glReadPixels generates OUT_OF_MEMORY error
Hi.
Usually, I use render-to-texture technique to process the image.
However, recently, I need to read the contents to the system memory.
So, I tried to use glReadPixels as follows:
GLubyte pixels[256] = { 0, 0, 0, 0 };
GL_CHECK( glReadPixels(100, 100, 2, 2, GL_RGBA, GL_UNSIGNED_BYTE, pixels) );
LOGI("%d %d %d %d\n", pixels[0], pixels[1], pixels[2], pixels[3]);
This code works well on my desktop PC with NVIDIA card.
But, it fails with ARM Mali-T628.
Debug: test0clear.cpp:36: glGetError() = OUT_OF_MEMORY at test0clear.cpp:36
Here is the details of my system:
EGL vendor = ARM
EGL version = 1.4 Midgard-"r4p0-02rel0"
EGL client apis = OpenGL_ES
GL ES vendor = ARM
GL ES version = OpenGL ES 3.0
GL ES renderer = Mali-T628
GL ES SL version = OpenGL ES GLSL ES 3.00
Do you have any idea to overcome this abnormal situation?
Thanks in advance.
oceancru
