D/a[ 8096.091510@0] hdmitx: audio: SPDIF
[ 8096.094780@0] hdmitx: audio: current VIC: 16
udi[ 8096.101815@0] hdmitx: audio: audio sample rate: 3
[ 8096.103912@0] hdmitx: audio: reset audio N para
[ 8096.109629@0] hdmitx: audio: PCM out to HDMI
[ 8096.112781@0] hdmitx: audio: i2s_to_spdif_flag:1
[ 8096.117410@0] hdmitx: audio: Enable audio spdif to HDMI
[ 8096.122865@0] hdmitx: audio: Audio Type: PCM
[ 8096.127142@0] hdmitx: audio: set audio param
[ 8096.131413@0] [aml-i2s-dai]i2s dma ef300000,phy addr 2f500000,mode 0,ch 2
[ 8096.138103@0] speaker_events--mute =1
[ 8096.141548@0] [aml-spdif-dai]aiu 958 playback enable
o[ 8096.146804@0] aiu i2s playback enable
[ 8096.146804@0]
D/audio_hw_hdmi( 133): out_set_parameters(kvpairs(routing=1024), out_device=0[ 8096.187809@0] video_disable_store(2)
[ 8096.190986@0] DisableVideoLayer()
x400)
V/AudioFlinger( 133): th[ 8096.204596@0] VsyncDisableVideoLayer
V/AudioFlinger( 133): remove track (4101) and delete from mixer
D/dalvikvm( 5094): Late-enabling CheckJNI
I/ActivityManager( 967): Start proc com.vectorunit.redcmgeplaycn for activity com.vectorunit.redcmgeplaycn/.Red: pid=5094 uid=10046 gids={50046, 3003, 1028, 1015}
D/dalvikvm( 5094): GC_CONCURRENT freed 193K, 24% free 713K/936K, paused 2ms+0ms, total 5ms
D/dalvikvm( 5094): GC_CONCURRENT freed 162K, 18% free 936K/1128K, paused 2ms+1ms, total 6ms
D/dalvikvm( 5094): GC_CONCURRENT freed 199K, 18% free 1123K/1356K, paused 2ms+0ms, total 7ms
I/InputDispatcher( 967): Dropping event because there is no touchable window at (234, 486).
I/InputDispatcher( 967): Dropping event because there is no touchable window at (234, 487).
I/InputDispatcher( 967): Dropping event because there is no touchable window at (234, 488).
D/dalvikvm( 5094): Trying to load lib /data/app-lib/com.vectorunit.redcmgeplaycn-1/libfmodex.so 0x42090c38
D/dalvikvm( 5094): Added shared lib /data/app-lib/com.vectorunit.redcmgeplaycn-1/libfmodex.so 0x42090c38
D/dalvikvm( 5094): No JNI_OnLoad found in /data/app-lib/com.vectorunit.redcmgeplaycn-1/libfmodex.so 0x42090c38, skipping init
D/dalvikvm( 5094): Trying to load lib /data/app-lib/com.vectorunit.redcmgeplaycn-1/libfmodevent.so 0x42090c38
D/dalvikvm( 5094): Added shared lib /data/app-lib/com.vectorunit.redcmgeplaycn-1/libfmodevent.so 0x42090c38
D/dalvikvm( 5094): No JNI_OnLoad found in /data/app-lib/com.vectorunit.redcmgeplaycn-1/libfmodevent.so 0x42090c38, skipping init
D/dalvikvm( 5094): Trying to load lib /data/app-lib/com.vectorunit.redcmgeplaycn-1/libRed.so 0x42090c38
D/dalvikvm( 5094): Added shared lib /data/app-lib/com.vectorunit.redcmgeplaycn-1/libRed.so 0x42090c38
D/dalvikvm( 5094): No JNI_OnLoad found in /data/app-lib/com.vectorunit.redcmgeplaycn-1/libRed.so 0x42090c38, skipping init
I/Red ( 5094): OnInitApp
D/sys ( 5094): VuAndroidSys::bindJavaMethods()
D/GamePad ( 5094): VuAndroidGamePad::bindJavaMethods()
W/dalvikvm( 5094): dvmFindClassByName rejecting 'com/vectorunit/VuGamePadHelper'
D/Http ( 5094): VuAndroidHttpClient::bindJavaMethods()
W/dalvikvm( 5094): dvmFindClassByName rejecting 'com/vectorunit/VuHttpHelper'
D/ofm ( 5094): VuAndroidAnalyticsManager::bindJavaMethods()
