I am getting these errors (about 200 of these) when using bgfx_backend as gles (render_gl.cpp) for MAME (for Android) for Mali T860 MP4. The same are coming during the init when the various texture formats (struct TextureFormat) are being checked for their support in the hardware. Vulkan bakend works fine but is much slower than gles and has glitches hence I would like to use gles.
When I check some parameters (from /sys/module/mali/parameters) from the device I see this - $ cat mali_shared_mem_size 4294967295 $ cat mali_debug_level 2 $ cat mali_dedicated_mem_size 0
It seems from the dump above that no dedicated GPU memory is allocated and hence GPU/CPU share the memory hence I am confused with the first two issues (below). Currently I have a hack where I comment out anything above 30 in the struct TextureFormat but still have occassional crashes.
Please tell me whether more information is needed.
E/mali_so: encounter the first gles_error : 0x0001 : failed to allocate CPU memory (gles_texture_compressed_tex_image_2d at hardware/rockchip/mali_so/driver/product/gles/src/texture/mali_gles_texture_api.c:655) E/mali_so: encounter the first gles_error : 0x0002 : failed to allocate GPU memory (gles_texture_compressed_tex_image_2d at hardware/rockchip/mali_so/driver/product/gles/src/texture/mali_gles_texture_api.c:700) E/mali_so: encounter the first gles_error : 0x0003 : execution failed (gles_texturep_convert_internalformat at hardware/rockchip/mali_so/driver/product/gles/src/texture/mali_gles_texture_helpers.c:184)
I think I should apologize for not debugging further. The memory error is not right and when it came I got confused as to why a memory error. Actual I am getting errors 0x500 and 0x501 -
GL_INVALID_ENUM, 0x0500 Given when an enumeration parameter is not a legal enumeration for that function. This is given only for local problems; if the spec allows the enumeration in certain circumstances, where other parameters or state dictate those circumstances, then GL_INVALID_OPERATION is the result instead.
GL_INVALID_VALUE, 0x0501 Given when a value parameter is not a legal value for that function. This is only given for local problems; if the spec allows the value in certain circumstances, where other parameters or state dictate those circumstances, then GL_INVALID_OPERATION is the result instead.
I am attaching the message dump files here. I have also filed the same at the BGFX site as well. All the warnings/errors (200) leads to a SIGTRAP -
2019-11-07 16:29:53.813 5803-5856/? A/libc: Fatal signal 5 (SIGTRAP), code 1 in tid 5856 (SDLThread), pid 5803 (rg.mamedev.mame)
Any help/insight will be great. Looking forward for any reply.
BC1 is not supported by hardware (data below)
../../../../../3rdparty/bgfx/src/renderer_gl.cpp (1531): **BGFX In isTextureFormatValid: 0, 0, 0, BC1** ../../../../../3rdparty/bgfx/src/renderer_gl.cpp (1450): BGFX In initTestTexture: _format - 0, _srgb - 0, _mipmaps - 0, _array - 0, _dim - 16 ../../../../../3rdparty/bgfx/src/renderer_gl.cpp (1491): BGFX initTestTexture: calling compressedtexImage - ii - 0, internalFmt - 0x83f1 ../../../../../3rdparty/bgfx/src/renderer_gl.cpp (1393): BGFX compressedTexImage target - 0xde1, level - 0, width - 16, height - 16, imagesize - 128
