Mali test program returned error messages - contains memory allocation problem
I need your help for GPU(Mali T624) porting on fbdev/X11 Linux.
I got error messages when I implement GPU test programs.
I have finished to set the environment for fbdev and had build full DDK and installed kernel modules(kbase.ko, mali.ko, mali_kbase as built-in) and copied generated libraries under /usr/local/lib,
and executed 'fbset "640x480-60" -depth 32'.
Can you tell me why I got these messages?
I added test results below.
Thank you.
1) mali_base_jd_test
# ./mali_base_jd_test
TEST FAILED: base_pmem_alloc failed - cannot continue!
2) mali_base_map_test_quick
# ./mali_base_map_test_quick
==>[ASSERT] (mali_base_map_t) : In file: base/platform_dummy/plat/mali_base_plat_memory.h  line: 122 base_tmem_to_mem
BASE_TMEM_INVALID_HANDLE != handle
Aborted
3) mali_base_ump_test
# ./mali_base_ump_test
Got ump id 1
WARNING: base_tmem_import failed
==>[ERROR] (mali_base_ump_t) BASE: In file: base/src/mali_base_kbase.c  line: 269 base_jd_event_term
Could not notify message handler of driver termination. As a result, your application may not terminate properly.
Aborted
4) mali_egl_integration_tests
# ./mali_egl_integration_tests
UTF: Platform Provenance
  Hardware: T62X r1p1
  OS:       Linux
UTF: Running egl_surface_suite
==>[WARN] (mali_egl_integr) CCTX: In file: cctx/src/mali_cctx.c  line: 254 cctx_new
Context creation failed from module: CFRAME
==>[ERROR] (mali_egl_integr) BASE: In file: base/src/mali_base_kbase.c  line: 269 base_jd_event_term
Aborted
5) mali_gles_integration_suite
# ./mali_gles_integration_suite
  Mali GLES integration tests
  Hardware: T62X r1p1
  OS:       Linux
UTF: Running gles1_api_integration
==>[WARN] (mali_gles_integ) CCTX: In file: cctx/src/mali_cctx.c  line: 254 cctx_new
==>[ERROR] (mali_gles_integ) BASE: In file: base/src/mali_base_kbase.c  line: 269 base_jd_event_term
Aborted
