Multi Render Target (MRT) with FBO
I am trying to implement the multi render target effect of open gl 3 using a single FBO with multiple color attachment points. I am attaching 4 textures(loaded with images) to 4 color attachment points of the FBO. After this ia m trying to blit from the framebuffer. However, i cannot see any output. Could anyone point out the error in my code.
This is an example to demonstrate Multiple Render Targets and framebuffer blits.
    First, we will render a quad that outputs four textures
    per fragment using MRTs.
    Then, we will copy the four color buffers into four screen quadrants
    using framebuffer blits.
code :
#include <EGL/egl.h>
#include <GLES3/gl3.h>
#include <stdlib.h>
#include <math.h>
#include <time.h>
#include <unistd.h>
#include <signal.h>
#include "MultiRenderTarget.h"
#include "imageload.h"
#define mMAXFC 500
extern EGLDisplay    sEGLDisplay;
extern EGLSurface    sEGLSurface;
static const char* samplerNames1[4]=
    "tex1",
    "tex2",
    "tex3",
    "tex4",
struct texImage
    char *fileName;
    GLenum imgFormat;
    const char*  nameOfImageIneternalformat;
char *bmp_texpath[100] = {
    (char*)"./assets/Raw1.bmp",
    (char*)"./assets/Raw2.bmp",
    (char*)"./assets/Raw3.bmp",
    (char*)"./assets/Raw4.bmp",
    GLfloat texcoords_bmp1[] =
        0, 0,
        0, 1,
        1, 1,
        1, 0
int width=res.h_res,height=res.v_res;
GLuint VSObject,FSObject;
GLuint ProgramObject;
GLuint mfbo;
GLuint colorTexId[4];
GLsizei textureWidth =res.h_res;
GLsizei textureHeight = res.v_res;
int MRT_bDone = 0;
int mframeCount = 0;
ImageData img[5] ;
void MRT_signalHandler (int sig)
    switch (sig)
            case SIGINT:
            case SIGTERM:
                GTS_INFO("Ctrl+c pressed\n");
                MRT_bDone = 1;
            default:
                break;
const GLenum attachments[4] =
    GL_COLOR_ATTACHMENT0,
    GL_COLOR_ATTACHMENT1,
    GL_COLOR_ATTACHMENT2,
    GL_COLOR_ATTACHMENT3
int InitFBO ( )
    int i;
    GLint defaultFramebuffer = 0;
    glGetIntegerv ( GL_FRAMEBUFFER_BINDING, &defaultFramebuffer );
       glGenFramebuffers ( 1, &mfbo );
       glBindFramebuffer ( GL_FRAMEBUFFER, mfbo );
    glGenTextures ( 4, &colorTexId[0] );
    for (i = 0; i < 4; ++i)
          GetImageFromBMP(&img[index],bmp_texpath[index]);
          if(img->imagedata != NULL)
           GL_CHECK(glActiveTexture(GL_TEXTURE0 + i));
          glBindTexture ( GL_TEXTURE_2D, colorTexId[i] );
          glTexImage2D ( GL_TEXTURE_2D, 0, GL_RGBA,
                         img->OriginalImageWidth, img->OriginalImageHeight,
                         0, GL_RGBA, GL_UNSIGNED_BYTE, img[i].imagedata );
          glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_WRAP_S, GL_CLAMP_TO_EDGE);
          glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_WRAP_T, GL_CLAMP_TO_EDGE);
          glTexParameteri ( GL_TEXTURE_2D, GL_TEXTURE_MIN_FILTER, GL_NEAREST );
          glTexParameteri ( GL_TEXTURE_2D, GL_TEXTURE_MAG_FILTER, GL_NEAREST );
          glFramebufferTexture2D ( GL_DRAW_FRAMEBUFFER, attachments[i],
                               GL_TEXTURE_2D, colorTexId[i], 0 );
       glDrawBuffers ( 4, attachments );
       if ( GL_FRAMEBUFFER_COMPLETE != glCheckFramebufferStatus ( GL_FRAMEBUFFER ) )
              return false;
       // Restore the original framebuffer