W/dalvikvm( 5094): dvmFindClassByName rejecting 'com/vectorunit/VuAnalyticsHelper'
D/ofm ( 5094): VuAndroidCommunityManager::bindJavaMethods()
W/dalvikvm( 5094): dvmFindClassByName rejecting 'com/vectorunit/VuCommunityHelper'
D/Online ( 5094): VuAndroidSignInManager::bindJavaMethods()
W/dalvikvm( 5094): dvmFindClassByName rejecting 'com/vectorunit/VuOnlineHelper'
D/Online ( 5094): VuAndroidNetGameManager::bindJavaMethods()
D/Leaderboard( 5094): VuAndroidLeaderboardManager::bindJavaMethods()
W/dalvikvm( 5094): dvmFindClassByName rejecting 'com/vectorunit/VuLeaderboardHelper'
D/Achievement( 5094): VuAndroidAchievementManager::bindJavaMethods()
W/dalvikvm( 5094): dvmFindClassByName rejecting 'com/vectorunit/VuAchievementHelper'
D/Billing ( 5094): VuAndroidBillingManager::bindJavaMethods()
W/dalvikvm( 5094): dvmFindClassByName rejecting 'com/vectorunit/VuBillingHelper'
D/NvInput ( 5094): Initialized (Supported)
I/Red ( 5094): OnStart
D/dalvikvm( 5094): GC_CONCURRENT freed 151K, 11% free 1490K/1656K, paused 2ms+1ms, total 13ms
W/FlurryAgent( 5094): Start session
I/Red ( 5094): OnResume
E/MobileUtils( 5094): the appkey is empty,please init datau.sdk
W/MobileUtils( 5094): Could not rea[ 8096.841153@1] audit_printk_skb: 94 callbacks suppressed
[ 8096.847135@0] type=1400 audit(1421843869.280:188): avc: denied { read } for pid=5107 comm="t.redcmgeplaycn" name="app_process" dev="system" ino=8197 scontext=u:r:untrusted_app:s0 tcontext=u:object_r:zygote_exec:s0 tclass=file
d MOBILE_CHANNEL meta-data from [ 8096.869087@0] type=1400 audit(1421843869.320:189): avc: denied { open } for pid=5107 comm="t.redcmgeplaycn" path="/system/bin/app_process" dev="system" ino=8197 scontext=u:r:untrusted_app:s0 tcontext=u:object_r:zygote_exec:s0 tclass=file
E/UploadThread( 5094): unexpected empty channelId
D/dalvikvm( 5094): GC_CONCURRENT freed 357K, 21% free 1521K/1908K, paused 2ms+0ms, total 10ms
I/Red ( 5094): OnInitWindow
I/libGLES_mgd( 5094): Initialising interceptor.
I/Red ( 5094): onWindowFocusChanged()
I/Red ( 5094): onSystemUiVisibilityChange()
I/ActivityManager( 967): Displayed com.vectorunit.redcmgeplaycn/.Red: +692ms (total +1m6s405ms)
I/libGLES_mgd( 5094): libGLES_mgd is in a system folder
E/libGLES_mgd( 5094): Failed to parse process mappings.
D/libEGL ( 5094): loaded /system/lib/egl/libGLES.so
I/mgd_interceptor( 5094): Interceptor constructor called
I/mgd_interceptor( 5094): Trying to connect to the daemon...
I/mgd_interceptor( 5094): Connected to the daemon.
I/MGDDAEMON( 4852): An intercepted application is connected.
I/MGDDAEMON( 4852): An intercepted application is being traced.
I/mgd_interceptor( 5094): Sending header...
I/mgd_interceptor( 5094): Header sent.
I/mgd_interceptor( 5094): Reading process name for PID=5094
I/mgd_interceptor( 5094): Process = com.vectorunit.redcmgeplaycn
I/mgd_interceptor( 5094): Could not open /system/lib/egl/processlist.cfg, so tracing by default
I/mgd_interceptor( 5094): Attempting to load libEGL at /vendor/lib/egl/libGLES_mali.so ...
I/MGDDAEMON( 4852): Interceptor is version: B002
E/mgd_interceptor( 5094): Could not get handle to libEGL (dlerror=`dlopen failed: library "/vendor/lib/egl/libGLES_mali.so" not found`).