D/: ../../../../../3rdparty/bgfx/src/renderer_gl.cpp (1394): BGFX compressedTexImage _internalformat - 0x83f1, _depth - 0, _border - 0, _data - 1828711968 ../../../../../3rdparty/bgfx/src/renderer_gl.cpp (1434): BGFX calling glCompressedTexImage2D E/mali_so: encounter the first gles_error : 0x0001 : failed to allocate CPU memory (gles_texture_compressed_tex_image_2d at hardware/arm/maliT760/driver/product/gles/src/texture/mali_gles_texture_api.c:655) to dump the call_stack of the first error : I/[Gralloc]: Got handle 2 for fd 62 leave, w : 1920, h : 1080, format : 0x1,internal_format : 0x1, usage : 0xb00. size=8294400,pixel_stride=1920,byte_stride=7680 leave: prime_fd=62,share_attr_fd=63 D/mali_so: #00 pc 00000000005599b4 /vendor/lib64/egl/libGLES_mali.so (glCompressedTexImage2D+112) #1 pc 0000000002e28194 /data/app/org.mamedev.mame-VgxC69JDTO58L9hu88n6Pg==/lib/arm64/libmain.so (bgfx::gl::initTestTexture(bgfx::TextureFormat::Enum, bool, bool, bool, int)+392) #2 pc 0000000002e635c0 /data/app/org.mamedev.mame-VgxC69JDTO58L9hu88n6Pg==/lib/arm64/libmain.so (bgfx::gl::isTextureFormatValid(bgfx::TextureFormat::Enum, bool, bool, bool, int)+1468) #3 pc 0000000002e2a960 /data/app/org.mamedev.mame-VgxC69JDTO58L9hu88n6Pg==/lib/arm64/libmain.so (bgfx::gl::RendererContextGL::init(bgfx::Init const&)+5928) #4 pc 0000000002e2888c /data/app/org.mamedev.mame-VgxC69JDTO58L9hu88n6Pg==/lib/arm64/libmain.so (bgfx::gl::rendererCreate(bgfx::Init const&)+104) #5 pc 0000000002e07418 /data/app/org.mamedev.mame-VgxC69JDTO58L9hu88n6Pg==/lib/arm64/libmain.so (bgfx::rendererCreate(bgfx::Init const&)+900) D/mali_so: #6 pc 0000000002e0a394 /data/app/org.mamedev.mame-VgxC69JDTO58L9hu88n6Pg==/lib/arm64/libmain.so (bgfx::Context::rendererExecCommands(bgfx::CommandBuffer&)+12080) #7 pc 0000000002e01d90 /data/app/org.mamedev.mame-VgxC69JDTO58L9hu88n6Pg==/lib/arm64/libmain.so (bgfx::Context::renderFrame(int)+212) #8 pc 0000000002e01be4 /data/app/org.mamedev.mame-VgxC69JDTO58L9hu88n6Pg==/lib/arm64/libmain.so (bgfx::renderFrame(int)+172) #9 pc 0000000002e03c38 /data/app/org.mamedev.mame-VgxC69JDTO58L9hu88n6Pg==/lib/arm64/libmain.so (bgfx::Context::renderThread(bx::Thread*, void*)+36) #10 pc 0000000002ec6a14 /data/app/org.mamedev.mame-VgxC69JDTO58L9hu88n6Pg==/lib/arm64/libmain.so (bx::ThreadInternal::threadFunc(void*)+36) #11 pc 0000000000067d80 /system/lib64/libc.so (__pthread_start(void*)+36) #12 pc 000000000001ec18 /system/lib64/libc.so (__start_thread+68) D/: ../../../../../3rdparty/bgfx/src/renderer_gl.cpp (1494): BGFX initTestTexture: compressedtexImage returns - getGlError reports - 0x500 ../../../../../3rdparty/bgfx/src/renderer_gl.cpp (1565): BGFX WARN TextureFormat::BC1 is not supported (500: GL_INVALID_ENUM).
Hardware reports that it supports ETC1 (data below)
../../../../../3rdparty/bgfx/src/renderer_gl.cpp (1531): BGFX In isTextureFormatValid: 0, 0, 0, ETC1 ../../../../../3rdparty/bgfx/src/renderer_gl.cpp (1450): BGFX In initTestTexture: _format - 7, _srgb - 0, _mipmaps - 0, _array - 0, _dim - 16 ../../../../../3rdparty/bgfx/src/renderer_gl.cpp (1491): BGFX initTestTexture: calling compressedtexImage - ii - 0, internalFmt - 0x8d64 ../../../../../3rdparty/bgfx/src/renderer_gl.cpp (1393): BGFX compressedTexImage target - 0xde1, level - 0, width - 16, height - 16, imagesize - 128 ../../../../../3rdparty/bgfx/src/renderer_gl.cpp (1394): BGFX compressedTexImage _internalformat - 0x8d64, _depth - 0, _border - 0, _data - 1828711968 ../../../../../3rdparty/bgfx/src/renderer_gl.cpp (1434): BGFX calling glCompressedTexImage2D
