I'm trying to profile a game with MGD 2.0.1 without success. So far my status is that I successfully managed to connect to target in the MGD GUI but no trace data is displayed.
Logcat is not displaying any information on the intercepted lib. I don't know what I am missing.
ligGLES_mgd.so and mgddaemon are inside /system/lib/egl and there's a symbolic link libGLES_mgd.so pointing to libGLES.so
I tried both with processlist.cfg and without it. egl.cfg contains "0 0 mali" (as per instructions on android 4.4 telling no need to do "0 0 mgd"
Host: Windows 7
Target: Note 4 910H Android 4.4.4 running an APK generated by Unity 4.6
Kind Regards,
Phil Lira.
Hi Phil,
If logcat is not displaying any output from the interceptor lib then this is because the Android EGL loader is not picking it up. The EGL loader mechanism on Android 4.4, from memory, basically looks for something called libGLES.so, and if it doesn't find it, looks for anything matching the now deprecated tag naming scheme, libGLES_<tag>.so, and takes the first thing it sees. The user guide seems to expect that the driver won't have gone for the primary method of just calling the library libGLES.so, so the intention is that you create a symlink called libGLES.so that points to libGLES_mgd.so, and EGL picks it up first. I'd sanity check that there isn't a libGLES.so in /vendor/lib/egl etc which might be getting picked up first, and also, have you restarted the OS before attempting to trace an app? The system must be restarted in order for the new lib to be picked up (older versions of Android it was sufficient to just restart the app process by force closing it).
If you still have trouble can you provide directory listings of /vendor/lib/egl/ and /system/lib/egl/ as they were before you started?
Cheers,
Chris
Thanks Chris.
I restarted the OS. Here's my directory listing of both /system/lib/egl and /vendor/lib/egl
The symbolic link from libGLES_mgd to libGLES is there as you can see. I tried using egl.cfg with both "0 0 mgd" and "0 0 mali". Restarting OS between changes.
There are two apps in gpr_list.cfg, none of them are mine.
Still no info on the intercep lib showing up on logcat and on mgd client.
The only thing I noticed on logcat, and might be unrelated to this, is the following line:
W/ContextImpl( 3367): Calling a method in the system process without a qualified user: android.app.ContextImpl.sendBroadcast:1510 com.absolute.android.persistservice.a.run:1059 java.lang.Thread.run:841
I really do know what to do next...
Phil Lira
Hi Philra,
ADB is supposed to come up before surfaceflinger etc so you should still have ADB access to revert the changes. It bricked when you put the interceptor at /vendor/lib/egl/libGLES.so? That's good information, does it do the same when you put it at /system/lib/egl, naming it libGLES.so rather than creating a symlink? If not then that definitely points to non-vanilla EGL code in that Android build. To the best of my knowledge we support vanilla 4.4.4 but I will double check that with the team.
Chris Varnsverry escreveu: It bricked when you put the interceptor at /vendor/lib/egl/libGLES.so?
Positive. I'm not sure how to revert through ADB since the OS is loooping and Volume Up, Power + Home doesn't work. :O.
I'm not sure if this device is vanilla or not. I'll probably need a binary/bootloader to flash from scratch and I might get it or not depending on the mobile test team providing me one.
Hi Philira,
I can confirm that we've had MGD working with Android 4.4.4, on a Note 4 N910. I'm confirming exactly which variant. They reported that it worked fine from /system/lib/egl so I'm a bit stumped on this one. If you put libGLES_mgd.so in /system/lib/egl/ and rename it to libGLES.so does it work? Worst case if ADB isn't working then you can grab a binary from http://www.sammobile.com/firmwares/database/SM-N910H/ and use Odin to flash it.
Ok. I applied a firmware I got from my team got the phone back working.
I tried copying libGLES_mgd.so to system/lib/egl with the name of libGLES.so. Bricked the device again.
So it seems the system can't use _mgd variant. Any ideas why?
I am sorry to hear you are having such annoying technical issues. We are investigating what may have happened in your case, we are using MGD successfully on Note 4 here.
We will let you know as soon as we have more information.
In the meantime, would you be able to send us a logcat of the device before it gets stuck? That's useful information.
Thanks,
Lorenzo
You mention you got a firmware from your team... Can you test it on a stock firmware available from SamMobile? Is there anything special / non-standard about the firmware your team are giving you? This seems to be a variable worth ruling out. Also one of our guys noticed in your original screenshot the link was pointing to ligGLES_mgd.so, notice the g, so that explains why it didn't brick in that case.
Thanks Chris. I really appreciatte the effort you guys are putting into this.
Really nice you catch that link typo. I'll pay more attention from now on.
I'm downloading one of the firmwares from SamMobile (N910C NK5). I know I previously said to you it was a N910H. That was a mistake, the 910H I have is not the device I'm testing this on. MGD is supposed to also work on 910C right?