W/mgd_interceptor( 5094): Unable to locate library libEGL, no functions for this library will be intercepted
E/mgd_interceptor( 5094): User called extension function eglGetProcAddress} which does not exist
F/libc ( 5094): Fatal signal 11 (SIGSEGV) at 0x00000000 (code=1), thread 5107 (t.redcmgeplaycn)
D/dalvikvm( 5094): GC_FOR_ALLOC freed 289K, 23% free 1592K/2060K, paused 7ms, total 8ms
I/DEBUG ( 5068): *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** ***
I/DEBUG ( 5068): Build fingerprint: 'MBX/m201/m201:4.4.2/KOT49H/20150116:user/test-keys'
I/DEBUG ( 5068): Revision: '10'
I/DEBUG ( 5068):
I/DEBUG ( 5068): Crash Time:----- 2015-01-21-20-37 -----
I/DEBUG ( 5068): pid: 5094, tid: 5107, name: t.redcmgeplaycn >>> com.vectorunit.redcmgeplaycn <<<
I/DEBUG ( 5068): signal 11 (SIGSEGV), code 1 (SEGV_MAPERR), fault addr 00000000
I/DEBUG ( 5068): r0 00000000 r1 00000000 r2 ccf02a09 r3 00000000
I/DEBUG ( 5068): r4 00000000 r5 4031da54 r6 67aa0710 r7 00000001
I/DEBUG ( 5068): r8 000000b0 r9 40336750 sl 00000007 fp 40336764
I/DEBUG ( 5068): ip 00000001 sp 67aa06f8 lr 683017d3 pc 00000000 cpsr 000f0010
I/DEBUG ( 5068): d0 6c61632072657355 d1 657478652064656c
I/DEBUG ( 5068): d2 7566206e6f69736e d3 65206e6f6974636e
I/DEBUG ( 5068): d4 6f72507465476c67 d5 7373657264644163
I/DEBUG ( 5068): d6 206863696877207d d7 746f6e2073656f64
I/DEBUG ( 5068): d8 0000000000000000 d9 0000000000000000
I/DEBUG ( 5068): d10 0000000000000000 d11 0000000000000000
I/DEBUG ( 5068): d12 0000000000000000 d13 0000000000000000
I/DEBUG ( 5068): d14 0000000000000000 d15 0000000000000000
I/DEBUG ( 5068): d16 000000000000001c d17 3fc999999999999a
I/DEBUG ( 5068): d18 4000000000000000 d19 3fd99a27ad32ddf5
I/DEBUG ( 5068): d20 3f8948b0fcd6e9e0 d21 3fe555b0aaeac752
I/DEBUG ( 5068): d22 3fd24998d6307188 d23 3fcc7288e957b53b
I/DEBUG ( 5068): d24 3fc74721cad6b0ed d25 3fc2f112df3e5244
I/DEBUG ( 5068): d26 40026bb1bbb55516 d27 0000000000000000
I/DEBUG ( 5068): d28 0000000000000000 d29 0000000000000000
I/DEBUG ( 5068): d30 0000000000000000 d31 0000000000000000
I/DEBUG ( 5068): scr 60000011
I/DEBUG ( 5068): backtrace:
I/DEBUG ( 5068): #00 pc 00000000 <unknown>
I/DEBUG ( 5068): #01 pc 000817cf /system/lib/egl/libGLES_mgd.so (eglGetProcAddress+78)
I/DEBUG ( 5068): #02 pc 000347ed /system/lib/libEGL.so
I/DEBUG ( 5068): #03 pc 0003489b /system/lib/libEGL.so
I/DEBUG ( 5068): #04 pc 0000dc19 /system/lib/libEGL.so
I/DEBUG ( 5068): #05 pc 0000e321 /system/lib/libEGL.so (eglGetDisplay+24)
I/DEBUG ( 5068): #06 pc 00183ce9 /data/app-lib/com.vectorunit.redcmgeplaycn-1/libRed.so (OnInitWindow(ANativeActivity*, ANativeWindow*)+68)
I/DEB[ 8097.325204@0] [aml-spdif-dai]aiu 958 playback disable
UG ( 5068): #07 pc 001842e9 /data/app-lib/com.vectorunit.redcmgeplaycn-1/libRed.so
I/DEBUG ( 5068): #08 pc 00184e75 /data/app-lib/com.vectoruni[ 8097.345198@0] aiu i2s playback disable
[ 8097.345198@0]
I/DEBUG ( 5068): #09 pc 001834eb /data/app-lib/com.vectorunit.redcmgeplaycn-1/libRed.so (android_main+82)
I/DEBUG ( 5068): #10 pc 00184a67 /data/app-lib/com.vectorunit.redcmgeplaycn-1/libRed.so
I/DEBUG ( 5068): #11 pc 0000d1a0 /system/lib/libc.so (__thread_entry+72)
I/DEBUG ( 5068): #12 pc 0000d338 /system/lib/libc.so (pthread_create+240)
I/DEBUG ( 5068): stack:
I/DEBUG ( 5068): 67aa06b8 40336764
I/DEBUG ( 5068): 67aa06bc 40087d44 /system/lib/libc.so (malloc+24)
I/DEBUG ( 5068): 67aa06c0 685dde3c
I/DEBUG ( 5068): 67aa06c4 68403a40 /system/lib/egl/libGLES_mgd.so
I/DEBUG ( 5068): 67aa06c8 00000001
I/DEBUG ( 5068): 67aa06cc ccf02a09
I/DEBUG ( 5068): 67aa06d0 6845a024 /system/lib/egl/libGLES_mgd.so
I/DEBUG ( 5068): 67aa06d4 6845a13c /system/lib/egl/libGLES_mgd.so
I/DEBUG ( 5068): 67aa06d8 4031da54 /system/lib/libEGL.so
I/DEBUG ( 5068): 67aa06dc ccf02a09
I/DEBUG ( 5068): 67aa06e0 00000000
I/DEBUG ( 5068): 67aa06e4 4031da54 /system/lib/libEGL.so
I/DEBUG ( 5068): 67aa06e8 00000001
I/DEBUG ( 5068): 67aa06ec 68301847 /system/lib/egl/libGLES_mgd.so (eglGetProcAddress+198)
I/DEBUG ( 5068): 67aa06f0 68421ae0 /system/lib/egl/libGLES_mgd.so
I/DEBUG ( 5068): 67aa06f4 6845a13c /system/lib/egl/libGLES_mgd.so
I/DEBUG ( 5068): #00 67aa06f8 67995258
I/DEBUG ( 5068): ........ ........