D/: ../../../../../3rdparty/bgfx/src/renderer_gl.cpp (1494): BGFX initTestTexture: compressedtexImage returns - getGlError reports - 0x0
A FAIL CASE of a texture supported but then still throws an error
../../../../../3rdparty/bgfx/src/renderer_gl.cpp (1531): **BGFX In isTextureFormatValid: 0, 0, 0, ASTC5x5** ../../../../../3rdparty/bgfx/src/renderer_gl.cpp (1450): BGFX In initTestTexture: _format - 21, _srgb - 0, _mipmaps - 0, _array - 0, _dim - 16 ../../../../../3rdparty/bgfx/src/renderer_gl.cpp (1491): BGFX initTestTexture: calling compressedtexImage - ii - 0, internalFmt - 0x93b2 ../../../../../3rdparty/bgfx/src/renderer_gl.cpp (1393): BGFX compressedTexImage target - 0xde1, level - 0, width - 16, height - 16, imagesize - 192 ../../../../../3rdparty/bgfx/src/renderer_gl.cpp (1394): BGFX compressedTexImage _internalformat - 0x93b2, _depth - 0, _border - 0, _data - 1828711904 ../../../../../3rdparty/bgfx/src/renderer_gl.cpp (1434): BGFX calling glCompressedTexImage2D
E/mali_so: encounter the first gles_error : 0x0002 : failed to allocate GPU memory (gles_texture_compressed_tex_image_2d at hardware/arm/maliT760/driver/product/gles/src/texture/mali_gles_texture_api.c:700) to dump the call_stack of the first error : D/mali_so: #00 pc 00000000005599b4 /vendor/lib64/egl/libGLES_mali.so (glCompressedTexImage2D+112) D/mali_so: #1 pc 0000000002e28194 /data/app/org.mamedev.mame-VgxC69JDTO58L9hu88n6Pg==/lib/arm64/libmain.so (bgfx::gl::initTestTexture(bgfx::TextureFormat::Enum, bool, bool, bool, int)+392) #2 pc 0000000002e635c0 /data/app/org.mamedev.mame-VgxC69JDTO58L9hu88n6Pg==/lib/arm64/libmain.so (bgfx::gl::isTextureFormatValid(bgfx::TextureFormat::Enum, bool, bool, bool, int)+1468) #3 pc 0000000002e2a960 /data/app/org.mamedev.mame-VgxC69JDTO58L9hu88n6Pg==/lib/arm64/libmain.so (bgfx::gl::RendererContextGL::init(bgfx::Init const&)+5928) #4 pc 0000000002e2888c /data/app/org.mamedev.mame-VgxC69JDTO58L9hu88n6Pg==/lib/arm64/libmain.so (bgfx::gl::rendererCreate(bgfx::Init const&)+104) #5 pc 0000000002e07418 /data/app/org.mamedev.mame-VgxC69JDTO58L9hu88n6Pg==/lib/arm64/libmain.so (bgfx::rendererCreate(bgfx::Init const&)+900) #6 pc 0000000002e0a394 /data/app/org.mamedev.mame-VgxC69JDTO58L9hu88n6Pg==/lib/arm64/libmain.so (bgfx::Context::rendererExecCommands(bgfx::CommandBuffer&)+12080) #7 pc 0000000002e01d90 /data/app/org.mamedev.mame-VgxC69JDTO58L9hu88n6Pg==/lib/arm64/libmain.so (bgfx::Context::renderFrame(int)+212) #8 pc 0000000002e01be4 /data/app/org.mamedev.mame-VgxC69JDTO58L9hu88n6Pg==/lib/arm64/libmain.so (bgfx::renderFrame(int)+172) #9 pc 0000000002e03c38 /data/app/org.mamedev.mame-VgxC69JDTO58L9hu88n6Pg==/lib/arm64/libmain.so (bgfx::Context::renderThread(bx::Thread*, void*)+36) #10 pc 0000000002ec6a14 /data/app/org.mamedev.mame-VgxC69JDTO58L9hu88n6Pg==/lib/arm64/libmain.so (bx::ThreadInternal::threadFunc(void*)+36) #11 pc 0000000000067d80 /system/lib64/libc.so (__pthread_start(void*)+36) #12 pc 000000000001ec18 /system/lib64/libc.so (__start_thread+68) D/: ../../../../../3rdparty/bgfx/src/renderer_gl.cpp (1494): BGFX initTestTexture: compressedtexImage returns - getGlError reports - 0x501 ../../../../../3rdparty/bgfx/src/renderer_gl.cpp (1565): BGFX WARN TextureFormat::ASTC5x5 is not supported (501: GL_INVALID_VALUE).
