How can i get “frame time” with Streamline ?
hi  everyone:
          How can i get “frame time” or “frame rate”  with Streamline?
  • There is no simple "FPS" counter, Streamline is a time-based sample scheme which gives a new counter sample every 1ms and it doesn't really know about frames.
    FPS is generally easiest to measure from the application side, looking at the rate you are completing eglSwapBuffer calls, but be aware that this may be limited by window system performance (most commonly because of vsync), so may not be showing you the true performance of the GPU.