I/DEBUG ( 5068): #01 67aa06f8 67995258
I/DEBUG ( 5068): 67aa06fc 4031da54 /system/lib/libEGL.so
I/DEBUG ( 5068): 67aa0700 4005[ 8097.504131@1] video_disable_store(2)
[ 8097.506248@1] DisableVideoLayer()
dfda /system/bin/linker
I/DEBUG ( 5068): 67aa0704 00000000
I/DEBUG ( 5068): 67aa0708 54bf9d9[ 8097.521273@0] VsyncDisableVideoLayer
d /dev/ashmem/dalvik-heap (deleted)
I/DEBUG ( 5068): 67aa070c 00062b8a
I/DEBUG ( 5068): 67aa0710 54bf9d9d /dev/ashmem/dalvik-heap (deleted)
I/DEBUG ( 5068): [ 8097.541434@1] video_disable_store(2)
[ 8097.543440@1] DisableVideoLayer()
67aa0714 00062ba2
I/DEBUG ( 5068): 67aa071[ 8097.554597@0] VsyncDisableVideoLayer
8 41647a48
I/DEBUG ( 5068): 67aa071c 4031da54 /system/lib/libEGL.so
I/DEBUG ( 5068): 67aa0720 66b5[ 8097.567276@1] type=1400 audit(1421843870.010:190): avc: denied { transfer } for pid=4865 comm="Thread-165" scontext=u:r:untrusted_app:s0 tcontext=u:r:init:s0 tclass=binder
de88
I/DEBUG ( 5068): 67aa0724 4032ede8 /system/lib/libEGL.so
I/DEBUG ( 5068): 67aa0728 000000b0
I/DEBUG ( 5068): 67aa072c 403177ef /system/lib/libEGL.so
I/DEBUG ( 5068): #02 67aa0730 00000000
I/DEBUG ( 5068): 67aa0734 4006fcad /system/lib/libcutils.so (__android_log_print+56)
I/DEBUG ( 5068): 67aa0738 67aa0b54 [stack:5107]
I/DEBUG ( 5068): 67aa073c 4032dc88 /system/lib/libEGL.so
I/DEBUG ( 5068): 67aa0740 6798f200
I/DEBUG ( 5068): 67aa0744 6798f1e0
I/DEBUG ( 5068): 67aa0748 614e7942 /dev/ashmem/dalvik-mark-stack (deleted)
I/DEBUG ( 5068): 67aa074c 40336750
I/DEBUG ( 5068): 67aa0750 66b5de88
I/DEBUG ( 5068): 67aa0754 66b5de88
I/DEBUG ( 5068): 67aa0758 678698cd /data/app-lib/com.vectorunit.redcmgeplaycn-1/libRed.so
I/DEBUG ( 5068): 67aa075c 67aa07b8 [stack:5107]
I/DEBUG ( 5068): 67aa0760 6799c348
I/DEBUG ( 5068): 67aa0764 6799e8d0
I/DEBUG ( 5068): 67aa0768 400ca384
I/DEBUG ( 5068): 67aa076c 4031789f /system/lib/libEGL.so
I/DEBUG ( 5068): memory near r5:
I/DEBUG ( 5068): 4031da34 53746547 41636e79 69727474 52484b62
I/DEBUG ( 5068): 4031da44 6c676500 74696157 636e7953 0052484b
I/DEBUG ( 5068): 4031da54 536c6765 77537465 65527061 6e617463
I/DEBUG ( 5068): 4031da64 41656c67 4f52444e 65004449 65476c67
I/DEBUG ( 5068): 4031da74 6e655274 42726564 65666675 444e4172
I/DEBUG ( 5068): 4031da84 44494f52 6c676500 4e707544 76697461
I/DEBUG ( 5068): 4031da94 6e654665 44466563 52444e41 0044494f
I/DEBUG ( 5068): 4031daa4 476c6765 79537465 6d657473 656d6954
I/DEBUG ( 5068): 4031dab4 71657246 636e6575 00564e79 476c6765
I/DEBUG ( 5068): 4031dac4 79537465 6d657473 656d6954 6500564e
I/DEBUG ( 5068): 4031dad4 69486c67 6e726562 50657461 65636f72
I/DEBUG ( 5068): 4031dae4 4d497373 67650047 6177416c 506e656b
I/DEBUG ( 5068): 4031daf4 65636f72 4d497373 6c670047 69746341
I/DEBUG ( 5068): 4031db04 68536576 72656461 676f7250 456d6172
I/DEBUG ( 5068): 4031db14 67005458 7463416c 54657669 75747865
I/DEBUG ( 5068): 4031db24 67006572 706c416c 75466168 6700636e
I/DEBUG ( 5068): memory near r6:
I/DEBUG ( 5068): 67aa06f0 68421ae0 6845a13c 67995258 4031da54
I/DEBUG ( 5068): 67aa0700 4005dfda 00000000 54bf9d9d 00062b8a
I/DEBUG ( 5068): 67aa0710 54bf9d9d 00062ba2 41647a48 4031da54
I/DEBUG ( 5068): 67aa0720 66b5de88 4032ede8 000000b0 403177ef
I/DEBUG ( 5068): 67aa0730 00000000 4006fcad 67aa0b54 4032dc88
I/DEBUG ( 5068): 67aa0740 6798f200 6798f1e0 614e7942 40336750
I/DEBUG ( 5068): 67aa0750 66b5de88 66b5de88 678698cd 67aa07b8
