Hi.
I need help with generating the report using Performance Advisor.
I get the following error when generating the report for Mali-G77 MC7 Valhall.
Fetching data...Preparing report type html...Problems were found preparing html report:ERROR: Cannot find Execution Engine cycles. Make sure your capture includes 'Mali Core EE Instructions - Executed' / Mali Core EE Instructions - Executed instructions'.
The problem is, there is not counter which PA is asking for. It was asking for more counters as well, which I added and those errors were gone, but this counter doesn't seem to exist for G77 (it is available for Bifrost though! )
I tried getting PA report on Mali-G71 MP2 Bifrost as well, but I got the following error:
Extracting zip file to a temporary directory.Creating report database in capture directory...Importing capture...Fetching data...Preparing report type html...Processing data...Index 2 out of bounds for length 2java.lang.IndexOutOfBoundsException: Index 2 out of bounds for length 2 at java.base/jdk.internal.util.Preconditions.outOfBounds(Unknown Source) at java.base/jdk.internal.util.Preconditions.outOfBoundsCheckIndex(Unknown Source) at java.base/jdk.internal.util.Preconditions.checkIndex(Unknown Source) at java.base/java.util.Objects.checkIndex(Unknown Source) at java.base/java.util.ArrayList.get(Unknown Source) at com.arm.meerkat.application.capturedata.FrameProvider.populateFpsList(FrameProvider.java:430) at com.arm.meerkat.application.capturedata.FrameProvider.doExecute(FrameProvider.java:41) at com.arm.meerkat.application.capturedata.Provider.execute(Provider.java:82) at com.arm.meerkat.application.capturedata.CaptureData.execute(CaptureData.java:134) at com.arm.meerkat.application.PerformanceAdvisor.call(PerformanceAdvisor.java:268) at com.arm.meerkat.application.Application.start(Application.java:94) at com.arm.meerkat.application.Application.start(Application.java:1) at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:203) at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:137) at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:107) at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:400) at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:255) at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(Unknown Source) at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source) at java.base/java.lang.reflect.Method.invoke(Unknown Source) at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:660) at org.eclipse.equinox.launcher.Main.basicRun(Main.java:597) at org.eclipse.equinox.launcher.Main.run(Main.java:1468)
I would be grateful for any help with this.
Thanks.
Hi Chakshu, Thanks for getting in touch, and sorry you’ve been having problems getting started.
We’ve just released Arm Mobile Studio 2020.1 - it was published yesterday. This new release will definitely fix your first problem as it adds Performance Advisor support for the Mali Valhall GPUs; they were not supported in the version of Performance Advisor released in Mobile Studio 2020.0. You can download the latest version from here:
I will raise the second issue that you reported with the engineering team, but it might be worth trying out the new release here also. We’ve fixed a number of stability issues, so there is a chance that it is fixed. If that doesn’t work are you able to share the Streamline .apc capture? This makes it faster for us to reproduce your problem and provide a solution.
Kind regards, Pete
