can MALI-T720 GPU use ACL to run CNN ? or other way to use it ? or why it does not ?
we prepare to run cnn in mali T720 GPU ,but we notice that the device( mali T720 GPU ) only support OpenCL1.1, can i get more message ?
  if it no support or  not recommend, why ?
  • Hi,
    The hardware has all the necessary features but depending on what CPU you have on your platform, the GPU may or may not be an attractive option from a performance point of view.
    On the software side, the Arm Compute Library requires extensions to OpenCL 1.x. Could you give us the list of extensions reported by your device? Have you tried and failed to use the Arm Compute Library?
    Regards,
    Kévin
  • Hi,
    Regards,
    Kévin