I/DEBUG ( 5068): 67aa0760 6799c348 6799e8d0 400ca384 4031789f
I/DEBUG ( 5068): 67aa0770 00000000 40336750 66b5de88 403374ec
I/DEBUG ( 5068): 67aa0780 678698cd 402f0c1d 00000000 00000001
I/DEBUG ( 5068): 67aa0790 67aa080c 402f1325 678a1b08 676a3ced
I/DEBUG ( 5068): 67aa07a0 00000000 00000000 00000000 00000000
I/DEBUG ( 5068): 67aa07b0 00000000 6799e7e8 00000000 00000000
I/DEBUG ( 5068): 67aa07c0 00000000 00000000 00000000 00000000
I/DEBUG ( 5068): 67aa07d0 00000000 00000000 00000000 00000000
I/DEBUG ( 5068): 67aa07e0 00000000 00000000 00000000 00000000
I/DEBUG ( 5068): memory near r9:
I/DEBUG ( 5068): 40336730 00000000 00000000 00000000 00000000
I/DEBUG ( 5068): 40336740 00000000 00000000 00000000 00000001
I/DEBUG ( 5068): 40336750 00000000 40334e64 40335ad8 00000000
I/DEBUG ( 5068): 40336760 00000000 682ff079 682ff15d 682ff255
I/DEBUG ( 5068): 40336770 682ff45d 682ff55d 682ff691 682ff791
I/DEBUG ( 5068): 40336780 682ff99d 682ff89d 682ffaa9 682ffb9d
I/DEBUG ( 5068): 40336790 68300511 6830061d 68300711 68300815
I/DEBUG ( 5068): 403367a0 683008f1 683009d5 68300ab1 68300bb9
I/DEBUG ( 5068): 403367b0 68300c95 68300d79 68300e89 682fef99
I/DEBUG ( 5068): 403367c0 682ff339 68301781 6830012d 6830022d
I/DEBUG ( 5068): 403367d0 68300325 6830041d 682ffc9d 682ffd81
I/DEBUG ( 5068): 403367e0 682ffe5d 682fff39 68300015 68303131
I/DEBUG ( 5068): 403367f0 683052f9 683011d5 68301425 68301309
I/DEBUG ( 5068): 40336800 68301541 683010a1 683047c1 6830165d
I/DEBUG ( 5068): 40336810 68300f85 00000000 00000000 00000000
I/DEBUG ( 5068): 40336820 00000000 00000000 00000000 00000000
I/DEBUG ( 5068): memory near fp:
I/DEBUG ( 5068): 40336744 00000000 00000000 00000001 00000000
I/DEBUG ( 5068): 40336754 40334e64 40335ad8 00000000 00000000
I/DEBUG ( 5068): 40336764 682ff079 682ff15d 682ff255 682ff45d
I/DEBUG ( 5068): 40336774 682ff55d 682ff691 682ff791 682ff99d
I/DEBUG ( 5068): 40336784 682ff89d 682ffaa9 682ffb9d 68300511
I/DEBUG ( 5068): 40336794 6830061d 68300711 68300815 683008f1
I/DEBUG ( 5068): 403367a4 683009d5 68300ab1 68300bb9 68300c95
I/DEBUG ( 5068): 403367b4 68300d79 68300e89 682fef99 682ff339
I/DEBUG ( 5068): 403367c4 68301781 6830012d 6830022d 68300325
I/DEBUG ( 5068): 403367d4 6830041d 682ffc9d 682ffd81 682ffe5d
I/DEBUG ( 5068): 403367e4 682fff39 68300015 68303131 683052f9
I/DEBUG ( 5068): 403367f4 683011d5 68301425 68301309 68301541
I/DEBUG ( 5068): 40336804 683010a1 683047c1 6830165d 68300f85
I/DEBUG ( 5068): 40336814 00000000 00000000 00000000 00000000
I/DEBUG ( 5068): 40336824 00000000 00000000 00000000 00000000
I/DEBUG ( 5068): 40336834 00000000 00000000 00000000 00000000
I/DEBUG ( 5068): memory near sp:
I/DEBUG ( 5068): 67aa06d8 4031da54 ccf02a09 00000000 4031da54
I/DEBUG ( 5068): 67aa06e8 00000001 68301847 68421ae0 6845a13c
I/DEBUG ( 5068): 67aa06f8 67995258 4031da54 4005dfda 00000000
I/DEBUG ( 5068): 67aa0708 54bf9d9d 00062b8a 54bf9d9d 00062ba2
I/DEBUG ( 5068): 67aa0718 41647a48 4031da54 66b5de88 4032ede8
I/DEBUG ( 5068): 67aa0728 000000b0 403177ef 00000000 4006fcad
I/DEBUG ( 5068): 67aa0738 67aa0b54 4032dc88 6798f200 6798f1e0
I/DEBUG ( 5068): 67aa0748 614e7942 40336750 66b5de88 66b5de88
I/DEBUG ( 5068): 67aa0758 678698cd 67aa07b8 6799c348 6799e8d0
I/DEBUG ( 5068): 67aa0768 400ca384 4031789f 00000000 40336750
I/DEBUG ( 5068): 67aa0778 66b5de88 403374ec 678698cd 402f0c1d
