Render passes in streamline.
Hi. I have a streamline Version 6.7.1, Build 20180716_103422. gator 6.71.
Can I somehow select render passes on streamline capture. I mean how to determine begin (if load attachment was happened) or end (if flushing memory from GPU to RAM was happened) of each render passes? Which counters should I have use?
Thank you.
