Am Trying to Use MGD(Mali Graphics Debugger)When i try to "export LD_PRELOAD=/path/to/intercept/libinterceptor.so" as per the Document "Could not load needed library 'libdl.so.2' for 'libinterceptor.so'"
and if i try to Libdl.s0.2 it depends libc.so.6 and Finally End up in this Error libdl.so.2 is not a valid ELF object.
Am using the Latest Version "Mali Graphics Debugger v1.2.1"
Target Device Details :
Note :
used the Methind 8.1.4 Mentioned in the user Document too as Below:
I tried Having Both Processlist.cfg & not having the same still No Trace is Generated.
If i dont use Pre load it ll Connect to the Port and No Trace is Generated .Please Help me to Resolve them.
Thanks in Advance
Hi subrhmanyam,
I think there's been some confusion, if you're running on Android you should not be using the PRELOAD method, you should just be putting libGLES_mgd.so in /system/lib/egl/ and modifying /system/lib/egl/egl.cfg to point to it. You seem to be following the Linux target instructions.
Hope this helps,
Chris
