How can I set the Mali GPU priority in my application ?
In my application there seems to be quite a long delay in submitting to the GPU. Can I change the priority somehow to reduce this delay?
  • Hi davek,
    The Mali driver will only submit work to the GPU at the end of a render pass, not as the draw calls are submitted, so some delay is expected. This generally isn't visible as real "on screen" latency given that the screen is locked to a vsync update rate anyway.
    If you have a more specific issue, you'll need to share more information about the problem you are seeing.
    Cheers,
    Pete
  • Hi davek,
    Cheers,
    Pete