Some more data (yes I know I need to upgrade the ARM Mali driver by a whole 1276.78 Miles :) )
../../../../../3rdparty/bgfx/src/renderer_gl.cpp (1899): BGFX Vendor: ARM ../../../../../3rdparty/bgfx/src/renderer_gl.cpp (1900): BGFX Renderer: Mali-T860 ../../../../../3rdparty/bgfx/src/renderer_gl.cpp (1901): BGFX Version: OpenGL ES 3.2 v1.r18p0-01rel0.b959385dd04b968bd095a8c31665a39a ../../../../../3rdparty/bgfx/src/renderer_gl.cpp (1902): BGFX GLSL version: OpenGL ES GLSL ES 3.20
All the compressed texture supported by the hardware
D/: ../../../../../3rdparty/bgfx/src/renderer_gl.cpp (1846): BGFX GL_NUM_COMPRESSED_TEXTURE_FORMATS 69 ../../../../../3rdparty/bgfx/src/renderer_gl.cpp (1869): BGFX 0: 8b90 <unknown> ../../../../../3rdparty/bgfx/src/renderer_gl.cpp (1869): BGFX 1: 8b91 <unknown> ../../../../../3rdparty/bgfx/src/renderer_gl.cpp (1869): BGFX 2: 8b92 <unknown> ../../../../../3rdparty/bgfx/src/renderer_gl.cpp (1869): BGFX 3: 8b93 <unknown> ../../../../../3rdparty/bgfx/src/renderer_gl.cpp (1869): BGFX 4: 8b94 <unknown> ../../../../../3rdparty/bgfx/src/renderer_gl.cpp (1869): BGFX 5: 8b95 <unknown> ../../../../../3rdparty/bgfx/src/renderer_gl.cpp (1869): BGFX 6: 8b96 <unknown> ../../../../../3rdparty/bgfx/src/renderer_gl.cpp (1869): BGFX 7: 8b97 <unknown> ../../../../../3rdparty/bgfx/src/renderer_gl.cpp (1869): BGFX 8: 8b98 <unknown> ../../../../../3rdparty/bgfx/src/renderer_gl.cpp (1869): BGFX 9: 8b99 <unknown> ../../../../../3rdparty/bgfx/src/renderer_gl.cpp (1869): BGFX 10: 8d64 ETC1 ../../../../../3rdparty/bgfx/src/renderer_gl.cpp (1869): BGFX 11: 9274 ETC2 ../../../../../3rdparty/bgfx/src/renderer_gl.cpp (1869): BGFX 12: 9275 <unknown> ../../../../../3rdparty/bgfx/src/renderer_gl.cpp (1869): BGFX 13: 9278 ETC2A ../../../../../3rdparty/bgfx/src/renderer_gl.cpp (1869): BGFX 14: 9279 <unknown> ../../../../../3rdparty/bgfx/src/renderer_gl.cpp (1869): BGFX 15: 9276 ETC2A1 ../../../../../3rdparty/bgfx/src/renderer_gl.cpp (1869): BGFX 16: 9277 <unknown> ../../../../../3rdparty/bgfx/src/renderer_gl.cpp (1869): BGFX 17: 9270 <unknown> ../../../../../3rdparty/bgfx/src/renderer_gl.cpp (1869): BGFX 18: 9272 <unknown> ../../../../../3rdparty/bgfx/src/renderer_gl.cpp (1869): BGFX 19: 9271 <unknown> ../../../../../3rdparty/bgfx/src/renderer_gl.cpp (1869): BGFX 20: 9273 <unknown> ../../../../../3rdparty/bgfx/src/renderer_gl.cpp (1869): BGFX 21: 93b0 ASTC4x4 ../../../../../3rdparty/bgfx/src/renderer_gl.cpp (1869): BGFX 22: 93b1 <unknown> ../../../../../3rdparty/bgfx/src/renderer_gl.cpp (1869): BGFX 23: 93b2 ASTC5x5 ../../../../../3rdparty/bgfx/src/renderer_gl.cpp (1869): BGFX 24: 93b3 <unknown> ../../../../../3rdparty/bgfx/src/renderer_gl.cpp (1869): BGFX 25: 93b4 ASTC6x6 ../../../../../3rdparty/bgfx/src/renderer_gl.cpp (1869): BGFX 26: 93b5 ASTC8x5 ../../../../../3rdparty/bgfx/src/renderer_gl.cpp (1869): BGFX 27: 93b6 ASTC8x6 ../../../../../3rdparty/bgfx/src/renderer_gl.cpp (1869): BGFX 28: 93b7 <unknown> ../../../../../3rdparty/bgfx/src/renderer_gl.cpp (1869): BGFX 29: 93b8 ASTC10x5 ../../../../../3rdparty/bgfx/src/renderer_gl.cpp (1869): BGFX 30: 