Due to my NDA I cannot disclose any detailed information of the firmware version I flashed last (which is different from the first one I had).
I'll let you know as soon as I flash the SamMobile one and them I'll provide all the detailed info on it. I should get back to you tomorrow at most.
Phil
Hi Lorenzo,
I'm flashing a stock firmware from SamMobile as Chris advised and hopefully we'll be able to track this more easily with the same exact firmware.
Lorenzo Dal Col escreveu: In the meantime, would you be able to send us a logcat of the device before it gets stuck? That's useful information.
Do you mean when the device got stucked in OS loop? I'm not sure how to attach ADB in that case. When the device is bricked I can only get to the ODIN Download screen.
Let me know whatever you want to try to figure out this and I'll do.
It would be really great if I could get MGD working by the end of this week.
No worries, understand NDAness AFAIK there is the H C and S which are all Exynos (someone feel free to correct me) but in any case you seem to have an Exynos one so the SoC shouldn't be an issue. The ROM at this point is much more likely to be problematic, so if we can confirm that you could raise it with the source of your rom... It's possible they have made some mods to the driver stack which MGD is not compatible with, i.e. the OS is looking for some hooks that are not there etc.
Hth,
I believe S is Snapdragon. I don't have any with me now. So far, only Exynos/Mali T Love
Sorry I didn't get back to you yesterday. So I finally managed to get it working. It was indeed a problem with my firmware. The MGD is being able to intercep now although It's giving more overhead to my game than I expected.
I'll be playing with the tool and getting to know it better.
I really wanted to say a big thank you for all the effort you put into helping me with this.
Yeah, this is expected. The interceptor has to package and pipe a huge amount of data off the target (every API call, paramaters, data buffers, etc), so it's relatively invasive. In general I find most apps stay usable, even for touch screen events, so although the framerate does suffer quite badly it is still running at "interactive" levels of performance. The only modes which drop off from that are the one which are capturing framebuffer output for every drawcall - that requires us to flush the rendering pipeline, and take a screen shot - which is always going to be expensive.
In general if you can stick to "best practise" - using VBOs already in memory rather than client-side attribute arrays, etc - then you can minimize the amount of data the interceptor has to pipe off target every frame. This will also help your app performance in the general case (if MGD has to move data around, then that is data the driver would also have had to move around).
Hope you find the tool useful, and let us know if you have any feedback on the user experience or feature set.
Cheers,Pete
Sorry for taking this long to provide a feedback. I was out of the studio and came back this week.
Although I had a short time to play with it, it felt intuitive and I managed to spot right on some batching problems. The only thing I kind of missed (debugger wise) is the ability to set a breakpoint in a specific OGL call and the ability to see mipmaps (setting a color for each level). Something similiar to the shader map.
Somehow I was expecting MGD to provide me an option to also profile my app. (something in the line of Adreno Profiler that has light, mid and deep profiling options).
I'd be interested in a fast profiler tool that allows me to spot bottleneck issues really easy by allowing me to: replace all textures for ones of 4x4 pixels, disable specific OGL calls and force states (like disabling alpha blend), rendering to a smaller viewport, etc.
Do you have a profiler tool that supports that? If not, do you have a recommendation for me?
thank you for feedback. For profiling we have a different tool: DS-5 Streamline. It allows profiling CPU and GPU hardware counters, as well as software events from the Linux kernel and kernel drivers. You cannot do replacements with it yet, but it is something we are thinking about. At the moment setting up Streamline to work with Mali GPUs requires recompiling the Mali driver with the right options (see Using DS-5 Streamline with Mali on Google Nexus 10).
As a general note, rather than pushing for an experimental approach, like trying 4x4 textures, change states, render to smaller viewport, we usually prefer a more analytical approach. With MGD and Streamline we aim to let the tool show you what is going on in the system, and find the reason of the bottleneck, understanding why something is slowing it down. This allows focusing on the whole system, also taking into account energy efficiency rather than just FPS.
Still, I acknowledge that what you listed can be very useful features, and some of which are on our 2015 roadmap for Mali tools.
Thanks for taking the time to get back to this.
I agree with you about the analytical approach. However, most of the profilers I used didn't provide me enough GPU data to identify the bottleneck analytically, and I understand that due to the inherent difficulty to timestamp GPU work. What I usually end up doing is resorting to these overrides to get precise timing. For instance, If I had the ability to override a specific shader program to a (write gl_Position = mvp * v and gl_Fragment = white) I could know for sure how much time this was taking by taking the difference of times (if this was my bottleneck, of course). Of couse this could be implemented on the application side and we did some of these in the past but it would be even nicer to have a tool providing us that.
I'm really interested now in testing DS-5 and even more looking forward to attend your GDC talk on mobile optimization.
