etcpack error when compress png
I am a freshman of Graphic.
I need to compress a lot of "png" files to "ktx" format,so i used the command-line version of the Texture Compression Tool, but it seems not to work well.
The command i used was "ectpack 1.png  myImages".
It did not work, given the following output.
[malitc-1]Compressing. Output file: myImages\1.pkm
无效参数 - tmp.ppm
Error: could not convert input image 1.png to .ppm
Some extra informations are:
1 the version of tool is “Mali Texture Compression Tool v4.0.0“
2 the operating system is Windows 7, Service Pack 1
3 The GUI works well when compress ".png" file
4 The command "ectpack 1.ppm  myImages" works well
I guess that the etcpack first comvert the ”.png“ to ".ppm", then compress the ”.ppm" file, but the conversion from ".png" to ".ppm" seems failed.
I did not know why.
Is there any guy who has the same problem?  I need help.
