eglGetError() = 12291 (0x00003003)
Hi
I am a beginner inOpenGL ES 2.0,and get a problem,
After decompress Mali_OpenGL_ES_2.0_SDK_for_Linux_On_ARM_v1.2.0.9310_Linux.tar.gz
and install Sourcery CodeBench Lite Edition for ARM (arm-2013.05-24-arm-none-linux-gnueabi.bin),
build the sample (Cube)
                      bash build-x86-linux.sh Cube            succeed
cd build/x86/Cube
ls
                         assets  Cube
                   ./Cube
                        Error: eglGetError() = 12291 (0x00003003) at  /home/pass2014/Software/Mali_OpenGL_ES_2.0_SDK_for_Linux_On_ARM_v1.2.0/samples/linux/Cube/Cube.cpp:177
code
int main(void)
    /* Intialize the Platform object for platform specific functions. */
    Platform* platform = Platform::getInstance();
    /* Initialize windowing system. */
    platform->createWindow(WINDOW_W, WINDOW_H);
    /* Initialize EGL. */
    EGLRuntime::initializeEGL(EGLRuntime::OPENGLES2);
   EGL_CHECK(eglMakeCurrent(EGLRuntime::display, EGLRuntime::surface, EGLRuntime::surface, EGLRuntime::context));                //line 177
    /* Initialize OpenGL ES graphics subsystem. */
    setupGraphics(WINDOW_W, WINDOW_H);
    /* Timer variable to calculate FPS. */
    Timer fpsTimer;
    fpsTimer.reset();
    bool end = false;
    /* The rendering loop to draw the scene. */
    while(!end)
        /* If something has happened to the window, end the sample. */
        if(platform->checkWindow() != Platform::WINDOW_IDLE)
            end = true;
        /* Calculate FPS. */
        float fFPS = fpsTimer.getFPS();
        if(fpsTimer.isTimePassed(1.0f))
            LOGI("FPS:\t%.1f\n", fFPS);
        /* Render a single frame */
        renderFrame();
         * Push the EGL surface color buffer to the native window.
         * Causes the rendered graphics to be displayed on screen.
        eglSwapBuffers(EGLRuntime::display, EGLRuntime::surface);
    /* Shut down OpenGL ES. */
    /* Shut down Text. */
    delete text;
    /* Shut down EGL. */
    EGLRuntime::terminateEGL();
    /* Shut down windowing system. */
    platform->destroyWindow();
    /* Shut down the Platform object. */
    delete platform;
    return 0;
What should I do to fix the problem?