I/DEBUG ( 5068): 67aa0788 00000000 00000001 67aa080c 402f1325
I/DEBUG ( 5068): 67aa0798 678a1b08 676a3ced 00000000 00000000
I/DEBUG ( 5068): 67aa07a8 00000000 00000000 00000000 6799e7e8
I/DEBUG ( 5068): 67aa07b8 00000000 00000000 00000000 00000000
I/DEBUG ( 5068): 67aa07c8 00000000 00000000 00000000 00000000
I/DEBUG ( 5068): code around pc:
I/DEBUG ( 5068): 00000000 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 5068): 00000010 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 5068): 00000020 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 5068): 00000030 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 5068): 00000040 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 5068): 00000050 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 5068): 00000060 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 5068): 00000070 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 5068): 00000080 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 5068): 00000090 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 5068): 000000a0 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 5068): 000000b0 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 5068): 000000c0 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 5068): 000000d0 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 5068): 000000e0 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 5068): 000000f0 ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 5068): code around lr:
I/DEBUG ( 5068): 683017b0 460447a0 4620b936 f0774629 b008ffb9
I/DEBUG ( 5068): 683017c0 81f0e8bd 2100ae06 f7e04630 f08ced3e
I/DEBUG ( 5068): 683017d0 4680fde7 fddef08c 463b4642 a8044631
I/DEBUG ( 5068): 683017e0 0030e88d fc8cf037 20004629 fa88f07d
I/DEBUG ( 5068): 683017f0 46204629 ff9cf077 f07e9003 f07ef827
I/DEBUG ( 5068): 68301800 9803fc97 e8bdb008 a80481f0 f7e02100
I/DEBUG ( 5068): 68301810 e7c5ed1c 22014f16 447f4916 46384479
I/DEBUG ( 5068): 68301820 f07e6809 f8c4fcf7 b1980178 b15b6823
I/DEBUG ( 5068): 68301830 f90cf7fd 4910e7b3 4a102006 44792701
I/DEBUG ( 5068): 68301840 f7e0447a e7b5eca2 4479490d fe44f07e
I/DEBUG ( 5068): 68301850 e7ed6020 463b490b 20054a0b 447a4479
I/DEBUG ( 5068): 68301860 ec92f7e0 bf00e79b 001589a6 00158996
I/DEBUG ( 5068): 68301870 0011f65a 001587e4 0011f63e 0012029c
I/DEBUG ( 5068): 68301880 0011cf1a 0011f620 0011f62e 4ff0e92d
I/DEBUG ( 5068): 68301890 461fb08b 468a4681 f08c4616 4c3afc4b
I/DEBUG ( 5068): 683018a0 fc1cf07e f8d4447c b2c53178 d04a2b00
I/DEBUG ( 5068): ==============================memory map dump_nearby_maps
V/AudioFlinger( 133): removeTracks_l removing track on session 118,mId 8
V/AudioFlinger( 133): removeTracks_l removing track on session 0,mId 7
V/AudioFlinger( 133): removeTracks_l removing track on session 0,mId 2
I/BootReceiver( 967): Copying /data/tombstones/tombstone_00 to DropBox (SYSTEM_TOMBSTONE)
D/dalvikvm( 967): GC_FOR_ALLOC freed 981K, 26% free 5824K/7804K, paused 43ms, total 44ms
W/InputDispatcher( 967): channel '426036a8 com.vectorunit.redcmgeplaycn/com.vectorunit.redcmgeplaycn.Red (server)' ~ Consumer closed input channel or an error occurred. events=0xd
E/InputDispatcher( 967): channel '426036a8 com.vectorunit.redcmgeplaycn/com.vectorunit.redcmgeplaycn.Red (server)' ~ Channel is unrecoverably broken and will be disposed!
