Hello there,
I add a job schedule policy ( similar to mali_kbase_js_policy_cfs along with the driver ) to the driver, and the new driver starts and init normally.
But it continually report following errors, and the graphic and opencl stack in user space can not run.
Error 1:
[ 73.559188] [B0] Mali<ERROR, BASE_JM>: In file: drivers/gpu/arm/t6xx/kbase/src/common/mali_kbase_jm.c line: 172 function:kbase_jo
[ 73.559200] [B0] t6xx: GPU fault 0x58 from job slot 0
I search in the driver, 0x58 means is "BASE_JD_EVENT_DATA_INVALID_FAULT".
Question 1:
What does BASE_JD_EVENT_DATA_INVALID_FAULT actually mean?
What should I do to solve the problem?
Error 2:
[ 74.184232] [B3] fences:
[ 74.184235] [B3] --------------
[ 74.184239] [B3] [dea76a80] mali_fence: signaled
[ 74.184243] [B3] malitl_1731_0x405a87f8_pt signaled@27.532617: 4(0) / 30
[ 74.184251] [B3] [dd77cc80] StrictModeFlash:1: signaled
[ 74.184255] [B3] s3c-fb_pt signaled@29.167068: 25 / 77
[ 74.184262] [B3] [dc89d900] mali_fence: signaled
[ 74.184269] [B3] malitl_1731_0x405a87f8_pt signaled@55.510202: 20(0) / 30
[ 74.184277] [B3] [dc8a0e80] mali_fence: error
[ 74.184281] [B3] malitl_1731_0x405a87f8_pt error@55.959635: 26(-14) / 30
[ 74.184305] [B3] s3c-fb_pt signaled@72.532865: 76 / 77
Question 2:
What does the error mean?
Which source code does the error come from?
Best Regards,
wlc
The data the GPU has received is not within spec, and it's thrown an error.
I would guess your scheduler changes are incorrect and sending work to the GPU out-of-order (either with respect to other GPU work or CPU-side work such as cache maintenance), so the GPU is reading undefined or invalid memory buffers.
It's a side effect of the fault above. It's a fence error from the window system because we failed the window rendering.
Grep is your friend.
If you are a direct licensee and have a support contract please feel free to contact support@arm.com.
HTH, Pete
Thanks for your relay, it's a great help. Problems are solved under your guidance.
I get another question about job slot and address space, need your help, thank you very nuch!
