Problems during setup Mali Graphics Debugger on Android 4.1
System Info
graphics: Mali-400MP, android version: 4.1.1, Mali Graphics Debugger: 2.0
when I try to setup the Mali Graphics Debugger  on android device following the user guide.
the libGLES_mgd say it can't load the libGLES_mali.so (because this library isn't here, but libEGL_mali.so and the other two).
files in /system/lib/egl/ :
shell@android:/system/lib/egl # ls
egl.cfg
libEGL_mali.so
libGLES_android.so
libGLES_mgd.so
libGLESv1_CM_mali.so
libGLESv2_mali.so
but the mgd only try to load libGLES_mali.so (/vendor/lib/egl/ have been mapped to /system/lib/egl/):
I/libGLES_mgd(30489): libGLES_mgd is in a system folder
E/libGLES_mgd(30489): Failed to parse process mappings.
D/libEGL  (30489): loaded /vendor/lib/egl/libGLES_mgd.so
I/mgd_interceptor(30489): Interceptor constructor called
I/mgd_interceptor(30489): Trying to connect to the daemon...
I/mgd_interceptor(30489): Connected to the daemon.
I/mgd_interceptor(30489): Sending header...
I/mgd_interceptor(30489): Header sent.
I/mgd_interceptor(30489): Reading process name for PID=30489
I/mgd_interceptor(30489): Process = ******
I/mgd_interceptor(30489): Could not open /system/lib/egl/processlist.cfg, so tracing by default
I/mgd_interceptor(30489): Attempting to load libEGL at /vendor/lib/egl/libGLES_mali.so ...
E/mgd_interceptor(30489): Could not get handle to libEGL (dlerror=`Cannot load library: load_library[1093]: Library '/vendor/lib/egl/libGLES_mali.so' not found`).
W/mgd_interceptor(30489): Unable to locate library libEGL, no functions for this library will be intercepted
E/mgd_interceptor(30489): User called extension function eglGetProcAddress} which does not exist
D/NmgDebug(30489): 1419480704.00: NmgBreakPad.cpp: 281: Crash caught.
E/Launcher( 2083): launcher is onStop.............
any suggestion is appreciated