D/Zygote ( 131): Process 5094 terminated by signal (11)
D/dalvikvm( 967): GC_FOR_ALLOC freed 296K, 20% free 6244K/7804K, paused 43ms, total 43ms
W/InputDispatcher( 967): Attempted to unregister already unregistered input channel '426036a8 com.vectorunit.redcmgeplaycn/com.vectorunit.redcmgeplaycn.Red (server)'
I/WindowState( 967): WIN DEATH: Window{426036a8 u0 com.vectorunit.redcmgeplaycn/com.vectorunit.redcmgeplaycn.Red}
W/ActivityManager( 967): Force finishing activity com.vectorunit.redcmgeplaycn/.Red
D/dalvikvm( 967): GC_FOR_ALLOC freed 585K, 26% free 5852K/7804K, paused 31ms, total 32ms
W/ActivityManager( 967): Exception thrown during pause
W/ActivityManager( 967): android.os.DeadObjectException
W/ActivityManager( 967): at android.os.BinderProxy.transact(Native Method)
W/ActivityManager( 967): at android.app.ApplicationThreadProxy.schedulePauseActivity(ApplicationThreadNative.java:660)
W/ActivityManager( 967): at com.android.server.am.ActivityStack.startPausingLocked(ActivityStack.java:793)
W/ActivityManager( 967): at com.android.server.am.ActivityStack.finishActivityLocked(ActivityStack.java:2796)
W/ActivityManager( 967): at com.android.server.am.ActivityStack.finishTopRunningActivityLocked(ActivityStack.java:2670)
W/ActivityManager( 967): at com.android.server.am.ActivityStackSupervisor.finishTopRunningActivityLocked(ActivityStackSupervisor.java:2222)
W/ActivityManager( 967): at com.android.server.am.ActivityManagerService.handleAppCrashLocked(ActivityManagerService.java:9815)
W/ActivityManager( 967): at com.android.server.am.ActivityManagerService.makeAppCrashingLocked(ActivityManagerService.java:9708)
W/ActivityManager( 967): at com.android.server.am.ActivityManagerService.crashApplication(ActivityManagerService.java:10353)
W/ActivityManager( 967): at com.android.server.am.ActivityManagerService.handleApplicationCrashInner(ActivityManagerService.java:9904)
W/ActivityManager( 967): at com.android.server.am.NativeCrashListener$NativeCrashReporter.run(NativeCrashListener.java:86)
D/ActivityManager( 967): resumeClassName is com.arm.mgd.mgddaemon.MainActivity
D/ActivityManager( 967): resumePackageName is com.arm.mgd.mgddaemon
I/InputDispatcher( 967): Dropping event because there is no touchable window at (244, 480).
W/ActivityManager( 967): Force finishing activity com.arm.mgd.mgddaemon/.MainActivity
I/InputDispatcher( 967): Dropping event because there is no touchable window at (244, 479).
D/ActivityManager( 967): send app_CRASH broadcast, packageName:com.vectorunit.redcmgeplaycn
I/ActivityManager( 967): Process com.vectorunit.redcmgeplaycn (pid 5094) has died.
W/ContextImpl( 967): Calling a method in the system process without a qualified user: android.app.ContextImpl.sendBroadcast:1162 com.android.server.am.ActivityManagerService.onVideoPlayerCrashed:3689 com.android.server.am.ActivityManagerService.handleAppDiedLocked:3719 com.android.server.am.ActivityManagerService.appDiedLocked:3857 com.android.server.am.ActivityManagerService$AppDeathRecipient.binderDied:1046
I/InputDispatcher( 967): Dropping event because there is no touchable window at (245, 479).
D/ActivityManager( 967): resumeClassName is com.amlogic.mediaboxlauncher.Launcher
D/ActivityManager( 967): resumePackageName is com.amlogic.mediaboxlauncher
W/AudioFlinger( 133): write blocked for 329 msecs, 4993 delayed writes, thread 0xb34fc008
I/InputDispatcher( 967): Dropping event because there is no touchable window at (246, 478).
D/MediaBoxLauncher( 2988): ------onResume
I/InputDispatcher( 967): Dropping event because there is no touchable window at (247, 478).
W/AudioFlinger( 133): write blocked for 337 msecs, 5017 delayed writes, thread 0xb367e008
I/InputDispatcher( 967): Dropping event because there is no touchable window at (247, 477).
