Summary
Is OpenCL support for the Mali-T628 (for example as found in the Exynos 5420 SoC on the Arndale Octa board) available? If so, how to set it up?
More details
According to the vendor, OpenCL should be supported, but the Arndale Octa Wiki does not state how this can be achieved.
I am using the latest Linaro developer build and installed Mali drivers that contain OpenCL libraries for Mali T604. According to this guide, the driver actually contains references to the Mali T628. So I tried to create the udev rule as specified, which is supposed to solve a permission problem with /dev/mali0, but I found that there is no /dev/mali0 on my installation at all. So my conclusion is that the driver indeed does not support T628.
When I execute a clinfo utility, clGetDeviceInfo returns CL_OUT_OF_HOST_MEMORY for some device properties. Why can I query the GPU for some characteristics, but does this fail for some others? When running a normal application, the same error appears when trying to create an OpenCL Context.
I was surprised to find this topic, where yoshi seems to have OpenCL working and can run benchmarks on his Arndale Octa board. How is this possible if there is no driver available? Or am I just missing something? I hope that you can help me to also establish a working OpenCL development environment.
Hi Rich,
I've not been able to look into this a huge amount for you unfortunately.
I really appreciate the efforts that you (and all others in this topic) put into helping me, so don't worry!
It is good to hear that you have been able to compile and run my code. Could you elaborate on the performance numbers that the program outputs? Are they anywhere near the numbers?
Bram
