Mali GPU performance counters query
Dear Team
I came across  HWCPipe library to access mali gpu performance counters from ARM. I would like to know if I sample performance counters each millisecond  independent of any graphics application as a separate process (Just hwcpipe apis) then is it shows the global/system wide count of that particular counter? How can I know at specific time which graphics process it belongs to when multiple gfx processes are running?
I know if i use HWCPipe apis inside gfx process then I can get it per process counters.
I would also like to understand How the gator daemon dumps the counter per process?  If you could provide any pointers then it will be very helpful to understand.
Thank you.
Best Regards,
Vikash
