OpenCL - Cant retrieve devices
I started recently with OpenCL and ARM (Particularly I'm using an Odroid U3, which has a Cortex A-9 and a Mali-400). First thing I did is an example project with some test cases. The first case get information about the retrieved "devices" with the library. The code is simple:
int dev;
cl_platform_id platform;
cl_device_type devs[NDEVS] = { CL_DEVICE_TYPE_CPU, CL_DEVICE_TYPE_GPU };
// get Platform
clGetPlatformIDs(1, &platform, NULL);
// For every device:
for (dev = 0; dev < NDEVS; dev++){
cl_device_id device;
// Find device
clGetDeviceIDs(platform, devs[dev], 1, &device, NULL);
char  vendor[1024];
char deviceName[1024];
cl_bool isAvailble = false;
char devicePlatform[1024];
clGetDeviceInfo(device, CL_DEVICE_NAME, sizeof(deviceName), deviceName, NULL);
clGetDeviceInfo(device, CL_DEVICE_VENDOR, sizeof(vendor), vendor, NULL);
clGetDeviceInfo(device, CL_DEVICE_AVAILABLE, sizeof(isAvailble), &isAvailble, NULL);
clGetDeviceInfo(device, CL_DEVICE_PLATFORM, sizeof(devicePlatform), devicePlatform, NULL);
std::cout << "---------------------------------------------------------------------------" << std::endl;
std::cout << "Device type is " << (dev ? "GPU" : "CPU") << " with ID: " << device << "and " << (isAvailble ? "is " : "isn't ") << "available." << std::endl;
std::cout << "Device's platform is " << devicePlatform << std::endl;
std::cout << "Vendor is " << vendor << std::endl;
std::cout << "Device's name is " << deviceName << std::endl;
It gets a CPU device and a GPU device and extract some information about it. I tested it on my PC and got it's information:
Device type is CPU with ID: 02AAB628and is available.
Device's platform is ¶ñØ►
Vendor is GenuineIntel
Device's name is       Intel(R) Core(TM) i7-3632QM CPU @ 2.20GHz
Device type is GPU with ID: 007266F0and is available.
Vendor is Advanced Micro Devices, Inc.
Device's name is Turks
But when I use this code on the Odroid U3 I got:
Device type is CPU with ID: 0x3b9cand isn't available.
Device's platform is Y0ý¶
Vendor is ¨;
Device's name is ∟
Device type is GPU with ID: 0x3b9cand isn't available.
Vendor is ¨;
Device's name is ∟
I don't know why, the system tells me that devices are unavailable and could not retrieve either vendor's, platform's or device's names.
Can anybody help me?
Thanks in advance,
Pablo R.S.
