eglMakeCurrent outputs on console - FATAL GL_ARB_transform_feedback2 extension is required but not detected.
I am using ARM GLES3.0 emulator. I have NVIDIA GeForce 8400 GS which supports OpenGL 3.3. My problem is, though eglMakeCurrent succeeds it leaves following message on console even simple Cube example - "FATAL GL_ARB_transform_feedback2 extension is required but not detected. Your GLES3.0 application will crash if you attempt to resume a transform feed-back operation! "
What is this message for? Can I avoid outputing it on Console? Is there any issue with my card supporting GLES30 emulator?
  • What is this message for?
    It's warning you that your host platform doesn't support the GL_ARB_transform_feedback2 extension, which is needed for the emulation of the OpenGL ES 3.0 transform feedback feature.
    No.
    Provided you don't try to resume a transform feedback operation it should be fine, but you are not able to access all OpenGL ES 3.0 functionality on that card/driver pairing.
    HTH,
    Pete
    No.
    HTH,
    Pete