W/InputMethodWrapper( 3072): Session is null
W/InputMethodManagerService( 967): Got RemoteException sending setActive(false) notification to pid 5094 uid 10046
[ 8099.749393@0] CPU1: shutdown
V/AudioFlinger( 133): releaseWakeLock_l() AudioOut_8
V/AudioFlinger( 133): thread 0xb33bb008 type 2 TID 560 going to sleep
V/AudioFlinger( 133): Audio hardware entering standby, mixer 0xb34fc008, suspend count 0,mid 7
D/audio_hw_hdmi( 133): out_standby(0xb7190d48)
I/audio_hw_hdmi( 133): [do_output_standby 746]Clear LastStream/0xb7190d48
V/AudioFlinger( 133): releaseWakeLock_l() AudioOut_7
V/AudioFlinger( 133): thread 0xb34fc008 type 0 TID 557 going to sleep
V/AudioFlinger( 133): Audio hardware entering standby, mixer 0xb367e008, suspend count 0,mid 2
D/audio_hw_primary( 133): do_output_standby(0xb718ee60)
D/audio_hw_primary( 133): do_output_standby : output_standby=1,input_standby=1
V/AudioFlinger( 133): releaseWakeLock_l() AudioOut_2
V/AudioFlinger( 133): thread 0xb367e008 type 0 TID 548 going to sleep
[ 8101.812728@0] Uart 0 Driver: Overflow Error while receiving a character
^C
130|root@m201:/system/lib/egl # [ 8105.257236@0] speaker_events--mute =0
I/libGLES_mgd( 5094): Initialising interceptor. I/libGLES_mgd( 5094): libGLES_mgd is in a system folder E/libGLES_mgd( 5094): Failed to parse process mappings. D/libEGL ( 5094): loaded /system/lib/egl/libGLES.so I/mgd_interceptor( 5094): Interceptor constructor called I/mgd_interceptor( 5094): Trying to connect to the daemon... I/mgd_interceptor( 5094): Connected to the daemon. I/MGDDAEMON( 4852): An intercepted application is connected. I/MGDDAEMON( 4852): An intercepted application is being traced. I/mgd_interceptor( 5094): Sending header... I/MGDDAEMON( 4852): Waiting for an interceptor to connect... I/mgd_interceptor( 5094): Header sent. I/mgd_interceptor( 5094): Reading process name for PID=5094 I/mgd_interceptor( 5094): Process = com.vectorunit.redcmgeplaycn I/mgd_interceptor( 5094): I/mgd_interceptor( 5094): Could not open /system/lib/egl/processlist.cfg, so tracing by default I/mgd_interceptor( 5094): Attempting to load libEGL at /vendor/lib/egl/libGLES_mali.so ... I/MGDDAEMON( 4852): Interceptor is version: B002 E/mgd_interceptor( 5094): Could not get handle to libEGL (dlerror=`dlopen failed: library "/vendor/lib/egl/libGLES_mali.so" not found`). W/mgd_interceptor( 5094): Unable to locate library libEGL, no functions for this library will be intercepted E/mgd_interceptor( 5094): User called extension function eglGetProcAddress} which does not exist F/libc ( 5094): Fatal signal 11 (SIGSEGV) at 0x00000000 (code=1), thread 5107 (t.redcmgeplaycn)
The above is basically the issue. Android EGL is successfully loading the interceptor, and it is reporting 2 errors, one that it can't parse the process mappings, and one that it can't get a handle to /vendor/lib/egl/libGLES_mali.so. The latter looks like a bug to me as it should also look in /system/lib/egl/ so I've passed this onto the team.
Hth,
Hi Yangw,
I see there is a crash in your report. Our team has been investigating that for the last week and we believe we have a patch that fixes it.
We are going to release it soon, I will update this post as soon as it is available.
Thank you for your patience,
Lorenzo
Thanks very much for your reply, and I am looking forward to the release.Thank you all!
There is one idea, you could create a symlink from /vendor/lib/egl/libGLES_mali.so to /system/lib/egl/libGLES_mali.so as that would probably allow mgd to pick up the driver untested but on paper might work.
I had tried this yesterday, still crash, no luck.
Hi, Chris! I have tried new Mali Graphics Debugger v2.0.1 and has the same issue (Samsung Galaxy Note (Mali-400) + Android 4.2.2 (Cyanogenmod)).
I've also tried to make symlink from /system/lib/egl to /vendor/lib/egl. The problem is /system/lib/egl doesn't contain any libGLES_mali.so but contains libEGL_mali.so, libGLES_android.so, libGLESv1_CM_mali.so and libGLESv2_mali.so. I've tried to map all available *.so to /vendor/lib/egl/libGLES_mali.so, but the result the same (black screen and huge log with functions which are not discovered). Best result was achieved with libGLES_android.so (corrupted picture and only one function not found). Is there any possibilities to make it work for my configuration.
Same exact crash? Maybe the symlink needs chmod 644 also in that case? In any case there are fixes in the works
I was going to suggest making 3 separate symlinks, from /vendor/lib/egl to /system/lib/egl, but due to the above bug there's no way to support fragmented builds at present (EGL will only look for /vendor/lib/egl/libGLES_mali.so, and symlinking that to libEGL.so would break GLESv1 and v2). There is a fix incoming though which will resolve this, and it should "just work" by following the install guide.
We have now released MGD v2.0.2 which should resolve this issue (Mali Graphics Debugger - Mali Developer Center Mali Developer Center). Please give it a go and let us know.
Be aware that there is still a known issue where the "frame capture" feature will not work on devices with non-monolithic drives (like yours) but tracing and the other features should work fine.
