Not able to Trace App using MGD
facing currently 2 issues
1) using processlist.cfg "process = com .xxxx.xxx" is Not logging my app , but not having this log am able to Log the System.
     i use the Following command   to generate the processlist.cfg  : echo     "process = com .xxxx.xxx" > /system/lib/egl/processlist.cfg  , the File Gets Generated but no output on trace.
2) even though i use VBO  -  i see the Following warning
" Detected 150 calls to glVertexAttribPointer without a bound vertex buffer object " .
Please Let me know How to resolve Profiling my app & what does the above error mean ??
Thanks in Advance
  • Hi subrymanyam,
    The processlist.cfg is intended to be a line separated list of process names. Your processlist.cfg file should therefore contain just the process name "com.xxxx.xxx", not "process = com.xxxx.xxx". So your command becomes:
    echo "com.xxxx.xxx" > /system/lib/egl/processlist.cfg
    For your second question, MGD is helpfully reporting that for those 150 calls, the value of GL_ARRAY_BUFFER_BINDING was zero, indicating no VBO being bound. The report itself does not imply an error in either your application or MGD, it is just reporting a potential inefficiency in your application, as those 150 calls would have referenced client buffers. Whether this is a problem/potentially sub-optimal situation is completely dependent on your particular situation, we are just highlighting the situation so you can make a judgement call.
    Can you please check your trace output and if you believe there is in fact a VBO bound and MGD is reporting incorrect information, please provide a reproducer or a partial trace showing the problem?
    Thanks,
    Chris
