Gator with MALI-6xx
I was trying to follow the instructions (Using DS-5 Streamline with Mali on Samsung Galaxy Note 3 & 10.1) to build gator with Mali-6xx support for Samsung Note 10.1 (2014) with Android 4.4.2 and kernel 3.4.39. Most of the instruction went smoothly till the part of building gator drivers.
GATOR_WITH_MALI_SUPPORT=MALI_T6xx make -C /home/kbzowski/sources/android/kernel-src M=`pwd` modules
Building gator module failed with an error:
make: Entering directory `/home/kbzowski/sources/android/kernel-src'
  CC [M]  /home/kbzowski/sources/android/DS-5/arm/gator/driver-src/gator-driver/gator_main.o
:0:0: error: "MALI_SUPPORT" redefined [-Werror]
:0:0: note: this is the location of the previous definition
In file included from /home/kbzowski/sources/android/DS-5/arm/gator/driver-src/gator-driver/gator_main.c:257:0:
/home/kbzowski/sources/android/DS-5/arm/gator/driver-src/gator-driver/gator_marshaling.c: In function 'marshal_summary':
/home/kbzowski/sources/android/DS-5/arm/gator/driver-src/gator-driver/gator_marshaling.c:54:6: error: "MALI_T6xx" is not defined [-Werror=undef]
/home/kbzowski/sources/android/DS-5/arm/gator/driver-src/gator-driver/gator_marshaling.c:56:8: error: "MALI_T6xx" is not defined [-Werror=undef]
In file included from /home/kbzowski/sources/android/DS-5/arm/gator/driver-src/gator-driver/gator_main.c:263:0:
/home/kbzowski/sources/android/DS-5/arm/gator/driver-src/gator-driver/gator_trace_gpu.c: At top level:
/home/kbzowski/sources/android/DS-5/arm/gator/driver-src/gator-driver/gator_trace_gpu.c:22:36: fatal error: linux/mali_linux_trace.h: No such file or directory
cc1: all warnings being treated as errors
compilation terminated.
make[1]: *** [/home/kbzowski/sources/android/DS-5/arm/gator/driver-src/gator-driver/gator_main.o] Error 1
make: *** [_module_/home/kbzowski/sources/android/DS-5/arm/gator/driver-src/gator-driver] Error 2
make: Leaving directory `/home/kbzowski/sources/android/kernel-src'
I checked gator_marshaling.c and it looks like I should use GATOR_WITH_MALI_SUPPORT=MALI_MIDGARD instead.
but
GATOR_WITH_MALI_SUPPORT=MALI_MIDGARD make -C /home/kbzowski/sources/android/kernel-src M=`pwd` modules
Finished with an error also:
  CC [M]  /home/kbzowski/sources/android/DS-5/arm/gator/driver-src/gator-driver/gator_events_block.o
  CC [M]  /home/kbzowski/sources/android/DS-5/arm/gator/driver-src/gator-driver/gator_events_irq.o
  CC [M]  /home/kbzowski/sources/android/DS-5/arm/gator/driver-src/gator-driver/gator_events_meminfo.o
  CC [M]  /home/kbzowski/sources/android/DS-5/arm/gator/driver-src/gator-driver/gator_events_mmapped.o
  CC [M]  /home/kbzowski/sources/android/DS-5/arm/gator/driver-src/gator-driver/gator_events_net.o
  CC [M]  /home/kbzowski/sources/android/DS-5/arm/gator/driver-src/gator-driver/gator_events_perf_pmu.o
  CC [M]  /home/kbzowski/sources/android/DS-5/arm/gator/driver-src/gator-driver/gator_events_sched.o
  CC [M]  /home/kbzowski/sources/android/DS-5/arm/gator/driver-src/gator-driver/gator_events_mali_midgard.o
  CC [M]  /home/kbzowski/sources/android/DS-5/arm/gator/driver-src/gator-driver/gator_events_mali_midgard_hw.o
/home/kbzowski/sources/android/DS-5/arm/gator/driver-src/gator-driver/gator_events_mali_midgard_hw.c: In function 'read_counter':
/home/kbzowski/sources/android/DS-5/arm/gator/driver-src/gator-driver/gator_events_mali_midgard_hw.c:769:64: error: 'vithar_blocks' undeclared (first use in this function)
/home/kbzowski/sources/android/DS-5/arm/gator/driver-src/gator-driver/gator_events_mali_midgard_hw.c:769:64: note: each undeclared identifier is reported only once for each function it appears in
/home/kbzowski/sources/android/DS-5/arm/gator/driver-src/gator-driver/gator_events_mali_midgard_hw.c:776:3: error: 'value' undeclared (first use in this function)
make[1]: *** [/home/kbzowski/sources/android/DS-5/arm/gator/driver-src/gator-driver/gator_events_mali_midgard_hw.o] Error 1
Kind Regards,
Krzysztof Bzowski
  • Hi Krzysztof,
    DS-5 v5.20 has indeed changed the naming convention from MALI_T6xx to MALI_MIDGARD. You are correct in changing this.
    You have also highlighted a bug in v5.20 which we will be fixing. Thank you for bringing this to our attention.
    The problem can be resolved by applying the attached patch.
    Please feel free to let us know how it goes. If you have any other questions, feel free to ask us.
    Kind Regards,
    Michael McGeagh
  • Hi Krzysztof,
    Kind Regards,
    Michael McGeagh
