Why does the CPU perform better than the GPU when blending small areas?
Hello All,
Perhaps this question is due to the nature of all GPU, regardless of the Mali GPU. I would like to know the theoretical reason why the CPU can perform better than the GPU.
Short test environment information:
  • GPU : Mali G-51 MP4 @ 700MHz
  • CPU : Cortex-A53 Quad @ 1.4GHz
  • Test : 1x1, 4x4, 8x8, 16x16, 32x32, 64x64, 128x128, 256x256 blend operation RGBA32 Format
Test Result:
*MP/s = (Number of operations during a single test run * pixmap width * pixmap height) / (1000 * 1000 * execution time in seconds)
*Measure time after glFinish() finishes
Area CPU Blending, MP/s GPU Blending, MP/s
1x1 0.02 0.0005
4x4 0.39 0.008
8x8 1.35 0.033
16x16 3.62 0.133
32x32 6.33 0.530
64x64 8.23 2.111
128x128 9.5 8.315
256x256 10.48 31.402
Only GPU with better performance than 256x256 are better and CPUs perform better with smaller sizes.
Is there something wrong I measured it? Is there another problem? Thanks in advance for any answer.