       glBindFramebuffer ( GL_FRAMEBUFFER, defaultFramebuffer );
       return true;
GLfloat vVertices[] = { -1.0f,  1.0f, 0.0f,
                            -1.0f, -1.0f, 0.0f,
                             1.0f, -1.0f, 0.0f,
                             1.0f,  1.0f, 0.0f,
       GLushort indices[] = { 0, 1, 2, 0, 2, 3 };
void DrawGeometry ( )
       // Set the viewport
       glViewport ( 0, 0, width,height );
       // Clear the color buffer
       glClear ( GL_COLOR_BUFFER_BIT );
    glUseProgram ( ProgramObject );
    //glDrawBuffers(4,attachments);
    for(i=0; i<4; i++)
        glDrawBuffers(1,attachments[i]);
    //for(i=0; i<4; i++)
        GL_CHECK(glBindTexture(GL_TEXTURE_2D,colorTexId[i]));
    glVertexAttribPointer ( 0, 3, GL_FLOAT,
                               GL_FALSE, 3 * sizeof ( GLfloat ), vVertices );
    GL_CHECK(glGenBuffers(1, texbuf));
    GL_CHECK(glBindBuffer(GL_ARRAY_BUFFER, texbuf));
    GL_CHECK(glBufferData(GL_ARRAY_BUFFER, sizeof(texcoords_bmp1), texcoords_bmp1, GL_STATIC_DRAW));
    GLuint textureCoordinateLocation1 = GL_CHECK(glGetAttribLocation (uiProgramObject, "attributeTextureCoordinate1"));
    GL_CHECK(glEnableVertexAttribArray(textureCoordinateLocation1));
        GL_CHECK(glVertexAttribPointer(textureCoordinateLocation1, 2, GL_FLOAT, GL_FALSE, 0, 0));
        GL_CHECK(glBindTexture(GL_TEXTURE_2D, colorTexId[i]));
        GL_CHECK(glUniform1i(glGetUniformLocation(ProgramObject, samplerNames1[i]),i));
       // Load the vertex position
       glEnableVertexAttribArray ( 0 );
       // Draw a quad
       glDrawElements ( GL_TRIANGLES, 6, GL_UNSIGNED_SHORT, indices );
// Copy MRT output buffers to screen
void BlitTextures ( )
       int index= 0;
       glBindFramebuffer ( GL_READ_FRAMEBUFFER, mfbo );
    while( mframeCount < mMAXFC && !MRT_bDone){
           // Copy the output red buffer to lower left quadrant
           glReadBuffer ( attachments[(index+0)%4] );
           glBlitFramebuffer ( 0, 0, textureWidth, textureHeight,
                               0, 0, width/2, height/2,
                               GL_COLOR_BUFFER_BIT, GL_LINEAR );
           // Copy the output green buffer to lower right quadrant
           glReadBuffer ( attachments[(index+1)%4] );
                               width/2, 0, width, height/2,
           // Copy the output blue buffer to upper left quadrant
           glReadBuffer ( attachments[(index+2)%4] );
                               width/2, height/2, width, height,
           // Copy the output gray buffer to upper right quadrant
           glReadBuffer ( attachments[(index+3)%4] );
                               0, height/2, width/2, height,
        GTS_INFO("Frame Count ----> %d\n",mframeCount + 1);
                   eglSwapBuffers(sEGLDisplay,sEGLSurface);
        mframeCount ++;
                  usleep(200000);
            index+=1;
            if(index>=4)
            index=0;
// Render to MRTs and screen
GLuint vb;
void Draw ( )
    static const GLfloat buffer_data[] = {
   -1.0f, -1.0f, 0.0f,
   1.0f, -1.0f, 0.0f,
   0.0f,  1.0f, 0.0f,
    //GLuint texID = glGetUniformLocation(quad_programID, "renderedTexture1");
    // FIRST: use MRTs to output four colors to four buffers
    glClear ( GL_COLOR_BUFFER_BIT | GL_DEPTH_BUFFER_BIT );
    //glDrawBuffers ( 4, attachments );
    //glDrawBuffers ( 1, attachments[0] );
    //for triangle