93b9 <unknown> ../../../../../3rdparty/bgfx/src/renderer_gl.cpp (1869): BGFX 31: 93ba <unknown> ../../../../../3rdparty/bgfx/src/renderer_gl.cpp (1869): BGFX 32: 93bb <unknown> ../../../../../3rdparty/bgfx/src/renderer_gl.cpp (1869): BGFX 33: 93bc <unknown>D/: ../../../../../3rdparty/bgfx/src/renderer_gl.cpp (1869): BGFX 34: 93bd <unknown> ../../../../../3rdparty/bgfx/src/renderer_gl.cpp (1869): BGFX 35: 93d0 <unknown> ../../../../../3rdparty/bgfx/src/renderer_gl.cpp (1869): BGFX 36: 93d1 <unknown> ../../../../../3rdparty/bgfx/src/renderer_gl.cpp (1869): BGFX 37: 93d2 <unknown> ../../../../../3rdparty/bgfx/src/renderer_gl.cpp (1869): BGFX 38: 93d3 <unknown> ../../../../../3rdparty/bgfx/src/renderer_gl.cpp (1869): BGFX 39: 93d4 <unknown> ../../../../../3rdparty/bgfx/src/renderer_gl.cpp (1869): BGFX 40: 93d5 <unknown> ../../../../../3rdparty/bgfx/src/renderer_gl.cpp (1869): BGFX 41: 93d6 <unknown> ../../../../../3rdparty/bgfx/src/renderer_gl.cpp (1869): BGFX 42: 93d7 <unknown> ../../../../../3rdparty/bgfx/src/renderer_gl.cpp (1869): BGFX 43: 93d8 <unknown> ../../../../../3rdparty/bgfx/src/renderer_gl.cpp (1869): BGFX 44: 93d9 <unknown> ../../../../../3rdparty/bgfx/src/renderer_gl.cpp (1869): BGFX 45: 93da <unknown> ../../../../../3rdparty/bgfx/src/renderer_gl.cpp (1869): BGFX 46: 93db <unknown> ../../../../../3rdparty/bgfx/src/renderer_gl.cpp (1869): BGFX 47: 93dc <unknown> ../../../../../3rdparty/bgfx/src/renderer_gl.cpp (1869): BGFX 48: 93dd <unknown> ../../../../../3rdparty/bgfx/src/renderer_gl.cpp (1869): BGFX 49: 93c0 <unknown> ../../../../../3rdparty/bgfx/src/renderer_gl.cpp (1869): BGFX 50: 93c1 <unknown> ../../../../../3rdparty/bgfx/src/renderer_gl.cpp (1869): BGFX 51: 93c2 <unknown> ../../../../../3rdparty/bgfx/src/renderer_gl.cpp (1869): BGFX 52: 93c3 <unknown> ../../../../../3rdparty/bgfx/src/renderer_gl.cpp (1869): BGFX 53: 93c4 <unknown> ../../../../../3rdparty/bgfx/src/renderer_gl.cpp (1869): BGFX 54: 93c5 <unknown> ../../../../../3rdparty/bgfx/src/renderer_gl.cpp (1869): BGFX 55: 93c6 <unknown> ../../../../../3rdparty/bgfx/src/renderer_gl.cpp (1869): BGFX 56: 93c7 <unknown> ../../../../../3rdparty/bgfx/src/renderer_gl.cpp (1869): BGFX 57: 93c8 <unknown> ../../../../../3rdparty/bgfx/src/renderer_gl.cpp (1869): BGFX 58: 93c9 <unknown> ../../../../../3rdparty/bgfx/src/renderer_gl.cpp (1869): BGFX 59: 93e0 <unknown> ../../../../../3rdparty/bgfx/src/renderer_gl.cpp (1869): BGFX 60: 93e1 <unknown> ../../../../../3rdparty/bgfx/src/renderer_gl.cpp (1869): BGFX 61: 93e2 <unknown> ../../../../../3rdparty/bgfx/src/renderer_gl.cpp (1869): BGFX 62: 93e3 <unknown> ../../../../../3rdparty/bgfx/src/renderer_gl.cpp (1869): BGFX 63: 93e4 <unknown> ../../../../../3rdparty/bgfx/src/renderer_gl.cpp (1869): BGFX 64: 93e5 <unknown> ../../../../../3rdparty/bgfx/src/renderer_gl.cpp (1869): BGFX 65: 93e6 <unknown> ../../../../../3rdparty/bgfx/src/renderer_gl.cpp (1869): BGFX 66: 93e7 <unknown> ../../../../../3rdparty/bgfx/src/renderer_gl.cpp (1869): BGFX 67: 93e8 <unknown> ../../../../../3rdparty/bgfx/src/renderer_gl.cpp (1869): BGFX 68: 93e9 <unknown>