/*    glGenBuffers(1, &vb);
    glBindBuffer(GL_ARRAY_BUFFER, vb);
    glBufferData(GL_ARRAY_BUFFER, sizeof(buffer_data), buffer_data, GL_STATIC_DRAW);
    glEnableVertexAttribArray(0);
    glVertexAttribPointer( 0,3,GL_FLOAT,GL_FALSE,0,(void*)0);
      glDrawArrays(GL_TRIANGLES, 0, 3);
    glDrawBuffers ( 1, attachments[1] );
    GLuint texID1 = glGetUniformLocation(quad_programID, "renderedTexture2");
    //for square
    GLfloat vertices[] = {-1, -1, 0,
                          -1,  1, 0,
                           1,  1, 0,
                           1, -1, 0};
    GLubyte indices[] = {0,1,2,
                         0,2,3};
    glGenBuffers(1, &vb1);
    glBindBuffer(GL_ARRAY_BUFFER, vb1);
    glBufferData(GL_ARRAY_BUFFER, sizeof(vertices), vertices, GL_STATIC_DRAW);
    glVertexAttribPointer(0,3, GL_FLOAT,GL_FALSE 0, (void*)0);
    glDrawElements(GL_TRIANGLES, 6, GL_UNSIGNED_BYTE, indices);
    DrawGeometry ( );
    // Restore the default framebuffer
    glBindFramebuffer ( GL_DRAW_FRAMEBUFFER, defaultFramebuffer );
    BlitTextures ( );
int MultiRenderTarget ()
    signal (SIGINT, MRT_signalHandler);
        signal (SIGTERM, MRT_signalHandler);
    if(processShader(&VSObject, (char *)VERT_FILE_IR, GL_VERTEX_SHADER) == EXIT_FAILURE)
        return EXIT_FAILURE;
    if(processShader(&FSObject, (char *)FRAG_FILE_IR, GL_FRAGMENT_SHADER) == EXIT_FAILURE)
    ProgramObject = GL_CHECK(glCreateProgram());
    GL_CHECK(glAttachShader(ProgramObject, VSObject));
    GL_CHECK(glAttachShader(ProgramObject, FSObject));
    GL_CHECK(glLinkProgram(ProgramObject));
    InitFBO ();
    glClearColor ( 1.0f, 1.0f, 1.0f, 0.0f );
    Draw();
//    ShutDown();
    GL_CHECK(glUseProgram(0));
    GL_CHECK(glDeleteShader(VSObject));
    GL_CHECK(glDeleteShader(FSObject));
    GL_CHECK(glDeleteProgram(ProgramObject));
    MRT_bDone = 0;
    return 0;
Vertex Shader:
#version 300 es
layout(location = 0) in vec4 a_position;
in        vec2 attributeTextureCoordinate1;
out vec2 varyingTextureCoordinate1;
void main()
  varyingTextureCoordinate1 = attributeTextureCoordinate1;
  gl_Position = a_position;
fragment Shader:
#version 300 es
precision mediump float;
uniform sampler2D tex1;
uniform sampler2D tex2;
uniform sampler2D tex3;
uniform sampler2D tex4;
in      vec2      varyingTextureCoordinate1;
layout(location = 0) out vec4 fragData0;
layout(location = 1) out vec4 fragData1;
layout(location = 2) out vec4 fragData2;
layout(location = 3) out vec4 fragData3;
void main()
   fragData0 = texture(tex1,varyingTextureCoordinate1);
   fragData1 = texture(tex2,varyingTextureCoordinate1);
   fragData2 = texture(tex3,varyingTextureCoordinate1);
   fragData3 = texture(tex4,varyingTextureCoordinate1);
  • I found your code a little hard to follow due to the large sections and loops commented out, but the first thing I notice is the odd behaviour of your DrawGeometries method, which seems to have a for loop whereby each iteration apparently binds a single texture, a single buffer and a single attribute then commits one draw, whereas I'd imagine what you wanted to do was bind your various attributes textures and buffers and then draw once.
    I think perhaps it would help you to start a little smaller, get this working with a single render to texture, then step it up to a pair of render targets, then see about putting it in indexed loops.
